| Newbie needs help with motor and ESC | |
Anthony Exton Deck Hand
Posts : 3 Join date : 2014-11-16 Location : Ely
| Subject: Newbie needs help with motor and ESC Sun Nov 16, 2014 9:10 pm | |
| Hi,
I need some help choosing a motor and ESC for a second hand boat I brought for my son for Christmas:rendeer:.
The boat is 40" long & 11" beam single screw.
The boat came with a 540 motor which I believe is a little small? I plan to use 12v 7ah sealed batteries.
I need some advice on a suitable motor and ESC either brushed or brushless?
Anthony | |
| Subject: Re: Newbie needs help with motor and ESC Sun Nov 16, 2014 10:20 pm | |
| Welcome aboard, I'm new to the model boat world, there are so many choices out there. Any chance you could tell what the boat is, perhaps a photy or two might help | |
| Subject: Re: Newbie needs help with motor and ESC Mon Nov 17, 2014 6:56 am | |
| Welcome.
Depending on the type of boat and the speed you want from it, the 540 may not be too small. It also depends a little on what version of the 540 the motor is.
As troutrunner says, a photo would help.
| Subject: Re: Newbie needs help with motor and ESC Mon Nov 17, 2014 8:42 am | |
| Sorry I can not work out how to add a picture to this page, I have added the boat picture as my profile picture.
Anthony | |
| Subject: Re: Newbie needs help with motor and ESC Mon Nov 17, 2014 8:50 am | |
| Anthony
Instructions for posting photos are given in the Second Post on the Welcome Section of the Forum, Alternatively email them to me bnw at bnw dot me dot uk and I'll post them.
| Subject: Re: Newbie needs help with motor and ESC Mon Nov 17, 2014 1:27 pm | |
| - barriew wrote:
- Anthony
Barrie Hi Barrie, Thanks for the information, Is there anyway to add a picture to a existing post? Anthony | |
| Subject: Re: Newbie needs help with motor and ESC Mon Nov 17, 2014 2:19 pm | |
| Not that I know of, although You could always quote your previous message and add the photo.
| Subject: Re: Newbie needs help with motor and ESC Thu Jan 08, 2015 7:28 am | |
| Should be able to add photo's using the edit button at the top right of your posts.
Damien. |
| Subject: Re: Newbie needs help with motor and ESC Thu Jan 08, 2015 7:49 am | |
| - Damien wrote:
- Should be able to add photo's using the edit button at the top right of your posts.
Damien. DAmien I think the Edit facility only exists for a short time after making the post. Barrie | |
| Subject: Re: Newbie needs help with motor and ESC Thu Jan 08, 2015 8:41 am | |
| Ok barrie perhaps because I'm a moderator I can edit anything anytime. |
| Subject: Re: Newbie needs help with motor and ESC Thu Jan 08, 2015 2:31 pm | |
| That must be true Damien - the Edit button has gone from my post above.
| Subject: Re: Newbie needs help with motor and ESC Thu Jan 08, 2015 3:22 pm | |
| _________________ I'm Not Anti-Social, I'm Anti-Stupid.
inertia Midshipman
| Subject: Re: Newbie needs help with motor and ESC Thu Feb 19, 2015 10:07 am | |
| - Anthony Exton wrote:
- Hi,
Anthony Anthony Assuming you're still awaiting a reply, is that a picture of the model as your avatar? If so then I would suggest an MFA 850 with a 45mm or 50mm diameter prop if you intend to use a SLA battery. Personally I wouldn't use a heavy lead-acid battery in such a boat anyway; much of its power would be spent just pushing its own weight. For a very good, reasonably-priced ESC which will cope with this motor go for a Microgyros FR40. Brushless motors require far more current than can be supplied by SLA batteries so you'd need to use either NiMH or LiPo cells. The Vintage Model Company sell two sizes of brushless motor and matched speed controller; the larger one would probably suit your model. Dave M | |
| Subject: Re: Newbie needs help with motor and ESC | |
