 Atlantic 85
5 posters
gribeauval
gribeauval
Atlantic 85 Empty
PostSubject: Atlantic 85   Atlantic 85 EmptySun May 03, 2015 12:31 pm
Here is the reason that the Watson refit is taking longer than anticipated.
I was asked to fix a leaking lifeboat rib for a client, this has turned into a full refit/rebuild. The original is a Models by Design 1/10th scale Atlantic 21 style rib ( why they moulded it at 1/10th and not 1/12th scale is beyond me!). The client wanted it to look more like an Atlantic 85 as well as the leaks fixing thus this rebuild.
The hull is a couple of inches too long for a true scale A85 so it will be a 'stand off scale' model.
State of the boat when it arrived.
Atlantic 85 A85-refit-001_zpswwrbs01z
The leaking problem was the ply transom plate had a couple of cracks in the epoxy where it was attatched to the moulding.
Atlantic 85 A85-refit-002_zps2q5wxzlk
The plate was removed and the inside of the moulding was sealed with epoxy to fill all the existing holes.
Atlantic 85 A85-refit-003_zpsoshbwvie
A pattern for a new birch ply transom was made and cut out.
Atlantic 85 A85-refit-004_zpsjvesrgx1
This was fitted onto the moulding with epoxy and allowed to set for 48 hours before the clamps were removed.
Atlantic 85 A85-refit-005_zpswpkjuavy
The underside of the hull and transom were then rubbed down and given a coat of primer.
Atlantic 85 A85-refit-006_zpspqcfefdn
gribeauval
gribeauval
Atlantic 85 Empty
PostSubject: Re: Atlantic 85   Atlantic 85 EmptySun May 03, 2015 1:55 pm
On with the rebuild.
The majority of the grp deck, which was lumpy and uneven, was removed ready for a new styrene deck to be fitted in place.
Atlantic 85 A85-refit-007_zpswmiv74ju
The deck was fitted in sections to make things easier. The stern section was bonded in place first and the steering servo was fitted through this piece.
Atlantic 85 A85-refit-009_zpsew6q3o24
The centre section was then sprung into place and welded to the rear section with liquid styrene cement. The edges were fixed to the grp deck with stabillit express resin glue.
Atlantic 85 A85-refit-010_zpsouoj5mlk
The front section was then glued/welded in place and the cutout for hull access marked up ready to remove. The edges of the new deck will be sealed with clear silicone sealer AFTER painting to ensure that there is no chance of leakage into the lower hull section.
Atlantic 85 A85-refit-011_zpsaofhsdzo
Cutout made and the coaming added.
Atlantic 85 A85-refit-012_zpsydsvyfkf
gribeauval
gribeauval
Atlantic 85 Empty
PostSubject: Re: Atlantic 85   Atlantic 85 EmptySun May 03, 2015 2:17 pm
The rear mast structure was next on the agenda.
The basic support hoops were bent and checked for fit in the hull.
Atlantic 85 A85-refit-013_zpszjirq8v6
Atlantic 85 A85-refit-014_zpsnabdx4px
These were brazed together and the curved air bag support frame fixed in place along with the rest of the support bars. This part of the build took several attempts to get the correct curvatures and fit!!
Atlantic 85 A85-refit-015_zpsel2o8qxw
Atlantic 85 A85-refit-016_zpsynr2rnac
After cleaning up the structure it was checked for fit again in the hull.
Atlantic 85 A85-refit-017_zpsfgxw8u4c
The upper mast section, radar platform and the navigation light supports were made from styrene and fixed in place before the whole structure was painted satin black.
Atlantic 85 A85-refit-018_zpsx34idzpd
Atlantic 85 Empty
PostSubject: Re: Atlantic 85   Atlantic 85 EmptySun May 03, 2015 4:07 pm
that is one superb piece of brazing mike......very clean..........as for the scale.............one wouldn't like to comment, lol.especially as his Cygnus boats are all 1;12, plus his extensive range of lifeboat mouldings being the same scale 1;12.
the mind boggles,
gribeauval
gribeauval
Atlantic 85 Empty
PostSubject: Re: Atlantic 85   Atlantic 85 EmptySun May 03, 2015 4:35 pm
He must had had a minor mental abberation!! lol!
Still it's not too far out for a stand off scale A85.
gribeauval
gribeauval
Atlantic 85 Empty
PostSubject: Re: Atlantic 85   Atlantic 85 EmptySun May 03, 2015 6:40 pm
Now on with the console for the four man crew.
Using the pattern used for the deck cut-out the basic shape of the console was made frrom 2mm thick styrene sheet.
Atlantic 85 A85-refit-019_zpso8zyvyvr
The helmsman, from DK figures, has been "adjusted" so that he sits astride the wide section of the console.
Atlantic 85 A85-refit-020_zpskfjg0xny
The distinctive front panel has been fabricated and the seat backs added.
Atlantic 85 A85-refit-021_zpsykgw4twi
Two crewmen have also been "adjusted" to sit on the central section of the console.
Atlantic 85 A85-refit-022_zpsfann36sc
Looks reasonable in the hull.
Atlantic 85 A85-refit-023_zpsrx5zs1sy
The central control panel has also been fabricated and the rest of the sides added ready for painting and detailling.
Atlantic 85 A85-refit-024_zpsilm2emgn
gribeauval
gribeauval
Atlantic 85 Empty
PostSubject: Re: Atlantic 85   Atlantic 85 EmptySun May 03, 2015 8:16 pm
The console has been painted and the detailling started. The seats are made from neoprene so if they get wet it doesn't matter too much. The locker doors are just added onto the outside.
Atlantic 85 A85-refit-025_zpsiukqfyed
Atlantic 85 A85-refit-026_zps0srnbi5v
The grab handles have been bent up and fixed onto the console.
Atlantic 85 A85-refit-027_zpsojq1nj9x
The switch/instrument panels were constructed from styrene.
Atlantic 85 A85-refit-028_zpsg4ljcmhb
Full set of panels made and painted ready to fit.
Atlantic 85 A85-refit-029_zpsxehzmk1l
All the panels have now been fitted onto the console.
Atlantic 85 A85-refit-030_zpsqcxkodze
gribeauval
gribeauval
Atlantic 85 Empty
PostSubject: Re: Atlantic 85   Atlantic 85 EmptyMon May 04, 2015 8:04 pm
The hull and deck have been painted and a stand built to protect the finish. This also allowed the clear silicone sealant to be done between the edge of the deck and the hull tubes. Now there should be no way that water can get inside the hull.
Atlantic 85 A85-refit-031_zpsw4dv2vsa
Close up of the joint.
Atlantic 85 A85-refit-032_zpschored8o
The painted mast and the console have been slipped in place in the hull to check that it has the look of an Atlantic 85.
Atlantic 85 A85-refit-033_zpsvj1rcr9a
Atlantic 85 A85-refit-034_zpsqtdy4z4x
Atlantic 85 A85-refit-035_zps05pzjb0x
Whilst all this paint was drying I took the black Graupner outboards (see first picture in this build), removed all the labels, cleaned up and masked off the casing, sprayed two coats of grey primer, two coats of metallic gunmetal grey, made on the PC Yamaha 115 logos and added them to the casings.
The result is more RNLI looking outboards ready to hang on the transom of the boat.
Atlantic 85 A85-refit-036_zps0so9ynql
The engines will be refitted tomorrow. Thumbup
Atlantic 85 Empty
PostSubject: Re: Atlantic 85   Atlantic 85 EmptyMon May 04, 2015 10:21 pm
2thumbsup nice job
Atlantic 85 Empty
PostSubject: Re: Atlantic 85   Atlantic 85 EmptyTue May 05, 2015 12:07 am
2thumbsup 2thumbsup 2thumbsup
Atlantic 85 Empty
PostSubject: Re: Atlantic 85   Atlantic 85 EmptyTue May 05, 2015 10:57 am
2thumbsup 2thumbsup 2thumbsup 2thumbsup 2thumbsup 2thumbsup 2thumbsup 2thumbsup 2thumbsup 2thumbsup 2thumbsup 2thumbsup 2thumbsup 2thumbsup 2thumbsup
emrys
Atlantic 85 Empty
PostSubject: Re: Atlantic 85   Atlantic 85 EmptyTue May 05, 2015 5:13 pm
Amazing work.
gribeauval
gribeauval
Atlantic 85 Empty
PostSubject: Re: Atlantic 85   Atlantic 85 EmptyWed May 06, 2015 10:38 am
The engines have now been reassembled and fitted onto the new transon plate.  The are a little overscale but short of an expensive re-engine with brushless motors the client will have to live with them as they are. Very Happy
Atlantic 85 A85-refit-037_zpsbbtrozra
The bolts will be trimmed later and the wiring sealed into conduits through the deck to keep out the water.
Atlantic 85 A85-refit-038_zpsjrmti7zl
The mast and console were slipped in place to get an overall view of the boat at the moment and check that it looks something like an Atlantic 85.
Atlantic 85 A85-refit-039_zps7dkxicsz
Atlantic 85 A85-refit-040_zpslzcquow9
Atlantic 85 Empty
PostSubject: Re: Atlantic 85   Atlantic 85 EmptyWed May 06, 2015 12:04 pm
Superb as usual MORE MORE
Atlantic 85 Empty
PostSubject: Re: Atlantic 85   Atlantic 85 EmptyWed May 06, 2015 12:59 pm
Stunning! 2thumbsup 2thumbsup
gribeauval
gribeauval
Atlantic 85 Empty
PostSubject: Re: Atlantic 85   Atlantic 85 EmptySat May 09, 2015 8:39 pm
The access caps for the ballast tanks have been fitted into the floor, the non-slip areas on the hull tubes added, the enclosed radar on the mast and the navigation lights fitted.
Atlantic 85 A85-refit-041_zpsew2tqrvq
All the wiring has now been done and passed through the conduits into the hull.
Atlantic 85 A85-refit-042_zps8tjlnqs3
I have also started the painting of the crew ready to fit onto the console.
Atlantic 85 A85-refit-043_zpsizodq5zb
gribeauval
gribeauval
Atlantic 85 Empty
PostSubject: Re: Atlantic 85   Atlantic 85 EmptySun May 10, 2015 8:25 pm
The upper mast aerial has been made and fitted along with the curved, folded self righting air bag.
Atlantic 85 A85-refit-044_zpsxadndr5x
The decals for the RNLI branding have been made on the PC and added to the dry suits of the crew. Just need to find some curved, clear packaging to make the visors now.
Atlantic 85 A85-refit-045_zps0oruqptw
The crew have now been fitted onto the console.
Atlantic 85 A85-refit-046_zps6td0bws1
Console fitted into the hull.
Atlantic 85 A85-refit-047_zpspplwq24a
Atlantic 85 A85-refit-048_zpsimscfqf8
Atlantic 85 Empty
PostSubject: Re: Atlantic 85   Atlantic 85 EmptySun May 10, 2015 8:28 pm
looks superb mike.
Atlantic 85 Empty
PostSubject: Re: Atlantic 85   Atlantic 85 EmptySun May 10, 2015 11:42 pm
Agreed a Ripper build Mike.  2thumbsup 2thumbsup 2thumbsup 2thumbsup 2thumbsup 2thumbsup 2thumbsup 2thumbsup 2thumbsup 2thumbsup 2thumbsup 2thumbsup Thumbup
gribeauval
gribeauval
Atlantic 85 Empty
PostSubject: Re: Atlantic 85   Atlantic 85 EmptyMon May 11, 2015 8:58 pm
Thanks guys, nice to be appreciated. Thumbup
Spent today making and fitting the grab handles that are along the inside of the hull tubes.
Atlantic 85 A85-refit-050_zpstuuc98qy
Atlantic 85 A85-refit-051_zps4cehaart
Also fitted the r/c twin latching switch that will operate the lights.
Atlantic 85 A85-refit-052_zpslohedkma
Last thing today was the fitting of the 'D' section fendering along the outside of the hull tubes.
Atlantic 85 A85-refit-053_zpsmzic0cdz
Atlantic 85 Empty
PostSubject: Re: Atlantic 85   Atlantic 85 EmptyMon May 11, 2015 9:17 pm
2thumbsup
Atlantic 85 Empty
PostSubject: Re: Atlantic 85   Atlantic 85 EmptyTue May 12, 2015 1:20 am
2thumbsup 2thumbsup
Atlantic 85 Empty
PostSubject: Re: Atlantic 85   Atlantic 85 EmptyTue May 12, 2015 2:44 pm
SUPERB .............................  cheers
ken
gribeauval
gribeauval
Atlantic 85 Empty
PostSubject: Re: Atlantic 85   Atlantic 85 EmptyThu May 14, 2015 6:32 pm
The large 'lump' at the bow of the boat has been made and fitted in place.
Atlantic 85 A85-refit-054_zpsmzeyvoa4
The decals for the corporate branding have been made on the pc and added to the tubes along with the grab line around the hull.
Atlantic 85 A85-refit-055_zpsiwwprkkr
Finally for now the name boards have been made and fitted onto the mast as well as the fleet number.
Atlantic 85 A85-refit-056_zpszvgfpk5c
Just a few more small parts to make and fit then it's wire up the esc, plug in a battery and give it a test on the lake. Thumbup
Atlantic 85 Empty
PostSubject: Re: Atlantic 85   Atlantic 85 EmptyFri May 15, 2015 6:29 am
Atlantic 85 2302161080Atlantic 85 2302161080Atlantic 85 2302161080Atlantic 85 2302161080
gribeauval
gribeauval
Atlantic 85 Empty
PostSubject: Re: Atlantic 85   Atlantic 85 EmptyTue Jun 09, 2015 1:39 am
Watch the whole build in six minutes. 2thumbsup
Atlantic 85 Empty
PostSubject: Re: Atlantic 85   Atlantic 85 EmptyTue Jun 09, 2015 2:09 am
Wow not only a great  model boat builder a movie maker as well Outstanding Mike.
2thumbsup 2thumbsup 2thumbsup 2thumbsup 2thumbsup 2thumbsup 2thumbsup 2thumbsup 2thumbsup 2thumbsup 2thumbsup 2thumbsup 2thumbsup 2thumbsup 2thumbsup 2thumbsup
Atlantic 85 Empty
PostSubject: Re: Atlantic 85   Atlantic 85 EmptyTue Jun 09, 2015 11:27 am
brilliant Mike..................I like the lifeboat as well lol! lol! Thumbup 2thumbsup Thumbup 2thumbsup
gribeauval
gribeauval
Atlantic 85 Empty
PostSubject: Re: Atlantic 85   Atlantic 85 EmptySat Jun 13, 2015 4:08 pm
After a test run in the tank it was decided that the stern is too heavy and still causing swamping problems so the 85 is going on a diet!!
This consists of re-motoring the outboards with brushless motors. The two large 540 style motors, weighing 260gms each, will be replaced with 2 Logic 2829/13 outrunners, weighing 57gms each.  A saving of 406gms or just over 14oz in old money!!!!!
Atlantic 85 A85-refit-059_zps6rbnwyhv
The smaller motor will also allow the oversize casing to be reduced to a more scale like size.
Atlantic 85 A85-refit-060_zps2lpnfdpr
Onwards and upwards !!!
Atlantic 85 Empty
PostSubject: Re: Atlantic 85   Atlantic 85 EmptySat Jun 13, 2015 4:21 pm
this is where I become even more interested than I was if that can be so.........as I have been down the lakeside at |Fleetwood today asking the guys at the vintage powerboat meeting about Brushless, and am going to go brushless with my Flying Christine after my summer holidays...........so will be taking great notice of this. cheers, mike............
maybe you can teach an old dog new tricks after all.
gribeauval
gribeauval
Atlantic 85 Empty
PostSubject: Re: Atlantic 85   Atlantic 85 EmptySat Jun 13, 2015 5:18 pm
So that's a pair of old dogs learning new tricks at the same time!! lol!
Atlantic 85 Empty
PostSubject: Re: Atlantic 85   Atlantic 85 EmptySat Jun 13, 2015 5:38 pm
it's all pretty alien to me having a motor with three wires coming out, and the outside spins around the inside, lol........but if it'll get my little flying christine running faster than a slug I'll be happy and sail it more often than I have......twice in 4 years, just ain't good enough, lol Sad
gribeauval
gribeauval
Atlantic 85 Empty
PostSubject: Re: Atlantic 85   Atlantic 85 EmptySat Jun 13, 2015 7:09 pm
The new motor has been reconnected to the flexible drive cable within the casing with the original solid coupling and the mounting plate for the motor bolted to the casing. The extra length on the outside will be trimmed off and when the casing is repainted the nuts will not be noticable.
Atlantic 85 A85-refit-061_zpsqebfkqlq
Comparison of the new motor in place alongside the original set up. It takes a leap of faith to believe that the tiny thing I have just fitted is just as poweful as the big lump behind it !!
Atlantic 85 A85-refit-062_zpsavbrjwpy
The top casing has also now been shortened by about 1" and the top refitted, it now just needs a little filler and sanding plus a repaint.
Atlantic 85 A85-refit-063_zpskrvpgr4q
Atlantic 85 Empty
PostSubject: Re: Atlantic 85   Atlantic 85 EmptySat Jun 13, 2015 11:48 pm
Modelers masters of innovation. 2thumbsup 2thumbsup 2thumbsup 2thumbsup 2thumbsup 2thumbsup
gribeauval
gribeauval
Atlantic 85 Empty
PostSubject: Re: Atlantic 85   Atlantic 85 EmptyMon Jun 15, 2015 1:36 pm
The re-motored outboards have been repainted, rebadged and refitted onto the transom. They look a great deal better than the originals ever did on the end of the lifeboat!!
Atlantic 85 A85-refit-064_zpsao9h3ama
I have also fitted a clear styrene "wash deflector" onto the transom. This, with the reduction in weight at the stern, should help stop the wash swamping the boat when the throttles are very shut quickly. The silicone adhesive will take 36 hours to cure then it will be wire up the two esc's and keep your fingers crossed!!
Atlantic 85 A85-refit-065_zpsm4joo4ik
Atlantic 85 Empty
PostSubject: Re: Atlantic 85   Atlantic 85 EmptyMon Jun 15, 2015 1:48 pm
gribeauval
gribeauval
Atlantic 85 Empty
PostSubject: Re: Atlantic 85   Atlantic 85 EmptyThu Jun 18, 2015 1:35 pm
Testing is complete !!!!
NO LEAKS !!!!
Test tank video :
Atlantic 85 Empty
PostSubject: Re: Atlantic 85   Atlantic 85 EmptyThu Jun 18, 2015 2:36 pm
Ripper job Mike.  2thumbsup 2thumbsup 2thumbsup 2thumbsup 2thumbsup 2thumbsup 2thumbsup 2thumbsup 2thumbsup 2thumbsup 2thumbsup
gribeauval
gribeauval
Atlantic 85 Empty
PostSubject: Re: Atlantic 85   Atlantic 85 EmptyThu Jun 18, 2015 2:48 pm
Cheers Damien. Thumbup
You have no idea of the strain this refit of a refit has put on my reputation as a boat builder and my self belief!! pale pale pale
Mike
Atlantic 85 Empty
PostSubject: Re: Atlantic 85   Atlantic 85 EmptyFri Jun 19, 2015 1:08 am
Mike take a deep breath, forget what others my think your work is astoundingly brilliant and when it's all said and done the only person you have to please is your self.
With members here leaving encouraging truthful posts meant to give you a buzz.
Your reputation is intact mate.  2thumbsup 2thumbsup
Atlantic 85 Empty
PostSubject: Re: Atlantic 85   Atlantic 85 EmptyFri Jun 19, 2015 1:32 am
I'm puzzled why you think your reputation is in dispute to start with  scratch scratch scratch
Atlantic 85 Empty
PostSubject: Re: Atlantic 85   Atlantic 85 EmptyFri Jun 19, 2015 8:31 am
never doubted you mike.........brilliant job, superb finish and like always a great build blog......neil. Thumbup 2thumbsup Thumbup 2thumbsup Thumbup 2thumbsup Thumbup 2thumbsup Thumbup 2thumbsup Thumbup 2thumbsup Thumbup
gribeauval
gribeauval
Atlantic 85 Empty
PostSubject: Re: Atlantic 85   Atlantic 85 EmptyFri Jun 19, 2015 11:43 am
If it was my boat then I wouldn't worry but this is a client's boat and he travelled a long way to collect it and had to go away without it !!!
It was more a case of I thought I had solved the problems but had to take steps back and re-do the job. Something I hate doing as I normally take my time and get it to my satisfaction first time.
Still it's all right now and he is happy again. 2thumbsup 2thumbsup
Mike
Atlantic 85 Empty
PostSubject: Re: Atlantic 85   Atlantic 85 EmptyFri Jun 19, 2015 12:05 pm
Glad your feeling better about it Mike.
2thumbsup Thumbup Thumbup 2thumbsup
Atlantic 85 Empty
Atlantic 85
» Atlantic 21
» LESRO ATLANTIC 21 KIT.
