 BRAIN FART, PARALLEL OR SERIES WIRING HARNESS?
BRAIN FART, PARALLEL OR SERIES WIRING HARNESS?  Empty
PostSubject: BRAIN FART, PARALLEL OR SERIES WIRING HARNESS?    BRAIN FART, PARALLEL OR SERIES WIRING HARNESS?  EmptySat Jun 06, 2015 12:37 am
I'm having a senior moment....
I want to make up a wiring harness for the springer using 2x 12v 3.4Ah battery's, but i can't remember if its a series harness or a parallel i need to give me an output of 12v 6.6Ah..
Any diagrams of which i need and or both (to help others if they need the latter) would be appreciated..
PostSubject: Re: BRAIN FART, PARALLEL OR SERIES WIRING HARNESS?    BRAIN FART, PARALLEL OR SERIES WIRING HARNESS?  EmptySat Jun 06, 2015 2:09 am
oOk never mind found the answer on ''oggle''
 Series connection = gives you twice the voltage @ the same Ah
BRAIN FART, PARALLEL OR SERIES WIRING HARNESS?  Serise10
 Parallel connection = gives you twice the Ah @ same voltage
BRAIN FART, PARALLEL OR SERIES WIRING HARNESS?  Parall10
» WIRING LED's
» Nearly 75 newbie
