 its my RESCUE DINGHIE...
krishna34
krishna34
its my RESCUE DINGHIE...  Empty
PostSubject: its my RESCUE DINGHIE...    its my RESCUE DINGHIE...  EmptyMon Jun 22, 2015 10:32 am
based on my Lake Cat hull.. so easy work.. and from things around me.. the boat is 17 inches long and 7 inches wide.. just used rubber foam tube around the hull, is actually 1 inch thick foam tubing for covering the split AC tube.. and applied white glue to avoid any damage in contact with PU and NC paints.. the engine is acting as a rudder, as the prop is driven by in built motor.. powered by a low profile brush less motor she is so responsive and fast..
PostSubject: Re: its my RESCUE DINGHIE...    its my RESCUE DINGHIE...  EmptyMon Jun 22, 2015 10:22 pm
If your having issues posting photos, please read the guide how to do this here.
https://www.thercmodelboatforum.com/t39-uploading-photo-s-tutorial
krishna34
krishna34
PostSubject: Re: its my RESCUE DINGHIE...    its my RESCUE DINGHIE...  EmptyTue Jun 23, 2015 4:38 am
sure.. and already tried.. but hope due to my slow home connection.. still trying.. thank you..
krishna34
krishna34
PostSubject: Re: its my RESCUE DINGHIE...    its my RESCUE DINGHIE...  EmptyTue Jun 23, 2015 4:48 am
follows..
its my RESCUE DINGHIE...  2512
its my RESCUE DINGHIE...  2610
krishna34
krishna34
PostSubject: Re: its my RESCUE DINGHIE...    its my RESCUE DINGHIE...  EmptyTue Jun 23, 2015 4:54 am
its ok now.. working fine..
its my RESCUE DINGHIE...  2710
its my RESCUE DINGHIE...  2910
its my RESCUE DINGHIE...  2810
its my RESCUE DINGHIE...  3010
krishna34
krishna34
PostSubject: Re: its my RESCUE DINGHIE...    its my RESCUE DINGHIE...  EmptyTue Jun 23, 2015 5:03 am
the construction is so simple and easy.. its based on my simple design, for kids.. by using foam board, its so light and reliable..
its my RESCUE DINGHIE...  110
its my RESCUE DINGHIE...  210
its my RESCUE DINGHIE...  310
its my RESCUE DINGHIE...  410
its my RESCUE DINGHIE...  510
its my RESCUE DINGHIE...  610
its my RESCUE DINGHIE...  710
its my RESCUE DINGHIE...  810
its my RESCUE DINGHIE...  910
its my RESCUE DINGHIE...  1010
krishna34
krishna34
PostSubject: Re: its my RESCUE DINGHIE...    its my RESCUE DINGHIE...  EmptyTue Jun 23, 2015 5:12 am
on..
its my RESCUE DINGHIE...  1110
its my RESCUE DINGHIE...  1210
its my RESCUE DINGHIE...  1310
its my RESCUE DINGHIE...  1410
its my RESCUE DINGHIE...  1510
its my RESCUE DINGHIE...  1610
its my RESCUE DINGHIE...  1810
its my RESCUE DINGHIE...  1910
its my RESCUE DINGHIE...  2010
its my RESCUE DINGHIE...  2110
its my RESCUE DINGHIE...  2210
its my RESCUE DINGHIE...  2310
its my RESCUE DINGHIE...  2410
krishna34
krishna34
PostSubject: Re: its my RESCUE DINGHIE...    its my RESCUE DINGHIE...  EmptyTue Jun 23, 2015 5:17 am
see her in action..
https://www.youtube.com/watch?v=7CyFtTDeUbg
» r.n.l.i rescue child
» Raf Rescue Launch ST 1502
» Model Slipway Rescue Boat
