 Rhyl Mersey Class Lifeboat
Beyno1968
Ramsey
Just add water
battleshipbuff
zetec
gribeauval
14 posters
Go to page : Previous  1, 2, 3, 4  Next
gribeauval
gribeauval
Rhyl Mersey Class Lifeboat - Page 3 Empty
PostSubject: Re: Rhyl Mersey Class Lifeboat   Rhyl Mersey Class Lifeboat - Page 3 EmptyMon May 09, 2016 9:29 pm
Made a start on the deck fittings today beginning with the towing gobeye for the stern.
This is made from laminated styrene and the removable H section brazed from steel rod.
Rhyl Mersey Class Lifeboat - Page 3 Hull-154_zpsnxvh08z3
Rhyl Mersey Class Lifeboat - Page 3 Hull-155_zpsqa4psw5m
Rhyl Mersey Class Lifeboat - Page 3 Hull-156_zpshi0ke9mt
Kick  boards for the stanchions next.
gribeauval
gribeauval
PostSubject: Re: Rhyl Mersey Class Lifeboat   Rhyl Mersey Class Lifeboat - Page 3 EmptyWed May 11, 2016 8:08 pm
The kick boards for the stanchions on a Mersey are an inverted 'T' section bonded to the deck This is not easy to find so I have made it myself.
First the positions for the boards was plotted and a slot cut into the deck using mini router with a 3mm straight cutter.
Rhyl Mersey Class Lifeboat - Page 3 Hull-157_zps9weqwtu5
Oversize pieces of 3mm ply were cut and glued into the slots followed by the horizontal parts fixed onto the deck and the upright. This gives a strong fixing into the deck for the stanchions.
Rhyl Mersey Class Lifeboat - Page 3 Hull-158_zpsy5s4h9zf
When fully cured the upright was trimmed down to the correct size, primed and will later be given a coat of the correct grey.
Rhyl Mersey Class Lifeboat - Page 3 Hull-159_zps36ummrms
The deck can now be given its coat of anti slip paint.
gribeauval
gribeauval
PostSubject: Re: Rhyl Mersey Class Lifeboat   Rhyl Mersey Class Lifeboat - Page 3 EmptyFri May 13, 2016 8:51 pm
As the weather has been fine over the past couple of days I masked off the hull and prepared to spray the deck.
Rhyl Mersey Class Lifeboat - Page 3 Hull-160_zpsw4ywupfu
This is the paint I use from my local branch of B&Q.
Rhyl Mersey Class Lifeboat - Page 3 Hull-161_zpsvedyvwkh
After spraying the deck looks a mess but as it dries it smooths out to a much better finish.
Rhyl Mersey Class Lifeboat - Page 3 Hull-162_zpsscxk3tsa
When the deck had dries and the masking removed the hull was given its RNLI corporate identity, yellow over red stripes, Hull fleet number, draught marks and at the stern the station name.
Rhyl Mersey Class Lifeboat - Page 3 Hull-163_zpsbhq93tqt
Rhyl Mersey Class Lifeboat - Page 3 Hull-164_zpsanalbewc
battleshipbuff
PostSubject: Rhyl Mersey   Rhyl Mersey Class Lifeboat - Page 3 EmptyFri May 13, 2016 9:37 pm
Cracking on at a good rate now Mike. Superb finish as always.
If you are down at Torbay in August for Lifeboat week I hope we can meet up.
PostSubject: Re: Rhyl Mersey Class Lifeboat   Rhyl Mersey Class Lifeboat - Page 3 EmptySat May 14, 2016 8:24 am
Nice work and she's looking really good   2thumbsup
gribeauval
gribeauval
PostSubject: Re: Rhyl Mersey Class Lifeboat   Rhyl Mersey Class Lifeboat - Page 3 EmptyThu May 19, 2016 11:49 am
More of the details added.
The towing gobeye has been fixed  in place and the metal fender protector added.
Rhyl Mersey Class Lifeboat - Page 3 Hull-165_zpsc0xfjo7f
The lifting lugs made and fixed onto the deck.
Rhyl Mersey Class Lifeboat - Page 3 Hull-166_zpsrcq45a1y
The chain releases made and fitted onto the deck.
Rhyl Mersey Class Lifeboat - Page 3 Hull-167_zpsac60idmg
The closed fairleads painted and fitted onto the kick boards.
Rhyl Mersey Class Lifeboat - Page 3 Hull-168_zpsxlo7tbgu
The hammers for the chain release made and fitted.
Rhyl Mersey Class Lifeboat - Page 3 Hull-169_zpsdc09hkki
Upper steering position painted matt black and the working compass fitted.
Rhyl Mersey Class Lifeboat - Page 3 Hull-170_zpsz7czzxlr
The towing post and mooring bitt made along with the reinforcing blocks for under the deck.
Rhyl Mersey Class Lifeboat - Page 3 Hull-171_zpsjegzx3ce
Painted and fitted onto the deck.
Rhyl Mersey Class Lifeboat - Page 3 Hull-172_zps53uwvoyy
Rhyl Mersey Class Lifeboat - Page 3 Hull-173_zpsbtng8l3s
First part of the stern rails made from steel welding rod, just need to make the matching starboard section next.
Rhyl Mersey Class Lifeboat - Page 3 Hull-174_zps1l9cjocp
Rails made, painted and fixed in place.
Rhyl Mersey Class Lifeboat - Page 3 Hull-175_zpsgykb9e0d
PostSubject: Re: Rhyl Mersey Class Lifeboat   Rhyl Mersey Class Lifeboat - Page 3 EmptyFri May 20, 2016 2:07 am
Superb Craftsmanship Mike 2thumbsup 2thumbsup 2thumbsup 2thumbsup 2thumbsup 2thumbsup 2thumbsup 2thumbsup 2thumbsup 2thumbsup
PostSubject: Re: Rhyl Mersey Class Lifeboat   Rhyl Mersey Class Lifeboat - Page 3 EmptyFri May 20, 2016 7:32 am
Ditto Damiens comment, nice detailing 2thumbsup 2thumbsup
gribeauval
gribeauval
PostSubject: Re: Rhyl Mersey Class Lifeboat   Rhyl Mersey Class Lifeboat - Page 3 EmptyFri May 20, 2016 8:22 pm
More deck fittings made.
The capstan on the fore deck was made from turned beech and styrene sheet.
Rhyl Mersey Class Lifeboat - Page 3 Hull-176_zpsew4xupcg
Painted and ready to fit.
Rhyl Mersey Class Lifeboat - Page 3 Hull-177_zpshstw6xfa
Mersey class lifeboats are recovered by driving onto the beach and hauling up with the aid of recovery strops fixed to the boat. When not in use the strops are held in place on the bow by an overcentre fitting.
Rhyl Mersey Class Lifeboat - Page 3 Hull-178_zpsr00jnfz8
The fittings fixed in place on the fore deck.
Rhyl Mersey Class Lifeboat - Page 3 Hull-179_zpsqjjjur5u
The strops themselves are bolted through the keel and pass up the stem, guided by small plates into the bow groove.
Rhyl Mersey Class Lifeboat - Page 3 Hull-180_zpsnjrtp49m
Rhyl Mersey Class Lifeboat - Page 3 Hull-181_zpsxw73mmgo
The free ends are held in the over centre fitting.
Rhyl Mersey Class Lifeboat - Page 3 Hull-182_zpswi9xkj8v
Before anybody asks, yes it does work!!
Rhyl Mersey Class Lifeboat - Page 3 Hull-183_zpsaqkiggnl
Just add water
Just add water
PostSubject: Re: Rhyl Mersey Class Lifeboat   Rhyl Mersey Class Lifeboat - Page 3 EmptySat May 21, 2016 5:21 pm
I have been watching this build and I think this is true craftsmanship in every sense of the meaning!
97 out of Ten  2thumbsup 2thumbsup 2thumbsup 2thumbsup 2thumbsup 2thumbsup 2thumbsup 2thumbsup 2thumbsup 2thumbsup 2thumbsup 2thumbsup 2thumbsup 2thumbsup 2thumbsup Shocked Shocked Shocked Shocked Shocked Shocked Shocked Shocked Shocked
Bernie.
gribeauval
gribeauval
PostSubject: Re: Rhyl Mersey Class Lifeboat   Rhyl Mersey Class Lifeboat - Page 3 EmptyMon May 23, 2016 8:55 pm
More bits done.
The metal support and lifeline at the front of the superstructure has been made and fixed in place.
Rhyl Mersey Class Lifeboat - Page 3 Hull-184_zpsl9br4ipt
The fender protection plates at the bow have been fitted and the bow roller made.
Rhyl Mersey Class Lifeboat - Page 3 Hull-185_zps99mpfwrw
This is hinged to allow the recovery strops to be deployed/recovered and is operated by removing the locking pin.
Rhyl Mersey Class Lifeboat - Page 3 Hull-186_zpsqtxhk8io
The upper helm position has been fitted out with throttles, instruments and switches.
Rhyl Mersey Class Lifeboat - Page 3 Hull-187_zpsqzegmsyb
Finally for now here is a small duck board I made today.
Rhyl Mersey Class Lifeboat - Page 3 Hull-188_zps2siidbnu
This is where it lives on the upper helm position.
Rhyl Mersey Class Lifeboat - Page 3 Hull-189_zpsw0mgikk8
Soon be time to refit the mast!
battleshipbuff
PostSubject: Rhyll Mersey   Rhyl Mersey Class Lifeboat - Page 3 EmptyMon May 23, 2016 9:11 pm
Absolutely wonderful build.The minute detailing,and the way you utilise materials is amazing.
Great Stuff Mike,
Sincerely,
Mick
Just add water
Just add water
PostSubject: Re: Rhyl Mersey Class Lifeboat   Rhyl Mersey Class Lifeboat - Page 3 EmptyTue May 24, 2016 4:52 pm
I like the compass 2thumbsup
Just add water
Just add water
PostSubject: Re: Rhyl Mersey Class Lifeboat   Rhyl Mersey Class Lifeboat - Page 3 EmptyTue May 24, 2016 4:54 pm
Excellent cant wait to see the end result 2thumbsup 2thumbsup 2thumbsup 2thumbsup 2thumbsup 2thumbsup 2thumbsup 2thumbsup 2thumbsup 2thumbsup 2thumbsup 2thumbsup
PostSubject: Re: Rhyl Mersey Class Lifeboat   Rhyl Mersey Class Lifeboat - Page 3 EmptyWed May 25, 2016 4:38 pm
trouble is.....mike as a tendency not to finish his Mersey's' lol........he's got one big enough to sit in and steer it sat in his back garden that we are ALL  waiting to see.....so come on mike.........stop playing with teensy weensy ones and get the biggun done, lol lol! lol! 2thumbsup 2thumbsup 2thumbsup
gribeauval
gribeauval
PostSubject: Re: Rhyl Mersey Class Lifeboat   Rhyl Mersey Class Lifeboat - Page 3 EmptyWed May 25, 2016 4:49 pm
Thank you for your comments guys, much appreciated. Thumbup
This one has to be finished Neil,   'cos it's not mine!!!
I have many other boats to build for other people I never get chance to build my own. I have a Waveney, Severn, Shannon, Brede and a Tamar of my own waiting to be done. Plus I have done the research and, with my son, produced hull lines in Freeship for the 64ft Fast lifeboat (a one off) they had in Dover in the 1930's AND sorted out the drawings for the steam lifeboat the Duke of Northumberland (to be turbine jet driven) and the contra rotating props on a single shaft version!! Shocked
PostSubject: Re: Rhyl Mersey Class Lifeboat   Rhyl Mersey Class Lifeboat - Page 3 EmptyWed May 25, 2016 6:18 pm
you do live up to your tag matey, lol..............just get building and put a bed in your workshop si you can build in yr sleep..........no slacking now.... lol! lol! lol!
gribeauval
gribeauval
PostSubject: Re: Rhyl Mersey Class Lifeboat   Rhyl Mersey Class Lifeboat - Page 3 EmptyThu May 26, 2016 9:33 pm
last day's work until after the Bank Holiday. 2thumbsup
The loudspeaker and the control box made and fitted onto the rails at the front of the wheelhouse.
Rhyl Mersey Class Lifeboat - Page 3 Hull-190_zpsm7v0uqz0
The horn made and fitted onto its hanger on the rail. This slides forward on the rail to release the wheelhouse when it needs to be removed.
Rhyl Mersey Class Lifeboat - Page 3 Hull-191_zpsanbhs6tl
The grab rails along the roof edge were made and fitted in place.
Rhyl Mersey Class Lifeboat - Page 3 Hull-192_zpsq0nik61k
Searching through the spares boxes produced handrail stanchions, M2 nuts and bolts and small electrical ring terminals...........
Rhyl Mersey Class Lifeboat - Page 3 Hull-193_zpskwr6qtx3
produces the folding aerial bases for the wheelhouse roof.
Rhyl Mersey Class Lifeboat - Page 3 Hull-194_zps6uttsmhg
Add wires etc and you have the aerials (still have a few more to make).
Rhyl Mersey Class Lifeboat - Page 3 Hull-195_zpsdpkeqlb8
These will be painted and fitted after the Bank holiday as I am going to East Anglia to visit the full size Thames Class lifeboat  50-001 on Saturday. 2thumbsup 2thumbsup 2thumbsup
PostSubject: Re: Rhyl Mersey Class Lifeboat   Rhyl Mersey Class Lifeboat - Page 3 EmptySat May 28, 2016 11:47 am
gribeauval
gribeauval
PostSubject: Re: Rhyl Mersey Class Lifeboat   Rhyl Mersey Class Lifeboat - Page 3 EmptyThu Jun 02, 2016 11:47 am
Short break over so back to work!
The rest of the aerials for the roof have been finished, painted and fitted in place on the wheelhouse along with their associated wiring plugs.
Rhyl Mersey Class Lifeboat - Page 3 Hull-196_zpswfml7pvg
Plus they all fold down as on the full size boat.
Rhyl Mersey Class Lifeboat - Page 3 Hull-197_zpspwawesmv
The emergency transmitter aerial has also been made and fitted on the forward casing.
Rhyl Mersey Class Lifeboat - Page 3 Hull-198_zpsnc1egixg
gribeauval
gribeauval
PostSubject: Re: Rhyl Mersey Class Lifeboat   Rhyl Mersey Class Lifeboat - Page 3 EmptySun Jun 05, 2016 9:06 pm
Spent yesterday at the Doncaster Model Boat Show buying parts and talking to old friends so today I have only made the Bantex aerials that fit on each side of the wheelhouse.
These areials are hinged as on the full size boat so that they can be lowered when the boat is housed. The piece of toothpick at the pivot is a temporary measure!
Rhyl Mersey Class Lifeboat - Page 3 Hull-199_zpsmn9szv35
The mast was temporarily refitted to allow the support struts to be cut to length.
Rhyl Mersey Class Lifeboat - Page 3 Hull-200_zpsyjtwikwz
View from the bow, just need to paint the struts.
Rhyl Mersey Class Lifeboat - Page 3 Hull-201_zpskvs8mlhn
PostSubject: Re: Rhyl Mersey Class Lifeboat   Rhyl Mersey Class Lifeboat - Page 3 EmptyMon Jun 06, 2016 12:17 am
Top notch detailing work  2thumbsup
gribeauval
gribeauval
PostSubject: Re: Rhyl Mersey Class Lifeboat   Rhyl Mersey Class Lifeboat - Page 3 EmptyTue Jun 07, 2016 7:56 pm
The window frames on the port side of the wheelhouse have now been painted and the glazing fixed in place. The rest will be done tomorrow. The filters on the side air intakes are also now in place.
Rhyl Mersey Class Lifeboat - Page 3 Hull-202_zps3rrktvg9
Most of today has been taken up with 'playing about' with Photoshop. This has produced the dedication plate for the Mersey.
Screen shot of the layers needed to make the plate.
Rhyl Mersey Class Lifeboat - Page 3 Name-plate-01_zpssy3od80t
Printed out at the size needed for the model on high quality photo paper.
Rhyl Mersey Class Lifeboat - Page 3 Hull-203_zpsutkxt9ka
Plate in position under the port side aerial. With minor magnification it is readable. 2thumbsup
Rhyl Mersey Class Lifeboat - Page 3 Hull-204_zpsl80zcuar
PostSubject: Re: Rhyl Mersey Class Lifeboat   Rhyl Mersey Class Lifeboat - Page 3 EmptyTue Jun 07, 2016 10:55 pm
2thumbsup nice touch on the dedication  2thumbsup
PostSubject: Re: Rhyl Mersey Class Lifeboat   Rhyl Mersey Class Lifeboat - Page 3 EmptyWed Jun 08, 2016 3:16 am
Indeed a nice touch Mike.  2thumbsup 2thumbsup 2thumbsup 2thumbsup 2thumbsup 2thumbsup
gribeauval
gribeauval
PostSubject: Re: Rhyl Mersey Class Lifeboat   Rhyl Mersey Class Lifeboat - Page 3 EmptyWed Jun 08, 2016 11:16 am
 Thanks guys. 2thumbsup
The crew at Rhyl are very proud of this dedication and keep the plate well polished.
Mike
PostSubject: Re: Rhyl Mersey Class Lifeboat   Rhyl Mersey Class Lifeboat - Page 3 EmptyWed Jun 08, 2016 11:53 am
Talking on polishing the dedication plaque, do you have the ability to acid etch at that size??
it may be worth looking into if you do another, meaning you could etch the lettering from brass sheet and coat the letters in black paint, once polished it would be even more outstanding!
of course it may not be possible given the size but its an idea
gribeauval
gribeauval
PostSubject: Re: Rhyl Mersey Class Lifeboat   Rhyl Mersey Class Lifeboat - Page 3 EmptyWed Jun 08, 2016 3:12 pm
Short answer ..... No.
The majority of the letters are only 0.5 mm tall, just possible with my hi res photo printer.
It would be possible with a laser but I can't afford one of them!!
gribeauval
gribeauval
PostSubject: Re: Rhyl Mersey Class Lifeboat   Rhyl Mersey Class Lifeboat - Page 3 EmptySun Jun 12, 2016 4:54 pm
The grab lines on each side of the hull have been fitted in place.
Rhyl Mersey Class Lifeboat - Page 3 Hull-205_zpsabspocip
The wiper boxes and wipers have been made and fitted over the front windows.
Rhyl Mersey Class Lifeboat - Page 3 Hull-206_zpsh1snjai8
The stanchions have had their support bars soldered in place where needed, painted and fixed onto the toe boards.
Rhyl Mersey Class Lifeboat - Page 3 Hull-207_zpslkp4tf6j
PostSubject: Re: Rhyl Mersey Class Lifeboat   Rhyl Mersey Class Lifeboat - Page 3 EmptySun Jun 12, 2016 11:33 pm
Excellent attention to detail. very impressed with the craftsman ship, but you must almost be done right?!
gribeauval
gribeauval
PostSubject: Re: Rhyl Mersey Class Lifeboat   Rhyl Mersey Class Lifeboat - Page 3 EmptySun Jun 12, 2016 11:53 pm
I wish!!!!
Still got to make the anchors, some deck fittings, safety lines, ram guards, liferings and holders, drogue and holder, refit the mast and join up all the wiring then refit the shafts, motors, rudders, r/c and sound system(when it arrives) plus other bits I can't think of at the moment.  lol! lol! lol!
PostSubject: Re: Rhyl Mersey Class Lifeboat   Rhyl Mersey Class Lifeboat - Page 3 EmptyMon Jun 13, 2016 1:27 am
lol you youngsters and all your fandangled toys  alien jocolor Laughing Laughing Rolling Eyes What a Face What a Face Suspect pirat
gribeauval
gribeauval
PostSubject: Re: Rhyl Mersey Class Lifeboat   Rhyl Mersey Class Lifeboat - Page 3 EmptyTue Jun 14, 2016 9:36 pm
More bits done.
The life rings and their holders have been made, painted and, when the paint hardens off, the small details will be added and then they will be fitted on the stern rails
Rhyl Mersey Class Lifeboat - Page 3 Hull-208_zpsxasbj4lu
I have also made the drogue, in its cover, and the holder and again when dry will be fixed to the rails at the rear of the wheelhouse just behind the helsman and to the starboard sde of the mast.
Rhyl Mersey Class Lifeboat - Page 3 Hull-209_zps5eesbsek
PostSubject: Re: Rhyl Mersey Class Lifeboat   Rhyl Mersey Class Lifeboat - Page 3 EmptyWed Jun 15, 2016 6:17 pm
it's an award winner is this one mike.........just beautiful matey.
gribeauval
gribeauval
PostSubject: Re: Rhyl Mersey Class Lifeboat   Rhyl Mersey Class Lifeboat - Page 3 EmptyWed Jun 15, 2016 7:09 pm
Thanks Neil, but I can see too many faults that need re-doing but don't have the time as delivery date looms!!
By the way do you have any of the plough anchors for the Mersey left ?? I need a couple to save me time buildimg them. Thumbup
Mike
gribeauval
gribeauval
PostSubject: Re: Rhyl Mersey Class Lifeboat   Rhyl Mersey Class Lifeboat - Page 3 EmptyFri Jun 17, 2016 3:20 pm
The life rings have been fitted onto the holders and the details added.
Rhyl Mersey Class Lifeboat - Page 3 Hull-210_zps8tftew6w
Now fitted onto the stern rails.
Rhyl Mersey Class Lifeboat - Page 3 Hull-211_zpsiwydnwzt
The drogue and holder fixed onto the wheelhouse stern rails.
Rhyl Mersey Class Lifeboat - Page 3 Hull-212_zpszesedxvz
PostSubject: Re: Rhyl Mersey Class Lifeboat   Rhyl Mersey Class Lifeboat - Page 3 EmptySat Jun 18, 2016 2:55 am
2thumbsup 2thumbsup 2thumbsup 2thumbsup 2thumbsup 2thumbsup 2thumbsup 2thumbsup 2thumbsup 2thumbsup 2thumbsup 2thumbsup 2thumbsup 2thumbsup 2thumbsup 2thumbsup 2thumbsup 2thumbsup 2thumbsup
Thumbup Thumbup Thumbup Thumbup Thumbup Thumbup Thumbup Thumbup Thumbup Thumbup Thumbup Thumbup Thumbup Thumbup Thumbup Thumbup Thumbup Thumbup Thumbup Thumbup Thumbup Thumbup Thumbup
        2thumbsup
PostSubject: Re: Rhyl Mersey Class Lifeboat   Rhyl Mersey Class Lifeboat - Page 3 EmptySat Jun 18, 2016 7:30 pm
Mike
yes mate....send me your address and i'll put a couple in the post for you.
gribeauval
gribeauval
PostSubject: Re: Rhyl Mersey Class Lifeboat   Rhyl Mersey Class Lifeboat - Page 3 EmptySat Jun 18, 2016 10:31 pm
Mike
email sent 2thumbsup 2thumbsup 2thumbsup
gribeauval
gribeauval
PostSubject: Re: Rhyl Mersey Class Lifeboat   Rhyl Mersey Class Lifeboat - Page 3 EmptyThu Jun 23, 2016 7:40 pm
The distinctive quarter bollards of the Mersey have been made and painted.
Rhyl Mersey Class Lifeboat - Page 3 Hull-213_zpstuxev540
Now in position along the stern with the mooring bitts just behind them along the side toe boards. I have also fitted the exhausts made earlier. The trim tab ram guards have also been added.
Rhyl Mersey Class Lifeboat - Page 3 Hull-214_zpstx0hpikt
The liferaft container made and fitted under the upper steering position.
Rhyl Mersey Class Lifeboat - Page 3 Hull-215_zpss7dvdddc
The radio installation for the helmsman has been completed.
Rhyl Mersey Class Lifeboat - Page 3 Hull-216_zpsvj0snefd
The hinged safety rail made and fitted in place.
Rhyl Mersey Class Lifeboat - Page 3 Hull-217_zpsrvp747bx
At the bow the anchors (basic casting from Neil) have been detailed and fitted in place.
Rhyl Mersey Class Lifeboat - Page 3 Hull-219_zpsst4m3etf
On the sides of the wheelhouse the safety wire has been added, the fire hydrant fitted into its recess, the deck lights added, the fuel fillers made and placed behind their slotted covers.
Rhyl Mersey Class Lifeboat - Page 3 Hull-220_zps4ndpgczt
PostSubject: Re: Rhyl Mersey Class Lifeboat   Rhyl Mersey Class Lifeboat - Page 3 EmptyFri Jun 24, 2016 8:47 am
I like your detailing, would it be possible to see some photo shots of the making of some of the small components please, it would really help some of us that are not so proficient or new to the hobby. Smile
gribeauval
gribeauval
PostSubject: Re: Rhyl Mersey Class Lifeboat   Rhyl Mersey Class Lifeboat - Page 3 EmptyFri Jun 24, 2016 8:51 pm
Check out this thread Thumbup :             Hatch handles
PostSubject: Re: Rhyl Mersey Class Lifeboat   Rhyl Mersey Class Lifeboat - Page 3 EmptySun Jun 26, 2016 9:01 am
Thanks for helping us new folk with these tips, I'm sure it will help a lot of us 2thumbsup .
gribeauval
gribeauval
PostSubject: Re: Rhyl Mersey Class Lifeboat   Rhyl Mersey Class Lifeboat - Page 3 EmptySun Jun 26, 2016 8:11 pm
The main cabin access door made earlier has been detailed and hinged in place.
Rhyl Mersey Class Lifeboat - Page 3 Hull-221_zpsifvqvkqk
The mast has been finally fitted in position and all the wiring wrestled in place underneath the wheelhouse and is ready to connect up to the switches at the front.
Rhyl Mersey Class Lifeboat - Page 3 Hull-222_zpsbnbtrplw
Finally for now, this afternoon, the boat received its name plates.
Rhyl Mersey Class Lifeboat - Page 3 Hull-223_zpsimpx0gum
gribeauval
gribeauval
PostSubject: Re: Rhyl Mersey Class Lifeboat   Rhyl Mersey Class Lifeboat - Page 3 EmptyMon Jun 27, 2016 8:47 pm
Spent today finishing off the wiring of the function switches at the front of the wheelhouse.
Rhyl Mersey Class Lifeboat - Page 3 Hull-224_zpsel4gtzge
Also started fitting the control system into the hull. The esc is a twin/mixer P94, a three way distribution board ( both by Action Electronics) and their newest baby. a P110 Mk2 sound system, this is so new it isn't even in the catalogue yet! It is very simple to fit, has twin sound inputs/outputs for the throttles, up to 16 other available sounds as well as the full engine start/run/stop sequence, built in amplifier and runs on any voltage between 12v and 24v. In this installation the unit at the bottom right corner takes the 7.2v from the board and ramps it up to 12v for the sound system.
Rhyl Mersey Class Lifeboat - Page 3 Hull-225_zps7ycelllt
Short clip of the initial run sound set up. This will be refined/tuned to the transmitter to be used when it is all in place.
PostSubject: Re: Rhyl Mersey Class Lifeboat   Rhyl Mersey Class Lifeboat - Page 3 EmptyMon Jun 27, 2016 9:25 pm
spot on  2thumbsup 2thumbsup 2thumbsup
PostSubject: Re: Rhyl Mersey Class Lifeboat   Rhyl Mersey Class Lifeboat - Page 3 EmptyTue Jun 28, 2016 12:38 am
Spot on indeed.   2thumbsup 2thumbsup 2thumbsup 2thumbsup
PostSubject: Re: Rhyl Mersey Class Lifeboat   Rhyl Mersey Class Lifeboat - Page 3 EmptyTue Jun 28, 2016 7:20 am
Ditto the above 2thumbsup 2thumbsup
gribeauval
gribeauval
PostSubject: Re: Rhyl Mersey Class Lifeboat   Rhyl Mersey Class Lifeboat - Page 3 EmptyThu Jun 30, 2016 11:25 pm
The Mersey is complete!!, well as much as I intend doing lol! lol! lol!
Ckecked out in the test tank this afternoon between showers. It sits well, goes as it should and doesn't leak!
Rhyl Mersey Class Lifeboat - Page 3 Hull-226_zpsotdpe5st
Rhyl Mersey Class Lifeboat - Page 3 Hull-227_zpsglab7vdh
All the lighting circuits tested late this evening.
Rhyl Mersey Class Lifeboat - Page 3 Hull-228_zpsxoy5kmqe
Rhyl Mersey Class Lifeboat - Page 3 Hull-229_zpsbm7r4ati
Rhyl Mersey Class Lifeboat - Page 3 Hull-230_zpstiaj0ray
Short clip with the lights, including the flashing blue light, and radar. The interior has the red night lights on.
Client collects the boat tomorrow.
PostSubject: Re: Rhyl Mersey Class Lifeboat   Rhyl Mersey Class Lifeboat - Page 3 EmptyThu Jun 30, 2016 11:57 pm
Absolutely smashing build bud, many congratulations on another superb build, thanks for sharing it with us!
I'm sure i speak for everyone when i say were looking forward to your next project!
2thumbsup 2thumbsup 2thumbsup 2thumbsup 2thumbsup 2thumbsup 2thumbsup 2thumbsup 2thumbsup 2thumbsup 2thumbsup 2thumbsup 2thumbsup 2thumbsup 2thumbsup 2thumbsup 2thumbsup 2thumbsup 2thumbsup 2thumbsup
Page 3 of 4Go to page : Previous  1, 2, 3, 4  Next
»  OAKLEY LIFEBOAT HAR - LIL Rhyl lifeboat
» Rowing Lifeboat and Surf class Lifeboat
» My Mersey Lifeboat etc
» Mersey class 1/12 scale
» 50 ft Thames class lifeboat
