 Magnetic Clamps
Magnetic Clamps Empty
PostSubject: Magnetic Clamps   Magnetic Clamps EmptyFri Jan 08, 2016 8:27 am
While perusing ebay the other day I came across some Neodymium block rare earth magnets, I hadn't a clue these even existed and it gave me an idea. I remembered seeing the magnetic clamps that Barrie has and after seeing the price of these clamps I could not resist the challenge, I just had to have a go at making some.
I bought some 20mm x 10mm x 5mm magnets at approx. £1.40p each and a 200mm x 200mm piece of 10mm Acrylic sheet, cost about £6.
Magnetic Clamps SAM_2338_zps9mntw24u
I used my new Proxxon table saw to cut some bits of Acrylic sheet to the desired size (only made one fopaux).And set a magnets in two to start with, more to follow.
Magnetic Clamps SAM_2343_zpsbvg41jve
Here are the resulting first pair 2thumbsup
Magnetic Clamps SAM_2339_zpsqbsiprct
Magnetic Clamps SAM_2341_zpsryfqd9pf
Magnetic Clamps SAM_2342_zpsqm5oj7rv
PostSubject: Re: Magnetic Clamps   Magnetic Clamps EmptyFri Jan 08, 2016 9:04 am
Very Nice Thumbup They look to be a  bit bigger than the ones I bought, which will be better for boat building. Mine were designed for model railways and are not always big enough to handle boat size structures.
I do have some very ferocious magnets - might have a go at making some.
PostSubject: Re: Magnetic Clamps   Magnetic Clamps EmptyFri Jan 08, 2016 9:30 am
Hi Barrie, on the York Modelmaking site they do quite a few different types and sizes I am going to make some variations on this one as well. Your clamps are I think just over 30mm mine are about 45mm.
I got the Acrylic sheet from ebay but you could always use wood, but they wouldn't be as tough though.
Yes have a go, it's just a bit time consuming but I think worth it for the satisfaction I got from making them. If you do make some would you post some pictures on this thread please.
PostSubject: Re: Magnetic Clamps   Magnetic Clamps EmptyFri Jan 08, 2016 9:53 am
Yes - I notice they now list different sizes, but they are expensive. When I bought mine they just had the two types. Its not top of my priority list, but I may get round to making some - it would use the magnets I bought for hatch fixings but are way too powerful for that.
PostSubject: Re: Magnetic Clamps   Magnetic Clamps EmptyFri Jan 08, 2016 2:44 pm
Paul,
OK - having said it wasn't top of the list, here is my version. I have started planking my hull, so lots of waiting for glue to dry - I'm using aliphatic at the moment, though may switch to CA.
These are made from 4 pieces of 1.5mm plasticard. Each side is 4mm. The two inner layers have a hole cut to accommodate the magnet. Not as neat as the acrylic  but cheaper - these were from the scrap box Thumbup
The photo includes one of the magnets. To give an idea of the strength, when I was returning one to the stack of 5, it slipped and the force of attraction was sufficient to crack it in half.
PostSubject: Re: Magnetic Clamps   Magnetic Clamps EmptyFri Jan 08, 2016 6:35 pm
They are awkward little B's, they have a tendency to fly at anything made of steel, it does say in the leaflet they shatter if they hit each other.
Yes your idea is probably a lot quicker to make, I hadn't thought of alternative materials but now you have me thinking, thanks. 2thumbsup
Magnetic Clamps
