Finally decided to get off my Whoopsie Daisies and do something to the ferry and the first job I have to do before anything else now is to get the VSU's fitted........how the **** do I do it.
got the base rings in and sealed but it goes on about the sealant and I haven't got a bloody clue as to where it goes in the seating.......anyone with any ideas from fitting their own either pics or diagrammed sketch would be appreciated.
below is what it says on the translated instructions.
Mounting the VOITH-SCHNEIDER drive unit in the model boat The first step is to cut a circular 84 mm hole in the bottom of the boat, into which the plastic mounting ring is glued.
Mould the gasket material supplied 5 mm and using your hands then place it on the sealing surface of the mounting ring; it should be located outside the screws. press the gasket material into the corner of the 1'5mm recess and press home the VPSU."
cheers guys. neil.
