 wont turn left
goldslinger
goldslinger
wont turn left Empty
PostSubject: wont turn left   wont turn left EmptyMon Oct 10, 2016 4:48 pm
hi all my air boat wont turn left but will turn right on a six pence
both rudders have independent servos but the servos are matched and run off a y lead to one servo control
both rudders move left and right the same amount
i am running a pusher prop which rotates anti clockwise
any one got any idea's
PostSubject: Re: wont turn left   wont turn left EmptyFri Oct 14, 2016 3:23 pm
It's to do with the rotation of the prop, the prop is aiding in the right turn but defeating the left, similar to prop walk on a boat. Only way to correct this issue is larger rudders, or increase the rudder throw so left becomes more responsive.
PostSubject: Re: wont turn left   wont turn left EmptyFri Oct 14, 2016 3:25 pm
On a side note a single central rudder would work better and directing air throw, or setting up larger rudders to the outer edgers of the blade creating a funnel effect allowing the thrust to be directed better.
goldslinger
goldslinger
PostSubject: Re: wont turn left   wont turn left EmptyFri Oct 14, 2016 4:20 pm
thanks for that it had me puzzeld
i will fit some bigger rudders on it this week end
at the moment the throw on both rudders in either direction is about 40degs
so i will have to reduce the right turn a little
thanks Very Happy
goldslinger
goldslinger
PostSubject: Re: wont turn left   wont turn left EmptyTue Oct 25, 2016 9:11 am
well i made up a new set of rudders about 1/2 as big again
and hey the boat turns both directions now
thanks
PostSubject: Re: wont turn left   wont turn left EmptyThu Oct 27, 2016 2:00 pm
Glad the solution was easily resolved
wont turn left
» Degees of rudder turn ?
» Not left the country!!
» Bandsaw cutting badly to left any ideas?
TheRcModelBoatForum.com :: Modelling Categories & Archived Build Logs :: Air Boats-
