 clyde puffer
5 posters
clyde puffer Empty
PostSubject: clyde puffer   clyde puffer EmptySun Mar 19, 2017 9:33 am
hi,
this is the build of my fourth puffer. the reason for 4 is a new grand daughter. as the others are all named after them, I was told I had to build her one .it is a grate little boat measuring 22inches by 5 1/2inches, it is fairly basic but looks good when built. the plan is from radio control boat modeler nov-dec 1985. as you will see from photos it is built using 1/2 ply then plank on frame, our you can just use 1/16" ply but I enjoy doing plank on frame. here is the plan and I will up date as I go along.
clyde puffer Dscf6510
clyde puffer Dscf6511
clyde puffer Empty
PostSubject: Re: clyde puffer   clyde puffer EmptySun Mar 19, 2017 9:40 am
I'm looking forward you your updates David, they look to be strongly built boats and it looks like you have the hang of building them.  2thumbsup
clyde puffer Empty
PostSubject: Re: clyde puffer   clyde puffer EmptyMon Mar 20, 2017 12:02 pm
Love the puffers, one day maybe ....
Looking forward to you making a start.
clyde puffer Empty
PostSubject: Re: clyde puffer   clyde puffer EmptyMon Mar 20, 2017 3:31 pm
this is the start of the main frame, cut out of scrap pieces of 1/2 plywood, I don't spend anything on timber as I collect any of cuts that are going spare.
clyde puffer Dscf0015
clyde puffer Dscf0014
clyde puffer Empty
PostSubject: Re: clyde puffer   clyde puffer EmptyMon Mar 20, 2017 5:35 pm
That looks pretty solid David 2thumbsup
clyde puffer Empty
PostSubject: Re: clyde puffer   clyde puffer EmptyMon Mar 20, 2017 7:23 pm
hi barrie ,
they need to be with a 5year old, and speed fanatic 11year old ,  and now georgia 16 years old, she has had hers for 6 years now  and it still looks good, the first 3 I made have had a real bashing against the concrete edgeing on the lake. as I said they are ideal for kids to play with and no doubt no 4 will lol! lol!
clyde puffer Empty
PostSubject: Re: clyde puffer   clyde puffer EmptySat Mar 25, 2017 7:46 am
I have been planking the puffer this week. the planks I cut from a piece off old pallet, cut into 6mm x 2mm strips and glued with p.v.a.
clyde puffer Dscf0018
clyde puffer Dscf0017
frame work at top is where the deck will be
clyde puffer Dscf0016
had to put 2 pieces at front of bows to get the curve right. as I said you can use ply if you want, I did one of the others in ply I will find photo and show you.
clyde puffer Empty
PostSubject: Re: clyde puffer   clyde puffer EmptySat Mar 25, 2017 10:49 am
2thumbsup 2thumbsup 2thumbsup 2thumbsup I love the recycling David, a man after my own heart 2thumbsup 2thumbsup 2thumbsup 2thumbsup
clyde puffer Empty
PostSubject: Re: clyde puffer   clyde puffer EmptyTue Mar 28, 2017 7:41 am
I have now completed the planking of the sides and also the deck was planked. the stern end was made from some 2mm card board slightly moistend  to help follow the shape.clyde puffer Dscf0020
clyde puffer Dscf0021
clyde puffer Dscf0022
then I gave it a coat of p.v.a. all over to help seal it. I used some fine body filler to fill any gaps on planking, and the stern also got 2 thin coats  put on roughly, then when hard I rubbed it down. you can see the tin of filler I used in one of the previous photos
clyde puffer Empty
PostSubject: Re: clyde puffer   clyde puffer EmptyFri Mar 31, 2017 5:41 pm
hi, not a lot done this week but have finished the stern end with body filler then made decks and fitted servo. I have put two options of the way I build these boats one plank on frame the other I used some 2mm ply I had.
clyde puffer Dscf6611
this one has balsa strip for strength
clyde puffer Dscf6610
servo fitted
clyde puffer Dscf6612
body filler all rubbed down and hole made for prop shaft.
clyde puffer Small10
this one I built i used some 2mm ply from scrap box and some left over short planks.
clyde puffer Dscf6613
this is the deck all cut out ready to be fixed but i need to sort out prop shaft, and motor. that's it for a week now as I am away visiting the ss great Britain in Bristol.
clyde puffer Empty
PostSubject: Re: clyde puffer   clyde puffer EmptyFri Mar 31, 2017 6:08 pm
Coming along nicely David - its interesting to see the two different methods for building. Both methods should be grandchild proof Laughing Laughing
I have added a puffer onto my wish list - I did build the Caldercraft Northlight but sold it. I tried to buy Deans vac formed model on ebay but didn't see any reason to pay more than Deans were selling a new kit for Shocked. I may have to pay him a visit someday soon - its not far from here.
clyde puffer Empty
PostSubject: Re: clyde puffer   clyde puffer EmptyThu Apr 13, 2017 3:57 pm
I have now started on the bridge cabin cut out the templates then transfered to white cardboard, I build a lot of my boats using this 2mm card. clyde puffer Dscf6910
clyde puffer Dscf6911
this is the card I use ready for cutting out bridge
clyde puffer Dscf6913
clyde puffer Dscf6912
this is the bridge all put togetherclyde puffer Dscf6917
clyde puffer Dscf6915
clyde puffer Dscf6916
these are the window frames cut out off empty cornflake box. I find this really good for model making much better than balsa wood. and there is no cost as I have said these boats are built from any old scrap wood and card board plus the funnel was made from 15mm plastic water pipe.
clyde puffer Dscf6918
that's it for today more to follow soon.
clyde puffer Empty
PostSubject: Re: clyde puffer   clyde puffer EmptyThu Apr 13, 2017 6:27 pm
Its interesting to try new materials. This is coming along nicely David.
clyde puffer Empty
PostSubject: Re: clyde puffer   clyde puffer EmptyFri Apr 14, 2017 1:35 am
2thumbsup 2thumbsup 2thumbsup 2thumbsup  A stocky little boat I like it a lot David.  2thumbsup 2thumbsup 2thumbsup 2thumbsup
clyde puffer Empty
PostSubject: Re: clyde puffer   clyde puffer EmptyFri Apr 14, 2017 9:03 am
As Barrie says, it's interesting using card, I would never have thought of that. 2thumbsup  Good progress David 2thumbsup
clyde puffer Empty
PostSubject: Re: clyde puffer   clyde puffer EmptySat Apr 15, 2017 4:52 pm
since my last post I have been soldering suppressers to the motor, I am using. they are soldered to the lead terminals for the battery power, any body that hasn't done this it is fairly simple if you have a soldering iron. first rub the metal caseing where you want to put the suppressers, then a bit of flux and heat up the caseing with iron then apply solder, it will flow when you reach temperature, then remove the  iron and let the solder cool down (I blow on it to make it go of faster but that is optional). then it is the same to the motor terminals and that's it. the speed controller I am using is one from china they work well with this motor.
this first photo shows the suppressers soldered to caseing
clyde puffer Dscf7110
this one is all connected to the live and neutural.
clyde puffer Dscf7111
clyde puffer Dscf7112
this photo is off the motor and the speed controller I will use 385 is the max it will operate.
clyde puffer Dscf7114
I was going to use one of these old bobs boards, the first one I made years ago, but bought the original bobs board one. but after a lot off thought I went for the simple  cheap one from china, but thought any young ones reading this  they can see what we had years ago  Mad Laughing Shocked confused
clyde puffer Dscf7113
 that's it for today hope you like the old and new technology.
clyde puffer Empty
PostSubject: Re: clyde puffer   clyde puffer EmptySat Apr 15, 2017 5:26 pm
Hi David
I use those Speed Controllers. I wouldn't try to put the 10 amps they claim through them, but for small motors in small models they are ideal. I am just waiting for another to arrive for my current build.
I'm afraid I've become a little lazy about fitting suppressors as 2.4 Ghz isn't really affected by motor interference, but I guess I should consider those still using 27 and 40 Mhz.
clyde puffer Empty
PostSubject: Re: clyde puffer   clyde puffer EmptyMon Apr 17, 2017 7:39 pm
so far i have been doing bits and pieces. this is the hatch cover again made from cardclyde puffer Dscf6920
clyde puffer Dscf6919
next job has been the bulwark this is 2mm ply put in boiling water for 2 min then gently teasd it around then put supports round I used super glue for this. servo is now fitted and working
clyde puffer Dscf7010
that's it for today
clyde puffer Empty
PostSubject: Re: clyde puffer   clyde puffer EmptyTue Apr 18, 2017 2:21 pm
What a very interesting and excellent build david.......unusual but shows great technique..........and enjoying it very much. neil.
clyde puffer Empty
PostSubject: Re: clyde puffer   clyde puffer EmptyTue Apr 18, 2017 3:19 pm
clyde puffer Dscf6922
this picture fixing the bulwark should have been on yesterdays post but lost it some where. today I have made the rudder from plasticard and 1.5 mm copper wire.clyde puffer Dscf7115
this you will all no is from a 13amp plug they make excellent rudder arms
clyde puffer Dscf7116
this shows it connected to servo.clyde puffer Dscf6924
this is the rudder made from plasticard then 1.5mm copper wire is pushed through holes and connected to brass strip to make a support at bottom
clyde puffer Dscf6923
rudder now on bottom supportclyde puffer Dscf7211
clyde puffer Dscf7212
the rudder and prop shaft that I have forgot to show, is a 30mm x 2mm plastic prop and the prop shaft was made of brass outer and stainless inner  6 inches long. i bought from ellesmere show  in march this year.
clyde puffer Empty
PostSubject: Re: clyde puffer   clyde puffer EmptyThu Apr 20, 2017 4:01 pm
the prop shaft I have used is this one in photo.clyde puffer Dscf7213
the motor is now installed and connected I find this method much simpler and less vibrationclyde puffer Dscf7011
also made some of these out of card from cornflake box. light boxes and water tankclyde puffer Dscf7215
clyde puffer Dscf7214
clyde puffer Dscf7216
next job is the painting
clyde puffer Empty
PostSubject: Re: clyde puffer   clyde puffer EmptyThu Apr 20, 2017 6:47 pm
clyde puffer Empty
PostSubject: Re: clyde puffer   clyde puffer EmptyFri Apr 21, 2017 11:31 am
2thumbsup 2thumbsup 2thumbsup 2thumbsup 2thumbsup
clyde puffer Empty
PostSubject: Re: clyde puffer   clyde puffer EmptySun Apr 23, 2017 6:57 pm
this is the first coat of red oxide paint
clyde puffer Dscf7218
started the painting today
clyde puffer Dscf7217
these are parts painted in gloss ready for fixing in place
clyde puffer Dscf7219
this is the cargo hold cover, this side is coal from model trains 00 gauge,i used p.v.a glue diluted then left to dry. the other side is all fastend down with tarpolin and batons ready for sailing.
clyde puffer Dscf7220
this is where I am upto today coat of matt black on upper bulwarks, deck is a cream colour I mixed.
clyde puffer Dscf7224
this is the other side of cargo hold
clyde puffer Dscf7223
these are some of the paints I use .
clyde puffer Empty
PostSubject: Re: clyde puffer   clyde puffer EmptyThu Apr 27, 2017 7:21 pm
hi all,
well I have been painting mostly this week in the freezing cold not good Mad . I have made the goose neck for the hoisting lift and mast using some copper and brass rod and some 1/4inch dowel that was in stock.
clyde puffer Dscf7227
clyde puffer Empty
PostSubject: Re: clyde puffer   clyde puffer EmptyFri Apr 28, 2017 4:27 am
Looking good David.  2thumbsup 2thumbsup 2thumbsup 2thumbsup
clyde puffer Empty
PostSubject: Re: clyde puffer   clyde puffer EmptyWed May 03, 2017 8:30 am
have finally finished all the painting a and put all the fittings on and her name.
clyde puffer Dscf7312
clyde puffer Dscf7313
clyde puffer Dscf7314
clyde puffer Dscf7311
well that's it for now I will take it for test sail when I next go sailing. that is my legacy to my grand children all sorted, when I am in the next world. I hope they will have some happy days with them and with there children.
inertia
inertia
clyde puffer Empty
PostSubject: Re: clyde puffer   clyde puffer EmptyWed May 03, 2017 9:35 am
It was the 1/72 scale Deans Puffer kit which Craig (ACTion) Talbot gave me to build which prompted me to design my own. To say it was somewhat lacking in the quality department would be an understatement. My design ended up as the Model Slipway kit. It's a shame that Lawrie and Jackie sold their big vac-forming machine when they left the factory, or this little kit might still have been available. I still have a full set of kit drawings and the plan - all in .DWG format - in case anyone out there is interested in building one.
Dave M
clyde puffer Empty
PostSubject: Re: clyde puffer   clyde puffer EmptyThu May 04, 2017 7:55 am
Nice addition to a wonderful line up David, cracking boats 2thumbsup
clyde puffer Empty
PostSubject: Re: clyde puffer   clyde puffer EmptyThu May 04, 2017 7:22 pm
hi,
I have been doing a costing for this model scratch . all the materials such as wood, card, ect cost me zero, as I had this in my scrap box. the plan was free, only cost to me was the speed controller, motor, couplings, prop & shaft total cost £15.00. the receiver I have is 27 meg, I have got some that I started of with  many years ago then went to 40meg. got the crystals and transmitter so to me no cost. it has given me endless enjoyment building and that time is free to me. so any body wanting to build something it can work out very cheap. ask around and a lot of people now on 2.4 will sell you there old receivers, if you ask nicely. our you can pick them up on ebay cheap with transmitters. so who said its expensive to build models, you don't have to have all the latest gear to sail as long as its legal try it out. I no my grand daughter is happy Very Happy
david.
clyde puffer Empty
clyde puffer
» Clyde Puffer
» Clyde Model boats
» Mini Puffer
» Mountfleet Sealight Puffer
» Models by Design Puffer
