 WARNING
WARNING Empty
PostSubject: WARNING   WARNING EmptyFri Feb 16, 2018 5:55 am
Avoid the blue plastic masking tape like it's the plague.
I attempted to masked the yellow on Josie with paper tape without success on the tight curves after the damage to the gloss finish on the yellow last time, I was hoping to avoid it.
I applied the blue and then paper tape and 150mm/6" Inch blown paper and resprayed the brown left it 5 minutes and removed all masking to find the gloss finish gone from under the blue masking tape again Grrrrrrrr 4 rolls now in garbage.
Hoping like crazy some cutting compound will bring the shine back, at least it's not as obvious as it was on the brown.
WARNING Empty
PostSubject: Re: WARNING   WARNING EmptyFri Feb 16, 2018 12:42 pm
Go to ebay type in fine lind tape....MAKE SURE   it is 3M.....and buy some proper 3m masking tape as well.....dont bother with thd Tamiya stuff
WARNING Empty
PostSubject: Re: WARNING   WARNING EmptySat Feb 17, 2018 12:00 am
2thumbsup 2thumbsup 2thumbsup 2thumbsup 2thumbsup 2thumbsup 2thumbsup
Thanks Dave It reacts to enamel paint never had a problem with automotive acrylics whilst using it I'll certainly get some 3M though.
WARNING Empty
PostSubject: Re: WARNING   WARNING EmptySat Feb 17, 2018 8:36 am
The blue tape I'm having trouble with is the 3m tape.
WARNING Empty
PostSubject: Re: WARNING   WARNING EmptySat Feb 17, 2018 9:20 am
May i ask where you got it from
WARNING Empty
PostSubject: Re: WARNING   WARNING EmptySat Feb 17, 2018 10:17 am
A local Dulux automotive supplier 12 months or so ago.
WARNING Empty
PostSubject: Re: WARNING   WARNING EmptySun Feb 18, 2018 8:39 am
I think the problem is the aerosol can paint being too thick and taking weeks or months to dry where I normally airbrush auto acrylics.
WARNING Empty
PostSubject: Re: WARNING   WARNING EmptySun Feb 18, 2018 4:08 pm
sounds to me that the tape is old.......another trick you can use is to look yet again on ebay for some 1/4 inch insulation tape and apply this first,i can gtee you this will stop any bleed through on any paint acrylic or enamel
WARNING Empty
PostSubject: Re: WARNING   WARNING EmptySun Feb 18, 2018 11:32 pm
"OLD" Quite possible Dave I bought 6 on ebay 18mth to 2 years ago and still had 4 takes forever to build anything these days.
WARNING Empty
WARNING
» Warning Warning Warning
» WARNING!!!WARNING!!!
» A warning to all members.
» Serious drink drive warning - timely pre- Christma
» Community Service Announcement!Government warning
