 Mountfleet sealight
Imcc
Imcc
Mountfleet sealight Empty
PostSubject: Mountfleet sealight   Mountfleet sealight EmptySun Sep 02, 2018 7:33 pm
Well at last I’ve started working on the Clyde puffer. It’s been a year upstairs in its box. As you can see motor, prop shaft, rudder, battery and smoke generator are all in place. Sound module and speaker can be fitted later. This is going to need a lot of weight to make it sit right in the water. Mountfleet sealight 59713b10
Mountfleet sealight 81b24510
Mountfleet sealight Dc78ac10
Ian
PostSubject: Re: Mountfleet sealight   Mountfleet sealight EmptySun Sep 02, 2018 9:44 pm
an interesting build as I built an original northlight puffer many years ago, and she sailed beautifully.
Imcc
Imcc
PostSubject: Re: Mountfleet sealight   Mountfleet sealight EmptySun Sep 16, 2018 9:53 pm
Some weight put in and the inside sprayed red. Decks are glued in. Bulwark need filling and sanding next
Mountfleet sealight Fa3fb810
Mountfleet sealight 1be0cb10
Mountfleet sealight 7da2c410
Ian
PostSubject: Re: Mountfleet sealight   Mountfleet sealight EmptySun Sep 16, 2018 11:27 pm
2thumbsup
PostSubject: Re: Mountfleet sealight   Mountfleet sealight EmptyMon Sep 17, 2018 12:53 am
2thumbsup 2thumbsup 2thumbsup 2thumbsup 2thumbsup 2thumbsup 2thumbsup 2thumbsup
Imcc
Imcc
PostSubject: Re: Mountfleet sealight   Mountfleet sealight EmptyThu Apr 16, 2020 5:15 pm
Well with the way things are at the moment there’s no reason why I shouldn’t get on with this puffer. So I’ve been working on the main hatch. Lots of fiddling little brackets gussets and ring bolts to fit. This is going to take some time to get it right, but will get there in the end.
Mountfleet sealight Bf22c610
Imcc
Imcc
PostSubject: Re: Mountfleet sealight   Mountfleet sealight EmptyWed Apr 22, 2020 8:48 pm
Gussets fitted and hatch boards cut out, these need staining and ring fitted. Next hard job is getting hold of some paint in these hard times.
Mountfleet sealight Ad2e7b10
Mountfleet sealight B2d0a010
Mountfleet sealight C5062710
PostSubject: Re: Mountfleet sealight   Mountfleet sealight EmptyThu Apr 23, 2020 12:54 am
Really nice, I do like the mount fleet kits, always fancied one of their ww2 converted tugs, I forget then name off hand but excellent work.
For paint try eBay, look for fast and free on their delivery.. they usually dps/Hermes or parcel force 48 that stuff. Even in this climate.
Imcc
Imcc
PostSubject: Re: Mountfleet sealight   Mountfleet sealight EmptySat Apr 25, 2020 2:10 pm
Painting hatch today. Managed to gets some paint delivered quick time from scale model shop. Trying some weathering affect so using air brush to get this finish. The colour I’ve picked is a Camouflage Light Brown Vallejo Model Air. The reason I’ve picked this colour is because with these puffers being used in the war. Private Walker from dads army ( or equivalent for that area)has supplied them with army camouflage paint in exchange for some coal that is on its way to one of the Scottish island distillery. Very Happy  This is the first time I’ve tried this and following YouTube videos I’ve sprayed black down on the corners and fittings. This was dry with hairdryer and the brown was put on in fine layers until I was happy. I’ve have a grime wash to put on after when I’ve tested it on a sample. Coal will be added at the end as well as ring pull handles and tarps covers.
Mountfleet sealight 83c4a310
Mountfleet sealight 57e35f10
Mountfleet sealight C8305110
PostSubject: Re: Mountfleet sealight   Mountfleet sealight EmptySun Apr 26, 2020 11:25 am
You did the pre shading method good job really nice on the weathering effect.
Pre shading is a bit of an art form on its own at times looks like you got the hang of it tho so well done 👍🏻
Imcc
Imcc
PostSubject: Re: Mountfleet sealight   Mountfleet sealight EmptySun May 03, 2020 2:55 pm
Mountfleet sealight 4fc02610
Mountfleet sealight 73719010
Sometime back I was chatting to a nice lady in the bank about my boat building and she told me her husband works with wood vaneers. I said I never thought of using that on my boats. The next time I went in she a shopping bag full of the stuff. How nice was that. So I’m trying it out and it seems quite easy.
Imcc
Imcc
PostSubject: Re: Mountfleet sealight   Mountfleet sealight EmptyMon May 04, 2020 11:13 pm
This veneer decking turned out to be real easy and after a clay wash it was just the effect I wanted Very Happy
Mountfleet sealight 808d2010
Mountfleet sealight
