for you interest
When looking at ships the power to weight ratio is important if you have to consider the fuel that you are going to use and the distance between stops.
Now with my new approach this fuel to weight ration does not apply only the size and to the ships engine room.
The military have a different power to weigh ratio the need for speed to fuel and distance is important and two speeds cruise and tactical speed.
So let’s look at some real ones
Emma Maersk single engine one screw 25kts
Gross tonnage 170,794 ton
Propulsion power only 81,000,000 watts or 81MW or 108,622.79 HP
So power to wt
So 474.26 watts to the ton but in
shipping language 474.26 kw per 1,000 ton or 635.99 HP per 1,000ton
QM2 4 azimuth thruster type podded propulsion units twin propellers each speed 30kts
Gross tonnage 149,215 tons
Propulsion power only 86,000,000 watts 86MW or 115,327.9 HP
So power to wt
576.35 watts per ton
shipping language 576.35 kw per 1,000 ton or 772.90 HP per ton
now the Daring class destroyer type 45
Gross tonnage 7,300 tons twin screw 27kts
Propulsion power only 42,000,000 watts 42MW or 56,322.93 HP
So power to wt
5,753.42 watts per ton but in
shipping language 5,753.42 kw per1,000 ton 7,715.47 HP per 1,000 ton
see the difference
The Yorkshireman tug 50ton bollard pull
Gross tonnage 144 ton twin screws 12.5kts -13kts
Propulsion power only 2,460,000 watts 2.46MW or 3,298.00 HP
So power to wt
17,083.33 watts per ton but in
shipping language 17,083.33 kw per 1,000 ton or 22,902.78 HP per 1,000 ton
model The Yorkshireman tug my brothers 1/48 scale
Gross wt 13kg twin screw 50 mm 6 bladed props
Total power 120 watts 12v x 5a max each motor so is total 120w
So power to wt
9.23 watts per kg
Timed full speed over 10m 7.5 real time seconds or 1.33m/sec 2.975mph real time
Bollard pull 2.5lb or 1.13kg
Then what is the real scale speed?
Problem here is the gwt and the power are not scaled and this is why scale speed is hard to fully calculate.
I have been working on it for them
I do have a new proposed real build
Trimaran
Expected Gross tonnage 9,000 tons twin screw and 4 water jets speed excess of 45kts
Propulsion power only 100,000,000 watts 100MW or 134,102 HP
2 x 20 MW motor driven 6 blade VP screws plus 4 water jets 15MW each
So power to wt
11,111.11 watts per ton but in
shipping language 11,111.11kw per 1,000 ton or 14,900.22 HP per 1,000 ton
the difference here is it has unlimited range and could do 30kts all day
So could I then take a cargo ship and give it unlimited range? yes, and that is what I am working on sizing up power systems for them.
