 mr darby build
satlite440
mr darby build Empty
PostSubject: mr darby build   mr darby build EmptyWed Jul 29, 2020 5:37 pm
https://www.facebook.com/photo?fbid=3135059449862973&set=pcb.3135060979862820
mr darby build Photo?fbid=3135059449862973&set=pcb
any one else built one of these monsters? looking for any tips or the build instrutions
satlite440
PostSubject: Re: mr darby build   mr darby build EmptyThu Jul 30, 2020 4:06 am
mr darby build P1050012
mr darby build P1050013
mr darby build P1050014
PostSubject: Re: mr darby build   mr darby build EmptyThu Jul 30, 2020 8:29 am
Your Facebook post says not available.
That is a big beast lol!
It looks to be a good quality moulding. I'm afraid I can't help with instructions - I have never heard of that model - is it American?
If you have specific questions we'll try to answer them for you. It looks as though you are cutting templates for something. What are you planning to do.
satlite440
PostSubject: Re: mr darby build   mr darby build EmptyThu Jul 30, 2020 3:50 pm
mr darby build P1050015
satlite440
PostSubject: Re: mr darby build   mr darby build EmptyThu Jul 30, 2020 3:53 pm
at the moment im glassing in the propshaft supports inner and outer was hopeing for some help but no luck here or any other fourm im onmr darby build P1050016
PostSubject: Re: mr darby build   mr darby build EmptyThu Jul 30, 2020 5:21 pm
Do you have a specific question about glassing the propshafts? Personally I use a product available in the UK called P40. Its a resin with chopped glass in it. Easier to use than glass mat.
We may not be familiar with Mr Darby, but we do have quite a bit of experience making all kinds of model boats from wood, plastic or fibre glass.
satlite440
PostSubject: Re: mr darby build   mr darby build EmptyFri Jul 31, 2020 1:38 am
mr darby build P1050110
mr darby build P1050017
mr darby build P1050018mr darby build P1050110
mr darby build P1050018no im kinda just kicking around internal lay out..i have the deck kit from  harbor models but there are no instructions wit it..nor is there much in pictures or vids of deck  access and internal lay  out to see..some things are fixed but i got no clue..got the hull for free like 10 yrs ago ..been slowly acquiring all the things i needed to do a build..and finally start..still have yet to pick a batt...i will have a 30mm bow thruster...i hope to make a flood tank with a pump to get 4 gallons of water from lake to bring down to waterline and back up again for transport.. i have read of some complains about the rear deck access but not seen it
satlite440
PostSubject: Re: mr darby build   mr darby build EmptyMon Aug 03, 2020 5:45 am
germaina wheft ag shipyard report...after what seemed like a life time of filling and sanding got the prop shaft covers on and glassed in..trying a few moter mount mock ups not happy with any of them..ideally i would like to turn the motor cans at 45 degrees and out-aboard next to the hull.. this will keep them above any flooding and give me blue water ability(ie i can take rough water and some internal flooding and keep the electronics safe)to sail...would like a thinner support or different still playing with this and other mock up's as i think of them for now....think i like the 2nd design better still kicking around a 3rd this one is removable and after base is glassed in pull the pins and slide forward will have a butt plate to stop rear movementmr darby build P1050113
mr darby build P1050112
mr darby build P1050111
satlite440
PostSubject: Re: mr darby build   mr darby build EmptyMon Aug 03, 2020 5:47 am
mr darby build P1050114
mr darby build P1050115
mr darby build P1050116
satlite440
PostSubject: Re: mr darby build   mr darby build EmptySun Aug 09, 2020 4:50 am
mr darby build P1050117
mr darby build P1050119
mr darby build P1050118
satlite440
PostSubject: Re: mr darby build   mr darby build EmptySun Aug 09, 2020 4:51 am
mr darby build P1050120
mr darby build P1050121
mr darby build P1050122
satlite440
PostSubject: Re: mr darby build   mr darby build EmptySun Aug 09, 2020 4:52 am
mr darby build P1050123
mr darby build P1050124
satlite440
PostSubject: Re: mr darby build   mr darby build EmptySun Aug 09, 2020 4:53 am
mr darby build P1050127
mr darby build P1050126
mr darby build P1050128
satlite440
PostSubject: Re: mr darby build   mr darby build EmptySun Aug 09, 2020 4:54 am
rendeer mr darby build P1050130
mr darby build P1050131
mr darby build P1050129
mr darby build
» Next Build Tug
» Wee Nip Build
» HMS Hood
» Mantis build
