 Billings Adrea Gail
Go to page : 1, 2  Next
Billings Adrea Gail Empty
PostSubject: Billings Adrea Gail   Billings Adrea Gail EmptyThu Dec 31, 2020 7:19 pm
This is my after Christmas present to myself Shocked  I wanted to buy this kit earlier in the year, but no one had it in stock. Browsing the internet after Christmas I found this on CMB's web site and ordered immediately. It arrived today. This is a static model.
Billings Adrea Gail Img_2036
This is the first 'modern' Billings kit that I have built - it will be interesting to see if they have improved. At least it is laser cut - not die cut - so hopefully the ply will be of better quality. The instructions also appear more comprehensive - they don't stop as you get to the difficult bit - at least that's the first impression.
coastie23
PostSubject: Re: Billings Adrea Gail   Billings Adrea Gail EmptyFri Jan 01, 2021 6:16 pm
Hi Barrie does it look any good any chance of some pictures of the box contents
cheers
coastie
PostSubject: Re: Billings Adrea Gail   Billings Adrea Gail EmptyFri Jan 01, 2021 7:49 pm
Hi Coastie - I thought it did until I made a start this morning. I'll show you the first problem tomorrow when I've taken some photos. I'll also replace the upside down photo above.
coastie23
PostSubject: Re: Billings Adrea Gail   Billings Adrea Gail EmptyFri Jan 01, 2021 10:08 pm
Thank You
PostSubject: Re: Billings Adrea Gail   Billings Adrea Gail EmptySat Jan 02, 2021 11:02 am
These are the contents of the box -
Billings Adrea Gail Dscn1930
plus the piece of MDF as a building board
Billings Adrea Gail Dscn1931
No plan, but this full size drawing in elevation and plan view
Billings Adrea Gail Dscn1929
The quality of the thicker is ply is very good, but the thinner sheets are very hard. There is some very fine detail in these sheets which I think will be tricky to cut free.
The problem I have encountered is illustrated in the following photo. There should be a notch in the half keel as indicated but its missing bounce bounce bounce
Billings Adrea Gail Dscn1932
a slight annoyance is also that the slots in the hull, as well as being too many, are slightly too wide.
This is where I have got to
Billings Adrea Gail Dscn1933
Swab likes this post
coastie23
PostSubject: Re: Billings Adrea Gail   Billings Adrea Gail EmptySat Jan 02, 2021 3:36 pm
Thanks Barrie. Doesnt look to be much there for the money. hope you checked all the wood and fittings are there.
last one i did was shocking wood looked like it had been chewed by the factory dog half the fittings were missing plywood was warped took pictures of the crap in the box. give them there due got a replacement kit within 4 days direct from Denmark. seems there cut out in germany now.
Will watch your build with interest.
coastie
Swab
Swab
PostSubject: Re: Billings Adrea Gail   Billings Adrea Gail EmptySat Jan 02, 2021 5:24 pm
Do you think the extra slots may be so they can use this profile for other boats with different hull layouts? If seems wasteful to program the laser for no reason. If you need crew for it I'll get a 3d print of myself done I'm a close match to George Clooney or was it Formby?
PostSubject: Re: Billings Adrea Gail   Billings Adrea Gail EmptySat Jan 02, 2021 6:48 pm
Hi Coastie - Bought if from Cornwall Model Boats - cheapest I could find by quite a lot. I still don't know about the quality of the planking. At first glance it wasn't very promising, but I wont know until I start to bend it and fix it. As usual with Billings the brass fittings are excellent.
Swab - yes obviously the keel is used for another model - or was designed for one. I just wish they had included the correct cut outs for this one Shocked
coastie23
PostSubject: Re: Billings Adrea Gail   Billings Adrea Gail EmptySun Jan 03, 2021 10:12 pm
Hi Barrie I have some 20 year old billings wood which is miles better than the wood that was in the last kit. Model shop was closing down he had billings wood display box full of timber so I bought it off him
Rudder shaft looks like its going to be fun drilling it
Coastie
PostSubject: Re: Billings Adrea Gail   Billings Adrea Gail EmptyMon Jan 04, 2021 11:44 am
I was hoping to start planking today, but it took longer than expected to finish fitting the bulkheads and decks. I had to be careful not to stick the decks to the building board. There was no way of using clamps, so in the end reverted to using superglue Rolling Eyes
Billings Adrea Gail Dscn1934
Having taken a good look at the planks supplied, then I revise my opinion - they're RUBBISH Shocked Shocked Shocked . A very heavy grain which will take considerable sanding and filling to achieve the smooth finish required as this was steel hulled vessel. Rolling Eyes Rolling Eyes bounce
coastie23
PostSubject: Re: Billings Adrea Gail   Billings Adrea Gail EmptyMon Jan 04, 2021 11:59 am
looking good so far
coastie
PostSubject: Re: Billings Adrea Gail   Billings Adrea Gail EmptyTue Jan 05, 2021 12:39 pm
Billings Adrea Gail Dscn1935 Billings Adrea Gail Dscn1936
Planking started! I think you can see what I mean about the quality of the timber Rolling Eyes I started using superglue, but have switched to aliphatic, although I may need to switch back when the going gets tough lol!
coastie23
PostSubject: Re: Billings Adrea Gail   Billings Adrea Gail EmptyTue Jan 05, 2021 1:03 pm
boy that is rough doesnt even look likes its been planed or sanded.
coastie
PostSubject: Re: Billings Adrea Gail   Billings Adrea Gail EmptyWed Jan 06, 2021 11:18 am
Billings Adrea Gail Dscn1937
Well - that's the easy bit Rolling Eyes  Had to stop here as the pins were getting in the way. When I restart I will use superglue so the pins can come out more quickly. I started sanding the top part - it will take a lot to get it smooth so I guess the whole lot will have to have a coat of filler.
Looking at the bow the second bulkhead appears to me to be wrong - its too low. Can't do anything about it now except to use more filler if it still looks wrong after sanding.
Swab
Swab
PostSubject: Re: Billings Adrea Gail   Billings Adrea Gail EmptySat Jan 09, 2021 9:36 am
Swipe me that's rough Billings quality control need to come back from furlough! I'm confident you'll sort it though Very Happy
PostSubject: Re: Billings Adrea Gail   Billings Adrea Gail EmptySat Jan 09, 2021 12:43 pm
Billings Adrea Gail Dscn1938
A few more planks added. Its slow going. I've sanded the top part and its still rough Rolling Eyes bounce bounce
I have no option to continue with this side, but I think I may have enough lime stripwood to do the other half. If so, the model will be displayed with that side showing lol! lol! lol!
barrie
coastie23
PostSubject: Re: Billings Adrea Gail   Billings Adrea Gail EmptySat Jan 09, 2021 3:28 pm
despite billings looking good Barrie
PostSubject: Re: Billings Adrea Gail   Billings Adrea Gail EmptyMon Jan 11, 2021 12:36 pm
Billings Adrea Gail Dscn1939
Side one finished 2thumbsup 2thumbsup Not my best bit of planking - thank goodness its going to be covered in filler Shocked Rolling Eyes Shocked Rolling Eyes
I don't think all the problems are mine. I'm sure some of the bulkheads are incorrect. There are bumps and hollows which don't look right at all.
I will continue to sand and then start filing while I build side 2. I have already removed all the parts from the sheets and mounted two of the bulkheads.
coastie23
PostSubject: Re: Billings Adrea Gail   Billings Adrea Gail EmptyMon Jan 11, 2021 4:32 pm
see the skegs got broken Sad off like i did on one mine can i suggest you plank the other side to make it stronger can always be fared in later.
just noticed another problem looking at there instruction manual on the bulk heads the deck support looks very very flimsy
PostSubject: Re: Billings Adrea Gail   Billings Adrea Gail EmptyMon Jan 11, 2021 7:07 pm
Coastie - yes it got broken when I tried to remove the half keel from the board to cut the slot that was missing. I have it and will stick it to the other side when I have fixed both sides together. Not sure what you mean about the deck. It sits on the top of the bulkheads. What I am concerned about is how the bulwarks fix to the deck - but that's for the future. For now there's another side to build Rolling Eyes Rolling Eyes
I'm going to be using some wood that is at least smooth - not sure how pliable it is. I think its some I rejected from another build Shocked
coastie23
PostSubject: Re: Billings Adrea Gail   Billings Adrea Gail EmptyMon Jan 11, 2021 7:31 pm
Hi Barrie part number 25 bulwarks as a top piece that supports a deck piece be tempt to jump up a bit and fit the deck part no  31 save breaking the supports off.
coastie
PostSubject: Re: Billings Adrea Gail   Billings Adrea Gail EmptyTue Jan 12, 2021 9:00 am
Coastie
Are you sure you are looking at the same model? This is the 1/60th scale display version of Andrea Gail. There is (was?) a 1/30th scale working version. The decks fit direct to the top of the bulkheads. The bulwarks appear to sit on the deck - no supports to break off.
coastie23
PostSubject: Re: Billings Adrea Gail   Billings Adrea Gail EmptyTue Jan 12, 2021 3:30 pm
bit where wonky arrow is pointing have to be careful until decks fitted some cut ends off when decks fitted others leave it wholeBillings Adrea Gail Andrea10
PostSubject: Re: Billings Adrea Gail   Billings Adrea Gail EmptyTue Jan 12, 2021 6:48 pm
See what you mean Coastie - hadn't got so far in my planning yet! My instruction book is in black and white - did you download yours?
coastie23
PostSubject: Re: Billings Adrea Gail   Billings Adrea Gail EmptyWed Jan 13, 2021 6:52 am
aye downloaded it from billings to follow your progress
PostSubject: Re: Billings Adrea Gail   Billings Adrea Gail EmptyWed Jan 13, 2021 12:47 pm
I've now stuck all the bulkheads to the keel for the second side. I hope to start planking tomorrow if my nose will stop dripping lol! lol!
I will probably also put some filler onto side one.
PostSubject: Re: Billings Adrea Gail   Billings Adrea Gail EmptySun Jan 17, 2021 11:32 am
Finally got back into the workshop. I've started planking side 2. I am using some stripwood from stock - its much smoother and not as coarse as that supplied in the kit.
Billings Adrea Gail Dscn1940
I decided not to start filling side one at this point, as I may want to see how I arranged the planks to help with side two.
PostSubject: Re: Billings Adrea Gail   Billings Adrea Gail EmptyFri Jan 22, 2021 11:22 am
Billings Adrea Gail Dscn1941
A few more planks on side 2. Its slow going as the pins get in the way Shocked Rolling Eyes This timber is smoother, but harder. The pins don't go in easily Rolling Eyes
I don't think this will be exactly the same as side 1, but after all the filler it will need that wont matter. lol!
Covid vaccination in the morning so no more work until Sunday.
PostSubject: Re: Billings Adrea Gail   Billings Adrea Gail EmptyMon Jan 25, 2021 12:51 pm
Billings Adrea Gail Dscn1943
Another couple of planks added today - its slow going because of the need to use clamps. You can see the strange shape at the bows - I'm sure the bulkheads 2, 3 and 4 are wrong.
I also added P38 filler to side 1 - lots of sanding needed here Shocked Rolling Eyes lol!
Billings Adrea Gail Dscn1942
coastie23
PostSubject: Re: Billings Adrea Gail   Billings Adrea Gail EmptyMon Jan 25, 2021 4:35 pm
coming along nicely
PostSubject: Re: Billings Adrea Gail   Billings Adrea Gail EmptyTue Jan 26, 2021 12:44 pm
Billings Adrea Gail Dscn1944
Almost finished planking side 2 - just the tricky bit at the keel Shocked
Billings Adrea Gail Dscn1946
I also started sanding side 1 - still quite a way to go, and more filler will be required Rolling Eyes
Here are the two hales clipped together
Billings Adrea Gail Dscn1945
PostSubject: Re: Billings Adrea Gail   Billings Adrea Gail EmptySun Jan 31, 2021 11:51 am
Finally got round to finishing planking side 2. It has now been sanded and had some filler applied. Side 1 had its first coat of filler sanded and some more filler. After sanding this again, I think I will fix the two sides together before more filling and sanding.
Billings Adrea Gail Dscn1947
PostSubject: Re: Billings Adrea Gail   Billings Adrea Gail EmptyMon Feb 01, 2021 10:51 am
Billings Adrea Gail Dscn1948
More sanding Shocked The two halves have now been joined together. They will require more filling and sanding before I can move on.
coastie23
PostSubject: Re: Billings Adrea Gail   Billings Adrea Gail EmptyMon Feb 01, 2021 4:57 pm
Smile Smile Smile Smile Smile Smile
PostSubject: Re: Billings Adrea Gail   Billings Adrea Gail EmptyTue Feb 02, 2021 10:47 am
Billings Adrea Gail Dscn1949
More sanding and filling Rolling Eyes  The other half of the deck has been stuck down - I left it as I thought it would allow me to get a better join. Once the glue and filler is dry, I have to cut and shape some balsa blocks for the stern. Once they and the hull have had another sanding I intend to apply some EzeKote resin. After that I really need to get some primer on the hull so I can check for imperfections.
Swab
Swab
PostSubject: Re: Billings Adrea Gail   Billings Adrea Gail EmptyTue Feb 02, 2021 9:49 pm
What's the standard of the deck fittings like Barrie?
PostSubject: Re: Billings Adrea Gail   Billings Adrea Gail EmptyWed Feb 03, 2021 7:04 am
I've not examined them in detail, but I don't expect problems. Billings fittings are normally pretty good - mainly in brass. I know the stantions are brass.
PostSubject: Re: Billings Adrea Gail   Billings Adrea Gail EmptyWed Feb 03, 2021 11:21 am
The balsa blocks have been stuck and sanded to shape. More sanding and filling - not quite ready for EzeKote yet. There was a serious discrepancy at the bows on one side, so more filler Rolling Eyes Rolling Eyes Rolling Eyes
I do hope this is the last. There is also a problem with the hull shape as seen in the photo on the right, but that will have to stay.
Billings Adrea Gail Dscn1950 Billings Adrea Gail Dscn1951
PostSubject: Re: Billings Adrea Gail   Billings Adrea Gail EmptyFri Feb 05, 2021 11:04 am
Billings Adrea Gail Dscn1952
Sanding finally finished 2thumbsup 2thumbsup  Two coats of Ezekote have been applied and will be lightly sanded. Ideally I would like to apply some primer to check the surface, but there are some rubbing strips to add, and I think they would be better stuck to resin than primer.
PostSubject: Re: Billings Adrea Gail   Billings Adrea Gail EmptyTue Feb 16, 2021 11:29 am
The weather has finally eased so I returned to the workshop.
After sanding the hull with wet and dry, I fitted the bulwarks and the first rubbing strip.
Coastie - you were right about the delicate nature of the bulwark. I have already snapped one. I didn't take your advice to fit the deck as I will need to paint that area before I do so or it will be very dificult to paint once the deck is in place.
There are some bits to add to the wall and then I can start painting that area.
Billings Adrea Gail Dscn1953
PostSubject: Re: Billings Adrea Gail   Billings Adrea Gail EmptySun Feb 21, 2021 12:05 pm
Second rubbing strip applied - this is in the correct place according to the plans, but not according to the construction picture Shocked
Billings Adrea Gail Dscn1954
The cutwaters on the bow have been fitted and some detail on the step. The large block is supposed to be a freezer Rolling Eyes I think I am almost ready to spray the whole hull and deck with white primer. I can then paint the step and inside the bulwarks before moving on to the superstructure.
coastie23 and Swab like this post
PostSubject: Re: Billings Adrea Gail   Billings Adrea Gail EmptySun Feb 28, 2021 12:02 pm
After some final filling and sanding this morning I was ready to spray with primer. Whilst waiting for it to warm up outside, I started preparing some of the fixtures that will be needed next. I am not sure if this was the best way of making these. They are laser cut with some very fine pieces of ply which means that I am very reluctant to sand them as they should be done. Just getting them out of the sheet I managed to snap one leg.
Billings Adrea Gail Dscn1955
Once the weather warmed up, I gave the whole of the hull a spray of white primer.
Billings Adrea Gail Dscn1956
PostSubject: Re: Billings Adrea Gail   Billings Adrea Gail EmptyMon Mar 01, 2021 11:50 am
I realised that because of the intricate and delicate superstructure of this ship - and there's even more to come - it was best to paint the hull before I started to place this on deck. So, the decks and upper side of the hull have had one coat of acrylic so far.
Billings Adrea Gail Dscn1957
The structure in yesterday's photo has on coat of matt white as an undercoat. It is very tricky to paint, not least because it is so fragile.
coastie23 likes this post
PostSubject: Re: Billings Adrea Gail   Billings Adrea Gail EmptyWed Mar 03, 2021 10:47 am
Billings Adrea Gail Dscn1958
A second coat on the green and first coat on the underside. This will dry matt (I hope). I never quite know what colour to paint the underside - I was going to use Humbrol red/brown, but the tin was almost empty so settled for this. I also gave the tower a coat of satin white, and I think it will need another - the lasered edges take some covering.
Swab
Swab
PostSubject: Re: Billings Adrea Gail   Billings Adrea Gail EmptyWed Mar 03, 2021 1:55 pm
Do you brush paint your top coats?
PostSubject: Re: Billings Adrea Gail   Billings Adrea Gail EmptyWed Mar 03, 2021 6:16 pm
Swab - yes normally. I sometimes use a rattle can especially if I have lot of white. I tried airbrushing but couldn't get on with it. All the mixing and cleaning became a hassle, so I reverted to brushing. Until just recently I used Humbrol enamels, but am now using acrylics as well. I have quite a lot of odd colours in enamel, but am using acrylic particularly black and white, plus the green is also acrylic.
PostSubject: Re: Billings Adrea Gail   Billings Adrea Gail EmptyThu Mar 04, 2021 11:47 am
A second coat on the bottom of the hull - nearly finished the painting now just need to touch up the green on the lower rubbing strip. Added some more white to the tower and other bits, then started on the winch drums for the stern. Very fiddly and rubbish dowel which tears when trying to saw it to length Rolling Eyes .
Billings Adrea Gail Dscn1959
Swab
Swab
PostSubject: Re: Billings Adrea Gail   Billings Adrea Gail EmptyThu Mar 04, 2021 7:11 pm
How do the Humbrol acrylics brush then enamels yes but the quality has declined, I've never used them at all. I've got a really good airbrush but it's only good for fine work on my plastic kits.
PostSubject: Re: Billings Adrea Gail   Billings Adrea Gail EmptyThu Mar 04, 2021 9:06 pm
The enamels are of very variable quality which is why I started using acrylics. They are reasonably easy to brush and the quality is more consistent.
PostSubject: Re: Billings Adrea Gail   Billings Adrea Gail EmptyFri Mar 05, 2021 11:08 am
I finished touching up the paintwork on the outside of the hull. I just have to paint the rudder and prop and fit them. The prop is too big bounce - luckily this is a static model and it doesn't have to actually turn Shocked
I have been making the winches - there are four of them. These are now ready for painting after a coat of sanding sealer. I have been following the instructions and making blocks from three or more layers of laser cut ply. Today I found that the kit actually includes block wood cut to the correct sizes bounce bounce bounce bounce
Billings Adrea Gail Dscn1960
Billings Adrea Gail
» Billings Norden
» Billings St Canute
» Billings fittings help.
» Billings propshaft size
» Billings RNLI Lifeboat
