 CLIFFS VICTORY
guzzijohn
CLIFFS VICTORY Empty
PostSubject: CLIFFS VICTORY   CLIFFS VICTORY EmptyWed Mar 10, 2021 8:38 pm
After a decade collecting dust this build restarts With 3 motorcycles and 2 snowblowers moved out now my shop can function. also took pix of foam carving tools. Rough carved engine room w prop shaft and motor. Thanx for all the input for motor esc selection. I sent pix of hull earlier but don't know if they're here. It seems that I can send 3 at a time. Are others stored and can be transferred or can I send more as replies?
CLIFFS VICTORY 000_0019
CLIFFS VICTORY 000_0018
CLIFFS VICTORY 000_0020
PostSubject: Re: CLIFFS VICTORY   CLIFFS VICTORY EmptyThu Mar 11, 2021 7:13 am
GJ
You can have as many photos as you want in a post, but you can only upload 3 at a time to the image server. When you've uploaded three and copied them to your post, Click Remove and you can then upload three more.
CLIFFS VICTORY Imgser10
guzzijohn
PostSubject: More pix   CLIFFS VICTORY EmptyThu Mar 11, 2021 2:22 pm
CLIFFS VICTORY 000_0021
CLIFFS VICTORY 000_0022
CLIFFS VICTORY 000_0023
guzzijohn
PostSubject: HAPPY EQUINOX UPDATE W PIX   CLIFFS VICTORY EmptyWed Mar 24, 2021 8:51 pm
I've been mostly working to buy the electro stuff lately. Today is rainy so had to do something. Rudder has been planned out after finding useable stuff in my scrap bin. Had a skinny copper tube that a tent stake fit in but too wimpy. Dug deeper and found 1/4" rod and stainless tube. Can thread rod for nuts to hold lever arm. And an old bronze door plate for rudder. Easy to braze together. Should be very strong and weighty. Will pay special attention to reinforcement of shaft tube. The deck has been a worry as the poly material I found is curved from being rolled up could've been from curved tank too. Found many ideas on line from boiling in microwave to roasting in a barbeque. But to my surprise a heat gun and weight did the trick. CLIFFS VICTORY 000_0024
CLIFFS VICTORY 000_0025
CLIFFS VICTORY 000_0026
CLIFFS VICTORY
» Constructo HMS Victory
