Iam going to build a pair of these boats 1">1froot so 39" scale in Pine on Oak frames.
This is my first attempt at model boats but have plenty of experiance in wood working and DIY However before i get posting on the forum i would like to say ive just had a bad experiance on an other forum and the lack of understanding of how i have to do things and why i may ask thing the way i do which is why i left that forum. Iam also going through a 4 1/2y brevement which has left me with no motivation /no life even before the covid and thats why these models will be my escape and a new begining.
Full Ahead likes this post
Sorry to hear you have a bad experience on another Forum. I can assure you that we do not allow negative criticism, or attacks on members, on this Form. I as Moderator and Roadrunner, the owner, are very definite about that. We will do our best to answer your queries and give any advice we can. I look forward to seeing your build as it progresses. Posting photos is very easy on this Forum. There is a built in image host, and there is no limit to photo sizes.
Barrie Form Moderator
REMUS likes this post
REMUS Deck Hand
Posts : 11 Join date : 2021-03-11 Location : Leicestershire
Subject: Build help Thu Mar 11, 2021 3:21 pm
My Boats will be 39" long and approz 13" on the beam and built of pine on oak frames so given thing info what type & size of motor would i need with a single prop .Also would i need two controlers two opperate two boats ?
I think that a 385 class motor should be adequate. This would be a good motor to use with the ESC below. https://www.mtroniks.net/prod/Motors-For-RC-Boats/M400.htm You could swap a speed controller between two models, but it would complicate the wiring, and probably introduce a point of weakness. I would suggest a 15 amp ESC from Mtroniks like this https://www.mtroniks.net/prod/Boat-Speed-Controls/Viper-Marine-15-pnp.htm It is certainly possible to swap a receiver between boats. These use plug connections anyway, so are easier to move.
REMUS Deck Hand
Subject: Build help Thu Mar 11, 2021 6:18 pm
Barrie You have mentioned Brushed motor .What are the pros & cons for a brushless motor
I suggested a brushed motor as its easier to specify the size you need. With brushless you have to consider more factors, plus these were originally designed for aircraft use where high revs are required, and they only have to go in one direction. Things have improved a lot, and some now have good slow running capabilities. There are now some good waterproof escs offering forward and reverse - avoid the car ones as they have a brake function which can be a problem.
I have used a brushless motor in a small model, and I think the combination I used would suit your models, but I can't be sure. I used a 1000Kv motor and a 30 amp marine ESC. I can supply details if you wish, although I did buy from China.
I am no expert on brushless!
REMUS Deck Hand
Subject: update Wed Dec 21, 2022 4:45 pm
Just bought a clarke scrol saw so started to cut out the templates in 3mm ply and make up the keel The boat in question is rotting away in a uk North Norfolk creek and as there are no plans so ive been searching for photoes on the net of the hull out of the water to get the shape correct I will post some pics later
REMUS Deck Hand
Subject: Romulus & Remus when new in 1955 Thu Dec 22, 2022 10:27 am
REMUS Deck Hand
Subject: Angled tramson Thu Jan 05, 2023 7:23 pm
Looking fo idear`s on how to extend /build the angled pointed tramson that these boats had.
REMUS Deck Hand
Subject: Angled transom Sat Jan 21, 2023 3:56 pm
Anyone ?
Subject: Re: 1950s Whitstable Fishing Boat Sat Jan 21, 2023 4:04 pm
Make the deck to the shape you want. Plank the hull bottom over length. When completed you can cut it to shape. You should be able to 'fill the gap' with a two part transom. It appears that the transom doesn't extend above deck.
Hope this helps,
REMUS Deck Hand
Subject: Plans Fri Feb 10, 2023 4:39 pm
I now have had the drawing scaled up and printed on A0 full size sheet as Romulus and Remus will be 39" long 13" beam .
