Subject: Fraser River Tugboat Fri Jun 10, 2022 6:39 pm
I've made a start. The first bit was easy
The hull framework slotted together beautifully. However, things then started to get more difficult
The bottom skins (if that is what these are) are not wide enough, and the side skins are too deep I also think there should be a keel, but there is nothing supplied or any provision for fitting one to the framework.
I am reluctant to glue the framework until I am reasonably sure its correct, so more pondering and research.
Fred 1948, Swab and Martin555 like this post
Subject: Re: Fraser River Tugboat Sat Jun 11, 2022 3:18 pm
It looks as though I have been done
As you can see, the deck does not fit the hull I am fairly sure the hull has nothing to do with the other items I received. I suspect the parts other than the hull are designed for the plastic hull version of this model. Unfortunately it was described as "for parts" so I have no recourse to the seller or ebay
I will have to try to find a plan or hull which I can use to use the superstructure parts.
For now I've started on Artur - so watch this space for Artur Mk 2
Fred 1948 Forum Sponsor
Subject: Re: Fraser River Tugboat Sun Jun 12, 2022 8:31 am
That is a bummer Barriew, good luck on your search.
Fred
Subject: Re: Fraser River Tugboat Sun Jun 12, 2022 8:45 am
Mobile Marine Models have a Stan Tug hull that I think I could use. It will be easier than trying to design and build a hull I'll build Artur then have another think.
Swab Master
Subject: Re: Fraser River Tugboat Sun Jun 12, 2022 11:25 am
Those bottom skins wouldn't make up a deck would they? your picture doesn't give a good view (no criticism) but the shape looks right.
Subject: Re: Fraser River Tugboat Sun Jun 12, 2022 1:48 pm
They could do - but that's not the only thing wrong. There's too much ply in the structure. No space to install motors etc. Lots of it would have to be cut away. Its almost as though its designed to make a mould for a fibreglass hull - which would still be too big
Swab Master
Subject: Re: Fraser River Tugboat Sat Jun 18, 2022 1:06 pm
You love a challenge don't you?
Subject: Re: Fraser River Tugboat Sat Jun 18, 2022 1:13 pm
But not so big
Subject: Re: Fraser River Tugboat Mon Jul 11, 2022 11:12 am
So having put Artur to one side during the hot weather, I started to examine what was left in this package after removing the components of the wooden hull. It looks to me as though there are bits of a possible third model here as well. I can see how to build a suitable wheelhouse with the remainder. There is a good selection of small fittings, two good prop shaft assemblies and two rudders. The props are 50mm, which I think is a bit too big. On this basis I think it will be worthwhile ordering a Damen Stan 1605 hull from Mobile Marine Models, and making the superstructure fit that. Watch this space - but don't hold your breath.
Subject: Re: Fraser River Tugboat Fri Aug 12, 2022 3:26 pm
Hi Barrie,
Interesting.
Would it be possible to see what else is in the kit box ?
Looking at this kit ( see link) it looks the frames fit into a pre-made hull.
https://www.ebay.com/itm/174783601126
Martin555.
Subject: Re: Fraser River Tugboat Sat Aug 13, 2022 6:57 am
Hi Barriew,
I have been thinking about this conundrum and I think that possibly the two pieces of ply that look as if they go on the bottom of the hull are actually the main deck and the smaller deck section is the insert after the main deck has the middle cut out.
Looking as the shape of the smaller deck and comparing it with the link that i attached to my last post.
Martin555.
After a lot of thought I have decided that the large wooden 'hull' is not in fact meant to be used to make a powered model. Given the egg box construction there is no way that you could get a motor etc into it. I now think this may be intended as a plug to make either a fibreglass or vac moulded hull. I also doubt it is for the other parts - the hull would be too big. This will now probably go in the recycling bin.
This is the end of this thread. When I buy a hull and start using the superstructure items I will start a new thread.
