 Shortening boat propeller shafts
Dykedweller
Shortening boat propeller shafts Empty
PostSubject: Shortening boat propeller shafts   Shortening boat propeller shafts EmptySun Mar 03, 2024 12:48 pm
I am making a scratch built balsa hull boat from the plans of the full sized craft which necessitates a very short propellor shaft. As these are not available I am seeking advice on the feasibility of purchasing a standard shaft, removing one of the bushes and shortening the tube before replacing the bush.
Has anybody done this if so any advice would be very helpful.
gribeauval
gribeauval
PostSubject: Re: Shortening boat propeller shafts   Shortening boat propeller shafts EmptyMon Mar 04, 2024 9:42 am
No problem, I do it all the time.
Just make sure you the cut end is square and remove ALL the metal debris before you refit the bearing. Also if it is a little loose then a drop of superglue or solder to make sure it doesn't drop out.
Mike
» Boating where boats dont go?
» Southampton Model Power Boat Club, Racing Boat.
» Boat ID please!
» Boat ID Please!
» Row Row, Row your Boat....!
