Subject: TOOLS
The real info..........
DRILL PRESS: A tall upright machine useful for suddenly
snatching flat metal bar stock out of your hands so that it
smacks you in the chest and flings your beer across the
room, splattering it against that freshly painted airplane
part you were drying.
WIRE WHEEL: Cleans paint off bolts and then throws them
somewhere under the workbench with the speed of light. Also
removes fingerprint whorls and hard-earned guitar calluses
in about the time it takes you to say, "Ouch...."
ELECTRIC HAND DRILL: Normally used for spinning pop rivets
in their holes until you die of old age.
PLIERS: Used to round off bolt heads.
HACKSAW: One of a family of cutting tools built on the Ouija
board principle. It transforms human energy into a crooked,
unpredictable motion, and the more you attempt to influence
its course, the more dismal your future becomes.
VISE-GRIPS: Used to round off bolt heads. If nothing else is
available, they can also be used to transfer intense welding
heat to the palm of your hand.
OXYACETYLENE TORCH: Used almost entirely for lighting
various flammable objects in your shop on fire. Also handy
for igniting the grease inside the wheel hub you want the
bearing race out of.
HYDRAULIC FLOOR JACK: Used for lowering an automobile to the
ground after you have installed your new disk brake pads,
trapping the jack handle firmly under the bumper.
EIGHT-FOOT LONG DOUGLAS FIR 2X4: Used for levering an
automobile upward off a hydraulic jack handle.
TWEEZERS: A tool for removing wood splinters.
PHONE: Tool for calling your neighbors to see if he has
another hydraulic floor jack.
SNAP-ON GASKET SCRAPER: Theoretically useful as a sandwich
tool for spreading mayonnaise; used mainly for getting dog
**** off your boot.
E-Z OUT BOLT AND STUD EXTRACTOR: A tool ten times harder
than any known drill bit that snaps off in bolt holes you
couldn't use anyway.
TWO-TON ENGINE HOIST: A tool for testing the tensile
strength on everything you forgot to disconnect.
CRAFTSMAN 1/2 x 16-INCH SCREWDRIVER: A large pry bar that
inexplicably has an accurately machined screwdriver tip on
the end opposite the handle.
AVIATION METAL SNIPS: See hacksaw.
TROUBLE LIGHT: The home mechanic's own tanning booth.
Sometimes called a drop light, it is a good source of
vitamin D, "the sunshine vitamin," which is not otherwise
found under cars at night. Health benefits aside, it's main
purpose is to consume 40-watt light bulbs at about the same
rate that 105-mm howitzer shells might be used during, say,
the first few hours of the Battle of the Bulge. More often
dark than light, its name is somewhat misleading.
PHILLIPS SCREWDRIVER: Normally used to stab the lids of
old-style paper-and-tin oil cans and splash oil on your
shirt; but can also be used, as the name implies, to strip
out Phillips screw heads.
AIR COMPRESSOR: A machine that takes energy produced in a
coal-burning power plant 200 miles away and transforms it
into compressed air that travels by hose to a Chicago
Pneumatic impact wrench that grips rusty bolts last over
tightened 58 years ago by someone at ERCO, and neatly rounds
off their heads.
PRY BAR: A tool used to crumple the metal surrounding that
clip or bracket you needed to remove in order to replace a
50ยข part.
HOSE CUTTER: A tool used to cut hoses too short.
HAMMER: Originally employed as a weapon of war, the hammer
nowadays is used as a kind of divining rod to locate the
most expensive parts not far from the object we are trying
to hit.
MECHANIC'S KNIFE: Used to open and slice through the
contents of cardboard cartons delivered to your front door;
works particularly well on contents such as seats, vinyl
records, liquids in plastic bottles, collector magazines,
refund checks, and rubber or plastic parts.
DAMMIT TOOL: Any handy tool that you grab and throw across
the garage while yelling "DAMMIT" at the top of your lungs.
It is also the next tool that you will need.
EXPLETIVE: A balm, usually applied verbally in hindsight,
which somehow eases those pains and indignities following
our every deficiency in foresight.
