| Close Up Shots | |
Norseman Master
Posts : 219 Join date : 2011-06-11 Location : Liverpool
| Subject: Close Up Shots Sun Nov 06, 2011 12:54 pm | |
| Hi Guys
I was looking at AlanP's scratch build of a Shrimper - and beeping marvellous it is too. The build always looks spectacular in Alans shots - so how do modellers get the photos so close and so clear? I can never snap anything up close and be remotely satisfied with the shot. My current camera's focus has become unreliable since my daughter borrowed it, and I'm now considering what to replace it with - so it's a really good time to ask the question.
Dave | |
| Subject: Re: Close Up Shots Sun Nov 06, 2011 1:10 pm | |
| Hi Dave, It's not the make of camera so much these days as they all seem to be keeping abreast. The word to look out for is 'Macro', as this will give the close up focus you are looking for. I've just stuck my finger under the lens for you and it's quite good what can be picked up. i suppose this might be close enough. Cheers ken [url][/url] | |
HS93 Lost But Never Forgotten R.I.P
Posts : 69 Join date : 2011-06-11 Location : merseyside
phil winks Master
| Subject: Re: Close Up Shots Sun Nov 06, 2011 5:38 pm | |
| The main question seems to have been answered but to re-iterate
1. use macro mode
2. avoid flash and use other lighting
3. use a tripod and either self timer or a remote trigger device to eliminate even minor shaking
4. select a plain preferably dark background
5. keep the lense clean
Follow these five simple rules and the results from even most of the cheapest digital camera's will improve dramatically | |
Mark Able Seaman
Posts : 42 Join date : 2011-06-11 Location : Portsmouth uk
| Subject: Re: Close Up Shots Sun Nov 06, 2011 6:04 pm | |
| [img:8cb6]http://rcmb.forumotion.com/ [/img] Another useful feature is a good zoom,this is from my fujifilm which has macro,but i zoomed in on this critter | |
Norseman Master
| Subject: Re: Close Up Shots Sun Nov 06, 2011 7:35 pm | |
| Thanks lads, Ok - I'm getting the picture now (sorry just couldn't resist that one). I've checked my old camera for a macro setting and found one tucked away in a sub menu. It works but the camera is a bit hit and miss focus wise - I need to take some photos this evening about problems with my old Hale's Spraymaster so we'll see how I do. Regards Dave | |
AlanP Master
| Subject: Re: Close Up Shots Sun Nov 06, 2011 9:31 pm | |
| So, what is Macro, and where do I look look for it on the camera?
Alan | |
Footski Master
| Subject: Re: Close Up Shots Sun Nov 06, 2011 10:23 pm | |
| Alan,
Macro is the ability of the lens to focus at very close distance to the subject, rendering it much bigger in the picture. It does reduce the depth of field, or amount in focus to a few millimeters in many cases. On compact cameras it is not really a true macro, but as close as the cameras limitations will allow. True macro lenses on DSLR cameras cost many hundreds to even thousands of pounds.. | |
Norseman Master
| Subject: Re: Close Up Shots Sun Nov 06, 2011 11:50 pm | |
| Hi Alan
Just got it out and this is my route to macro, Menu - Focus - Select - Macro
todays the first time I've seen it.
Dave | |
AlanP Master
| Subject: Re: Close Up Shots Mon Nov 07, 2011 4:39 pm | |
| Had to get the book out in the end dave, found it, tried it, WOW | |
| Subject: Re: Close Up Shots Mon Nov 07, 2011 4:52 pm | |
| the only problem is that you can see to much , scratches on brass etc that you could not see looking at it normally can stand out so can paint blemishes , the way my boats are going these days ill be using a bit of Vasaline over the lens or a nice soft filter.
Peter | |
Footski Master
| Subject: Re: Close Up Shots Mon Nov 07, 2011 5:50 pm | |
| - HS93 wrote:
- the only problem is that you can see to much , scratches on brass etc that you could not see looking at it normally can stand out so can paint blemishes , the way my boats are going these days ill be using a bit of Vasaline over the lens or a nice soft filter.
Peter Nah, Just set the camera to macro and shoot from 6 feet......You will not see any scratches then!! | |
Norseman Master
| Subject: Re: Close Up Shots Mon Nov 07, 2011 7:49 pm | |
| Glad it worked for you Peter - it really helps me apprecite a guys hard work when I can see those crisp close ups I need a new camera though - I had hoped to just use my old one in the workshop for macro but the focus is too hit and miss now. It took me hours last night to get the few shots I needed. Serves me right for letting my daughter borrow it. I really liked my Casio Exilim Z500 5 mgpxl, small, nice features and easy to use. Repair would probably be posible but I bet I'd just get screwed by the shop - I read a few message boards re jessops shenanigans on repairs. Any reccomendations guys Dave | |
Mark Able Seaman
| Subject: Re: Close Up Shots Mon Nov 07, 2011 9:15 pm | |
| Fujifilm s1730
3x macro,15xzoom and hundreds of other features,excellent camera,around £150 | |
| Subject: Re: Close Up Shots Mon Nov 07, 2011 11:39 pm | |
| Have a look at the pannasonic range , befor anybody comes back with hundreds of cheaper places this is where I would buy because of the cover they give and no quible return.
you buy what you can afford
Peter
http://www.johnlewis.com/Electricals/Cameras+_26+Camcorders/Cameras+_26+Camcorders/All+Cameras/Panasonic/-/Brand/4002/ProductCategory.aspx?tmcampid=38&tmad=c&s_kenid=7a012e50-3eb6-c8e9-b3da-00006a811b32&s_kwcid=3x1555286
Mine was the older version of this it was about £135 at the time
http://www.johnlewis.com/231203436/Product.aspx | |
Footski Master
| Subject: Re: Close Up Shots Tue Nov 08, 2011 7:47 am | |
| The Panasonic range are truely very good cameras and range from simple point and shoot upto much more advanced cameras. Have a look at Nikon's range too. | |
Norseman Master
| Subject: Re: Close Up Shots Tue Nov 08, 2011 12:03 pm | |
| Does something very clever happen with our banner advert at the top of the page? I have just noticed it advertising John Lewis and Panasonic cameras Both are mentioned in this thread Dave | |
Footski Master
| Subject: Re: Close Up Shots Tue Nov 08, 2011 12:09 pm | |
| Erm, not quite sure here Dave....I see nothing except the proper banner. It may be you have pop ups enabled on your system.,. | |
| Subject: Re: Close Up Shots Tue Nov 08, 2011 1:15 pm | |
| I think you will find it's the last things you searched for with Google etc it tags on to web pages if you go on sky news you will proberley get the same.
Peter | |
| Subject: Re: Close Up Shots Tue Nov 08, 2011 2:16 pm | |
| think twice about olimpus
http://news.sky.com/home/business/article/16105895
Peter | |
| Subject: Re: Close Up Shots | |
| Close Up Shots | |
