 Water cooling
Water cooling Empty
PostSubject: Water cooling   Water cooling EmptyTue Mar 13, 2012 9:30 pm
Can anyone tell me where to get the aluminium tubing from so that I can make my own motor cooling coils.
Water cooling Empty
PostSubject: Re: Water cooling   Water cooling EmptyTue Mar 13, 2012 9:39 pm
Hi Alan, I would use copper brake pipe, it bends a lot easier than ally without kinking. Bend it around a former which is slightly smaller in diameter than the motor can....
W..
Water cooling Empty
PostSubject: Re: Water cooling   Water cooling EmptyWed Mar 14, 2012 9:20 pm
Thanks Windy, but I was realy looking for aluminium in order to keep the weight down.
Water cooling Empty
PostSubject: Re: Water cooling   Water cooling EmptyThu Mar 15, 2012 1:15 am
Alan you'll need reasonably thick walled tubing otherwise it will kink even after annealing even the thicker walled tubing will need to be re-annealed each 1/4 turn to avoid kinks copper brake tubing is friendlier to work and would only need annealing once or twice for the job.
The smaller the Radius of the bends you require the harder it will be to achieve.
Damien.
Water cooling Empty
Water cooling
» Water Jet ESC
» Glass of water
» Getting models into the water
» CROSS REFERENCING??
