| Sanding sealer | |
AlanP Master
| Subject: Sanding sealer Sun Mar 18, 2012 9:56 pm | |
| After sealing some small balsa boats (Air boats) with sanding sealer, sanding in between coats and leaving enough time for each coat to dry, then primer and top coats resulting in a realy good finish.
But then after a short time, a couple of weeks or so, there are tiny hair line cracks all over the finished surface.
Any thoughts lads.
Alan | |
Footski Master
| Subject: Re: Sanding sealer Mon Mar 19, 2012 7:32 am | |
| Was there any moisture in the balsa at all before you sealed it? Just a thought. | |
| Subject: Re: Sanding sealer Mon Mar 19, 2012 7:39 am | |
| It doesn't help you Alan, but I now use Easy Kote to seal Balsa etc. Its a water based resin that really hardens balsa. It can be used with glass fibre or tissue, or just on its own.
AlanP Master
| Subject: Re: Sanding sealer Mon Mar 19, 2012 8:15 pm | |
| Where do you get Easy Kote from Barrie, I'v googled it and it seems to be an industrial floor sealer.
Alan | |
| Subject: Re: Sanding sealer Mon Mar 19, 2012 10:32 pm | |
| Any model shop stockist of DeLuxe Materials should have it. [url]www.deluxematerials.com/products_building.html [/url] Mike | |
| Subject: Re: Sanding sealer Tue Mar 20, 2012 7:08 am | |
| - AlanP wrote:
- Where do you get Easy Kote from Barrie, I'v googled it and it seems to be an industrial floor sealer.
Alan Gribeauval is correct - its a Deluxe Materials product, but its Eze-Kote - my mistake I think I probably bought mine from Squires. Barrie | |
AlanP Master
| Subject: Re: Sanding sealer Tue Mar 20, 2012 6:35 pm | |
| Thanks lads, I'll get some and give it a try Alan | |
| Subject: Re: Sanding sealer Thu Dec 20, 2012 12:51 pm | |
| This sanding sealer is it turpentine based or Acetone based no one seems to know what I'm talking about when I ask about it here in Oz. Damien.
| Subject: Re: Sanding sealer Thu Dec 20, 2012 1:17 pm | |
| Damien,
Its based on aircraft dope - people used to make it by adding talcum powder to clear dope, although the stuff you can buy uses a different filler I think.
| Subject: Re: Sanding sealer Thu Dec 20, 2012 10:20 pm | |
| Subject: Re: Sanding sealer | |
| Sanding sealer | |
