 GRRRRRRRRRRRRRRRRRRRRR
GRRRRRRRRRRRRRRRRRRRRR Empty
PostSubject: GRRRRRRRRRRRRRRRRRRRRR   GRRRRRRRRRRRRRRRRRRRRR EmptyThu Dec 06, 2012 10:21 am
Bought a 4ch rc set on ebay on the 3rd dec got an email to night saying item out of stock should have more in 10 days.
call themselves revolutionshop_uk but based in Hong Kong
PostSubject: Re: GRRRRRRRRRRRRRRRRRRRRR   GRRRRRRRRRRRRRRRRRRRRR EmptyThu Dec 06, 2012 11:17 am
Damien,
Contact them and ask for a refund and mark them down. They will not like that if they are a good ebay company.
PostSubject: Re: GRRRRRRRRRRRRRRRRRRRRR   GRRRRRRRRRRRRRRRRRRRRR EmptyThu Dec 06, 2012 5:04 pm
I would report them to eBay. Sellers are supposed to only list stock items.
PostSubject: Re: GRRRRRRRRRRRRRRRRRRRRR   GRRRRRRRRRRRRRRRRRRRRR EmptyFri Dec 07, 2012 2:57 am
I had a go at them I got an email with a code for $5 off my next purchase no much to interest me though mostly stock car, helicopter an high speed boats.
Damien.
PostSubject: Re: GRRRRRRRRRRRRRRRRRRRRR   GRRRRRRRRRRRRRRRRRRRRR EmptyFri Dec 07, 2012 10:53 am
Then I find only if the next order is over 50 dollars when it arrives I think negative feedback is in order.
PostSubject: Re: GRRRRRRRRRRRRRRRRRRRRR   GRRRRRRRRRRRRRRRRRRRRR EmptyFri Dec 07, 2012 11:21 am
Don't just give negative feedback - report them to eBay. They are breaking ebay's terms.
PostSubject: Re: GRRRRRRRRRRRRRRRRRRRRR   GRRRRRRRRRRRRRRRRRRRRR EmptyFri Dec 07, 2012 12:53 pm
report to ebay, and put in a cancellation of transaction to ebay and then if you payed via paypal, put in a claim for your money back.
PostSubject: Re: GRRRRRRRRRRRRRRRRRRRRR   GRRRRRRRRRRRRRRRRRRRRR EmptyFri Dec 28, 2012 1:35 am
Purchased and paid for on 3/12/2012 got notification today it was posted 26/12 it usually takes around 45 days to get from Hong Kong to Aust if not here at 45 days from purchase I'll start dispute proceedings.
D.
PostSubject: Re: GRRRRRRRRRRRRRRRRRRRRR   GRRRRRRRRRRRRRRRRRRRRR EmptyFri Dec 28, 2012 11:38 am
blimey Damien......it takes half that time to get from HK to UK, at the most..........something wrong there.
PostSubject: Re: GRRRRRRRRRRRRRRRRRRRRR   GRRRRRRRRRRRRRRRRRRRRR EmptyFri Dec 28, 2012 11:56 am
It doesn't matter what part of that region China, Hong Kong Sth Korea or Vietnam they all take 5 to 6 weeks to get here where UK is 7 days and USA around 10 days.
They had 3 separate listings for more than 10 available but had no stock at all,
I have reported them to ebay and I've started a Paypal dispute because Sunday is the 45 day and ebay shows any disute needs to be lodged by the 29th If the gear arrives I can always cancel the Dispute.
I guess there is the possibility every thing from that region gets inspected by customs.
PostSubject: Re: GRRRRRRRRRRRRRRRRRRRRR   GRRRRRRRRRRRRRRRRRRRRR EmptySun Dec 30, 2012 4:09 pm
Stick with the complaint Damien it will cost nothing and they have broken ebays basic rules you may even get your money back also a negative feed back will help others avoid these dodgy traders
PostSubject: Re: GRRRRRRRRRRRRRRRRRRRRR   GRRRRRRRRRRRRRRRRRRRRR EmptyFri Jan 04, 2013 8:51 am
I received the gear on the 6th Jan marked as posted Honk Kong 29/12 2012 just shows slack HK sellers.
Anyway I tried to put the antenna in it went in but didn't connect with a screw as expected and when I turned the TX over there was quite a rattle I then discovered there was no ratchet on the throttle and the stick flopped up and down.
So I've started a Paypal dispute and asked for a refund.
PostSubject: Re: GRRRRRRRRRRRRRRRRRRRRR   GRRRRRRRRRRRRRRRRRRRRR EmptyFri Jan 04, 2013 9:58 am
I forgot to add there were no instructions at all and the gear has 4ch mixing and the Rx has 4 slots for servos and none for battery. when I asked for instructions I was sent a PDF of instructions for a small foam electric aircraft and in Chinese English.
PostSubject: Re: GRRRRRRRRRRRRRRRRRRRRR   GRRRRRRRRRRRRRRRRRRRRR EmptyFri Jan 04, 2013 1:20 pm
Damien,
Its quite common now to have no dedicated battery slot. Just use any, or if you need all slots for for servos, use a Y lead.
PostSubject: Re: GRRRRRRRRRRRRRRRRRRRRR   GRRRRRRRRRRRRRRRRRRRRR EmptyFri Jan 04, 2013 10:13 pm
Thanks Barrie, that's the battery ? cleared up I'll wait until Paypal dispute is settled before opening the Tx up to see what's wrong with it.
PostSubject: Re: GRRRRRRRRRRRRRRRRRRRRR   GRRRRRRRRRRRRRRRRRRRRR EmptySat Jan 05, 2013 12:01 pm
The seller rejected my request for a refund and want to send a new antenna , there's nowt wrong with the one that came with it, it just needs a screw to mounts it on & no thought of the other problems they appear to have skipped over them.
PostSubject: Re: GRRRRRRRRRRRRRRRRRRRRR   GRRRRRRRRRRRRRRRRRRRRR EmptyThu Jan 31, 2013 12:42 pm
The promised antenna has still not arrived I took it to paypal dispute after 10 day paypal decided if I returned it I'd be eligible for a partial refund having paid $31 for the gear Aust post wanted $34 to return it so I cancelled the dispute and left the seller a scathing 87 character negative feedback.
Please avoid Revolution shop UK on ebay.
TheRcModelBoatForum.com :: The Lake Side :: At The Lake Side-
