 Getting a good mix of resin and hardener
Getting a good mix of resin and hardener Empty
PostSubject: Getting a good mix of resin and hardener   Getting a good mix of resin and hardener EmptySun Feb 03, 2013 7:37 am
After having problems getting an even mix after mixing with various items and having sticky patched on the surface I thought of a small battery operated paint stirrer a check on ebay came up with several in UK & US they were expensive with post added, I already had a 65mm Graupner prop on a 4mm shaft I'd used for mixing Auto paint set me searching what I had in small props and found these.
Getting a good mix of resin and hardener DSCF2335_zpsdc29eea8
I have no idea where I got them l & rhd 30mm on 1.5mm shaft on screw driver speed it produced a mini cyclone effect in a cut down 50mm plastic pill bottle and the result was a perfect cure.
I expect these shaft/pros could be found in elcheapo kids boats.
Damien.
PostSubject: Re: Getting a good mix of resin and hardener   Getting a good mix of resin and hardener EmptySun Feb 03, 2013 4:18 pm
Damien if you fix a disc about twice the diametre of the prop on the shaft about an inch away from it splashing up is less of a problem when run in reverse and an even beter mix results
PostSubject: Re: Getting a good mix of resin and hardener   Getting a good mix of resin and hardener EmptyTue Feb 05, 2013 11:29 am
good idea.
PostSubject: Re: Getting a good mix of resin and hardener   Getting a good mix of resin and hardener EmptyTue Feb 05, 2013 7:25 pm
Just a little trick I picked up of a plasterer friend of mine who modified his plaster stirrer the same way
» Dean's Marine Tug YARRA
» Be extra careful adding Mekp hardener to resin.
» Good find
» Good news everyone....
» GOOD RIDANCE THANK GOD.
TheRcModelBoatForum.com :: Technical Pages :: Working With GRP-
