 I bought this for drilling in tight spots
I bought this for drilling in tight spots Empty
PostSubject: I bought this for drilling in tight spots   I bought this for drilling in tight spots EmptyFri Jun 21, 2013 8:28 am
I bought this for drilling in tight spots Drill_zpsdd8744c5
Ostensibly for drilling .8mm PCB holes but the chuck gives out at 1mm It will take 1mm > 1.5mm bits great for pilot holes for screws and brads.
However a 5 pole little motor, body length 40mm x 27 dia for GBP 2.13 = $3.59Au is not to be sneezed at, I've been offered a refund because the chuck was larger than stated but I might bye a few more for motor stocks.
PostSubject: Re: I bought this for drilling in tight spots   I bought this for drilling in tight spots EmptyFri Jun 21, 2013 1:04 pm
hi Damien,
that's a brilliant idea:Thumbup: for small drill bits thanks for shareing
PostSubject: Re: I bought this for drilling in tight spots   I bought this for drilling in tight spots EmptyFri Jun 21, 2013 1:09 pm
hi Damien,
do you have problems posting pictuers and now the the emoticons, should show thumbs up. I have given up trying to post pictuers.
PostSubject: Re: I bought this for drilling in tight spots   I bought this for drilling in tight spots EmptyFri Jun 21, 2013 1:17 pm
Thanks David I tried it at 12v and had trouble stalling the chuck so it's a little power house when I over this Flu I'll put an amp meter in line to check the current.
PostSubject: Re: I bought this for drilling in tight spots   I bought this for drilling in tight spots EmptyFri Jun 21, 2013 10:01 pm
that's a real , cracker of a tool Damien......think I'll have one of those
does it mean that you can actually change the drill bit should you break them or is the bit pressed into the "chuck head".
cheers, neil..
PostSubject: Re: I bought this for drilling in tight spots   I bought this for drilling in tight spots EmptySat Jun 22, 2013 12:05 am
It's a screw chuck for 1mm to 1.5mm drills it just won't hold the .8mm drill supplied Neil, a razor saw could be used to open it a bit for 2mm use.
PostSubject: Re: I bought this for drilling in tight spots   I bought this for drilling in tight spots EmptySat Jun 22, 2013 5:00 pm
thanks matey....very handy.
PostSubject: Re: I bought this for drilling in tight spots   I bought this for drilling in tight spots EmptyMon Nov 26, 2018 4:19 am
Whilst these little motor drills served their purpose well at the time my shaky hands cant hold it steady enough to be accurate.
While perusing an ebay sellers site I found a Mini drill press it takes .6mm to 6.5mm it set me searching for more like it.
This is the cheapest I found,
 https://www.ebay.com.au/itm/Bench-Top-Mini-Drill-Press-16000rpm-for-Wood-or-Metal-Hobby-Table-Top-0.6-6-.5mm/232907782210?autorefresh=true&autorefresh=true
I found a solution
So I treated myself to a Christmas present.
