| Jupiter, a Caledonian macBrayne Ferry | |
+13battleshipbuff Tug--Kenny carlmt vnkiwi wbeedie Roadrunner gribeauval Oldsmokey Cody614 davidjt Windy barriew Footski 17 posters |
| Subject: Re: Jupiter, a Caledonian macBrayne Ferry Sat Jan 10, 2015 8:38 pm | |
| Subject: Re: Jupiter, a Caledonian macBrayne Ferry Sat Jan 10, 2015 10:37 pm | |
| loving the brass work Neil _________________ I'm Not Anti-Social, I'm Anti-Stupid.
| Subject: Re: Jupiter, a Caledonian macBrayne Ferry Sat Jan 10, 2015 11:05 pm | |
| cheers matey.......how are you................did you have a good Christmas n new year. |
| Subject: Re: Jupiter, a Caledonian macBrayne Ferry Mon Jan 12, 2015 5:41 pm | |
| Subject: Re: Jupiter, a Caledonian macBrayne Ferry Tue Jan 13, 2015 12:37 am | |
| Subject: Re: Jupiter, a Caledonian macBrayne Ferry Tue Jan 13, 2015 5:16 pm | |
| `cheers matey. the main up / down companionways from the car deck to the upper deck have now been made....the thinner one which is the port and starboard companionway has been modified from an old one I made for the Clyde class lifeboat interior and I just added more treaders between the existing ones. the larger double one which is the main central companionway wan made of the same material and glued together with plastiweld. both these will be put into open moulds as easier to cast intricate parts with thin plastic walls ( no split halves) and moulded in polyurethane resin |
| Subject: Re: Jupiter, a Caledonian macBrayne Ferry Sun Jan 18, 2015 11:39 am | |
| Subject: Re: Jupiter, a Caledonian macBrayne Ferry Sun Jan 18, 2015 10:54 pm | |
| Subject: Re: Jupiter, a Caledonian macBrayne Ferry Mon Jan 19, 2015 6:37 am | |
| Subject: Re: Jupiter, a Caledonian macBrayne Ferry Mon Jan 19, 2015 8:21 am | |
| hi Damien, possibly..........I am being supplied with all the materials to build her as I wanted to build for my daughter................and then just handing all the moulds and stuff over to Andrew in Scotland......I don't know whether he and his club members are going are going to semi kit it or not..................however Andrew is a very busy man, being senior camera man for BBC Scotland and is all over the world filming..off in Sweden at the moment so whether he'll ever get time to turn it into a kit, I don't know. neil. |
| Subject: Re: Jupiter, a Caledonian macBrayne Ferry Mon Jan 19, 2015 8:54 am | |
| Ever thought of doing a paddle boat Hull? |
| Subject: Re: Jupiter, a Caledonian macBrayne Ferry Mon Jan 19, 2015 12:56 pm | |
| never thought of doing one Damien but have had thoughts of building a large scale WAVERLEY from a semi kit hull n wheels available for some years now, but the kit is over a grand to buy these days..........well out of my price bracket I'm afraid. |
wbeedie Able Seaman
Posts : 43 Join date : 2011-06-11 Age : 49 Location : Portree
| Subject: Re: Jupiter, a Caledonian macBrayne Ferry Mon Jan 19, 2015 8:07 pm | |
| looking good Neil, that hull could be quite versatile, you will have to do a build of the Hallaig ,Sconser/Raasay ferry one of the new hybrid ones built at the yard that when bust last year before being bought by the Clyde Blowers owner, think it was Fergusons | |
| Subject: Re: Jupiter, a Caledonian macBrayne Ferry Tue Jan 20, 2015 8:35 am | |
| Subject: Re: Jupiter, a Caledonian macBrayne Ferry Tue Jan 20, 2015 9:04 am | |
| Subject: Re: Jupiter, a Caledonian macBrayne Ferry Tue Jan 20, 2015 2:05 pm | |
| Damien...........the Lochinvar and Hallaig are two new hybrid ferries built in the last two years for Calmac...............sadly even though a superb concept and so quiet when you are sailing on them, they keep breaking down regularly and other ferries constantly have to shift around to sub for them........they are good looking ships and hopefully soon will get their woes sorted to give good service for years, but like anything new are having a wee bit o' bovver, lol
http://en.wikipedia.org/wiki/MV_Hallaig
http://en.wikipedia.org/wiki/MV_Lochinvar
https://www.youtube.com/watch?v=e9Wx0RDQbEI |
| Subject: Re: Jupiter, a Caledonian macBrayne Ferry Tue Jan 20, 2015 2:29 pm | |
| Subject: Re: Jupiter, a Caledonian macBrayne Ferry Tue Jan 20, 2015 3:15 pm | |
| hi neil , superb detail into mould making . I keep telling my self I must have a go, as you make it look so easy but no doubt it isn't easy. I am following with great interest. have you sorted the motors out now for this our are you still in test moad waiting to see how they develop and work . david | |
| Subject: Re: Jupiter, a Caledonian macBrayne Ferry Tue Jan 20, 2015 3:54 pm | |
| David, it is as easy as it looks, honestly.....there is absolutely no hidden problem to it at all, so long as you have bit of lego to make the boxes , some plasticine and your masters..................if you get stuck just give me a shout and we can sort it. .............as for the motors...........I have gone back to the original motors and belts and have cut the hole in the bottom of one of the vehicles to hide it coming through the deck.................it was in the end, the safest solution. neil. |
| Subject: Re: Jupiter, a Caledonian macBrayne Ferry Wed Jan 21, 2015 12:25 am | |
| Subject: Re: Jupiter, a Caledonian macBrayne Ferry Wed Jan 21, 2015 1:55 am | |
| Subject: Re: Jupiter, a Caledonian macBrayne Ferry Wed Jan 21, 2015 3:33 pm | |
| the flow tracks have been cut into the rubber and the first casts have been made. I use fast cast polyurethane none shatter resin for all my resin mouldings these days....a little more costly but far better. the split moulds can be seen sandwiched by some hard board outers.......just to keep the elastic bands from biting into squashing and distorting the rubber moulds. the open cast moulds are just what they say........pour the resin into the mould and then when cured sand down to the line of the mould. these castings will be ready and hard enough to take out of the moulds in around 30 minutes. |
| Subject: Re: Jupiter, a Caledonian macBrayne Ferry Wed Jan 21, 2015 4:18 pm | |
| Subject: Re: Jupiter, a Caledonian macBrayne Ferry Wed Jan 21, 2015 11:54 pm | |
| Hmmmm perhaps I'll give this molding caper a try one day in near future |
| Subject: Re: Jupiter, a Caledonian macBrayne Ferry Thu Jan 22, 2015 12:05 am | |
| it's as easy as it looks Damien.....try it. |
| Subject: Re: Jupiter, a Caledonian macBrayne Ferry Thu Jan 22, 2015 1:15 pm | |
| I think the lads who are building the other two boats I made the mouldings for are going to have the stanchions brass etched and hopefully will be sending me a set eventually. in the mean time I have a few fittings to clean and sort out, lol |
| Subject: Re: Jupiter, a Caledonian macBrayne Ferry Thu Jan 22, 2015 2:06 pm | |
| Subject: Re: Jupiter, a Caledonian macBrayne Ferry Thu Jan 22, 2015 2:11 pm | |
Windy Gunner
| Subject: Re: Jupiter, a Caledonian macBrayne Ferry Sat Jan 24, 2015 6:07 pm | |
| Hi Neil, I have found the PU resin only has a shelf life of 8 to 10 weeks once opened... The clear brown coloured part is hydroscopic..
Not that it lasts that long with me, I go through about 10 to 15kg a month!!
W.. | |
| Subject: Re: Jupiter, a Caledonian macBrayne Ferry Sat Jan 24, 2015 6:27 pm | |
| cheers mark..now I know why.....those two tins are at least 3 months old, lol............better get casting some stuff, lol |
| Subject: Re: Jupiter, a Caledonian macBrayne Ferry Fri Jan 30, 2015 4:28 pm | |
| there is a flange from the outer skin of the funnels on the back and top edge where the exhaust gasses from the engines come through and so knowing that I want this flange to come out in the moulding. I decided to "dress" the outer skin of the funnels with card. I built it up in two layers and then on the inner rim of each flange ran two further layers of card ( 120 gram) to build the thickness for moulding purposes. all the card was glued to the timber with household PVA glue. once it has all dried I will give it several coats of sanding sealer to harden it all up before putting more detailing on to it. |
Windy Gunner
| Subject: Re: Jupiter, a Caledonian macBrayne Ferry Fri Jan 30, 2015 7:33 pm | |
| Subject: Re: Jupiter, a Caledonian macBrayne Ferry Fri Jan 30, 2015 8:31 pm | |
| wondered what the b****y he** you were talking about for a minute mark, till I had another look, lol |
Windy Gunner
| Subject: Re: Jupiter, a Caledonian macBrayne Ferry Sat Jan 31, 2015 9:46 pm | |
| Don't worry Neil, I wonder what the hell I am waffling on about most of the time, must be the resin fumes getting to me!!
Mark.. | |
| Subject: Re: Jupiter, a Caledonian macBrayne Ferry Sat Jan 31, 2015 9:54 pm | |
| Subject: Re: Jupiter, a Caledonian macBrayne Ferry Mon Feb 09, 2015 5:56 pm | |
| Subject: Re: Jupiter, a Caledonian macBrayne Ferry Mon Feb 09, 2015 11:37 pm | |
| Subject: Re: Jupiter, a Caledonian macBrayne Ferry Tue Feb 10, 2015 1:05 am | |
| Subject: Re: Jupiter, a Caledonian macBrayne Ferry Wed Feb 11, 2015 11:17 am | |
| Subject: Re: Jupiter, a Caledonian macBrayne Ferry Wed Feb 11, 2015 11:44 am | |
| Subject: Re: Jupiter, a Caledonian macBrayne Ferry Wed Feb 11, 2015 9:08 pm | |
| putting it down to old past shelf life resin, but the first two funnels out the mould came out very nicely......just the flash line to titivate up and a few little areas where the resin didn't mix terribly well to sand, but the moulds have produced two nice replicas of the masters. and please do excuse the photos...having to use an old camera as can't find my other one |
| Subject: Re: Jupiter, a Caledonian macBrayne Ferry Thu Feb 12, 2015 8:12 am | |
| Subject: Re: Jupiter, a Caledonian macBrayne Ferry Thu Feb 12, 2015 8:46 am | |
| Subject: Re: Jupiter, a Caledonian macBrayne Ferry Thu Feb 12, 2015 6:47 pm | |
| she's not sunbaking lads.......just been run over by james bond in the db5, lol........as for weight............too heavy I think so am going to drill out the insides to get rid of some weight. |
| Subject: Re: Jupiter, a Caledonian macBrayne Ferry Fri Feb 13, 2015 7:38 pm | |
| , I didn't want to waste these two mouldings as I am running out of resin and don't envisage using any for a while so will build up the stock of new fitting masters first before buying more so I get the best shelf life so drilled them out this evening and they are about half the weight that they were, so reasonably satisfied with that. |
| Subject: Re: Jupiter, a Caledonian macBrayne Ferry | |
