Subject: Re: New begginings, Fast Patrol Launch Sun Nov 23, 2014 3:07 pm
barriew wrote:
Its rather strange with the big gap there. I don't think you will need any ventilation for the motor. I use those motors in larger hulls and they don't really get warm without any special ventilation.
Thanks Barrie, I have not a clue how hot things get.
LUQA Deck Hand
Posts : 14 Join date : 2014-06-07 Age : 80 Location : Derby East Mids
Subject: Fast Launch Sun Nov 23, 2014 3:46 pm
Hi Paul Yes, or you could put an angled piece of ply with a window cut in it. That would make it fully weather proof, and keep the look of a lot of broads cruisers. Hope this is some help. Regards David
Subject: Re: New begginings, Fast Patrol Launch Mon Nov 24, 2014 11:02 am
Yes I think that would be the simplest thing to do David but I might make it so it removable and a pram hood type of canopy could then be an option later.
Subject: Re: New begginings, Fast Patrol Launch Mon Nov 24, 2014 11:20 am
Masked up the red to paint the white on the sides and top deck yesterday, this went fairly good, got it in one coat but I can always put more paint on later. Removed the masking tape and it left loads of bits behind, moral is, don't buy cheap masking tape from the cheap shops, you know what they say "If it looks to good to be true it probably is".
The Masking.
Finished and under my antique "Pifco" heat lamp keeping warm
The results.
Just the font cabin roof to paint green today, but I can fit all the workings back in the boat today
Subject: Re: New begginings, Fast Patrol Launch Tue Nov 25, 2014 4:59 pm
I have today finished installing the workings and tested them, all seems OK.
To connect the rudder and servo I used an old push bike spoke, quite hard stuff and tough to bend but sorted it
It's very busy in the middle compartment, perhaps on reflection I should have spread things about a bit more...........
Still have the servo bed to paint, but it won't stop it floating
Not 100% happy with the paintwork but it'll do for now, also have two small jobs to do before testing.
Subject: Re: New begginings, Fast Patrol Launch Tue Nov 25, 2014 5:27 pm
Looking very good Are you aware that the switch on the ESC probably doesn't totally isolate the battery? They usually just switch off the receiver supply. I can't be certain about your EC, but that is what I have found. You either need a switch in the battery leads, or unplug the battery.
Subject: Re: New begginings, Fast Patrol Launch Tue Nov 25, 2014 6:52 pm
Thanks Barrie, I had no idea that might be the case, best put a switch in just to be safe I did put a fuse in as suggested earlier, which I also thought a good idea. Belt and braces comes to mind
Subject: Re: New begginings, Fast Patrol Launch Tue Nov 25, 2014 7:01 pm
You could always check if it does totally isolate by removing the fuse and replacing it with a multi-meter set to amps. If it shows any current flowing with the switch off, then a switch in the battery lead would be a good idea, or pull the fuse, to save getting to the lake with a flat battery
Subject: Re: New begginings, Fast Patrol Launch Tue Nov 25, 2014 11:42 pm
I've cut the centre wire on my brushless ESC's and use a separate battery, if the Rx is turned off the brushless motors on my air boats sing so I installed a switch in the main battery wires.
Subject: Re: New begginings, Fast Patrol Launch Tue Nov 25, 2014 11:53 pm
I've pulled the fuse for now, I will fit a switch at some point soon
Subject: Re: New begginings, Fast Patrol Launch Tue Nov 25, 2014 11:56 pm
Subject: Re: New begginings, Fast Patrol Launch Thu Nov 27, 2014 11:00 pm
hi,
the paint job looks great , are you ready for her maiden voyage yet our waiting till spring now. hope you have enjoyed the build I have. are you planning on some deck fittings.
Subject: Re: New begginings, Fast Patrol Launch Thu Nov 27, 2014 11:16 pm
davidjt wrote:
hi,
Hi David, funny how the camera can make things look better than they actually are, I'm happy with it for now but I think I will add a few bits and improve the paint job in time. I also have the other two to finish and am planning the build the "Duchess of Fife" Paddle steamer, I have the plans for this already
I'm hoping Robert my middle lad will be over at the weekend as I am off work with a bad back and can't bend down easily to put her in the water. There is a lake quarter of a mile away, as long as there are no fishermen there I'll be ok to use it.
Thanks for your comment and yes I have enjoyed the build. it's been handy having all you folk on here to guide an encourage me
Subject: Re: New begginings, Fast Patrol Launch Fri Nov 28, 2014 7:05 am
You may be OK without a switch or pulling the fuse. I did a check with one of my brushless set ups yesterday, and it doesn't draw any current when switched off with the switch on the ESC. I was basing my advice on the mTroniks ESCs for brushed motors, where you definitely need a switch in the battery line.
Subject: Re: New begginings, Fast Patrol Launch Fri Nov 28, 2014 8:05 am
Thanks Barrie, I'll get Richard my eldest lad to bring his multimeter at the weekend
Subject: Re: New begginings, Fast Patrol Launch Wed Aug 11, 2021 7:38 pm
Hi Troutrunner,
No you have not drifted back in time LOL!!
It must feel strange receiving a comment 7 years latter. Great work. She looks very nice indeed. Well done.
