| Our Springers | |
Mark Able Seaman
Posts : 42 Join date : 2011-06-11 Location : Portsmouth uk
| Subject: Our Springers Sat Jun 11, 2011 2:36 pm | |
| First my wifes boat and then my big springer [img] [/img] [img] [/img] | |
AlanP Master
| Subject: Re: Our Springers Thu Jun 23, 2011 10:22 pm | |
| i just love the hundreds of variations that you see of the springer......
if it weren't for these variations i don't suppose it would have the same appeal that it does, but boy oh boy, there are some that REALLY make me smile and brighten my day....little things like the toy story woodie on yours alan....just brilliant imagination.....sadly something i don't possess....if it ain't on the plans, i'm stuffed, and i really do admire that imaginative trait in you springer builders.. |
Mark Able Seaman
| Subject: Re: Our Springers Fri Jun 24, 2011 8:44 pm | |
| Thats the good thing about about springers Neil,the tops of them are endless. Your building qualities are superb,so maybe we will see a RNLI springer Mark | |
| Subject: Re: Our Springers Fri Jun 24, 2011 9:11 pm | |
| well, it's definately a thought...was wondering if i ever got round to one, what i could do one as. what i didn't realise was that they are modelled on the base of real vessels that have the hull shape....i always thought that they were originally a figment of someones imagination. how wrong can i be. cheers. neil |
Mark Able Seaman
| Subject: Re: Our Springers Fri Jun 24, 2011 9:33 pm | |
| Easy, Build a basic hull,then put one of great ribs that you made on top,bucket by pondside, hopefully public will give to a worthy cause | |
Footski Master
mattycoops43 Midshipman
Posts : 51 Join date : 2011-06-12 Location : Newport, South Wales
| Subject: Re: Our Springers Sat Jun 25, 2011 9:21 am | |
| HA HA HAAA! Still waiting to see that springer on the plane!!! | |
vnkiwi Deck Hand
Posts : 6 Join date : 2011-06-11 Age : 75 Location : Hamilton NZ
| Subject: my footy springer Fri Mar 16, 2012 7:19 am | |
| Don't have enough space for a full springer, so made this one at 66% size. Runs a 240 motor, SAB plastic prop and brass tube, on 7.2v rechargable NiMH, 2.4Ghz control. https://i.servimg.com/u/f46/17/36/24/73/scruff12.jpg https://i.servimg.com/u/f46/17/36/24/73/scruff13.jpg https://i.servimg.com/u/f46/17/36/24/73/scruff14.jpg
video here
https://www.youtube.com/watch?v=d3PZENXBFpQ
All balsa, and will be my rescue boat for my other boats I'm building
vnkiwi | |
| Subject: Re: Our Springers Fri Mar 16, 2012 11:15 am | |
| Very nice. Do you plan to have pushers on the bow ? ken | |
| Subject: Re: Our Springers Fri Mar 16, 2012 12:02 pm | |
| a bonny little model.............you could almost put it in your pocket.....
AlanP Master
| Subject: Re: Our Springers Fri Mar 16, 2012 4:25 pm | |
| Cute Alan | |
vnkiwi Deck Hand
| Subject: Re: Our Springers Fri Mar 16, 2012 5:33 pm | |
| Not at this stage Ken. Most of my boats are less than 24inches long and its fitted with a floating ball and line, (not attached in the video) so its mostly circle and tow back. But it does have a continuous soft rubber bumper all round. May fit one later if I think its required Here is a video link of the size boats I have at the moment
https://www.youtube.com/watch?v=QOHhgG6Ay3A
This is my 12" Fairey Swordsman, Both boats have the same power train and r/c, except that the swordsman runs 4.8v NiMH rechargeables (weight is critical) cheers kiwi | |
tarak Deck Hand
Posts : 5 Join date : 2019-10-18 Location : Devonport Tasmania
| Subject: just a help for my brothers Fri Oct 18, 2019 9:48 am | |
| I tried to post this before so i will try again. I was asked to help with the springer tug that my brothers and mate are and have built. so one brother Roy wanted to use a shottle drive so need some help so Graupner Schottel Drive Unit I (1761) then motors choice
MFA Torpedo 800 with Belt Drive Unit
MFA950D 385 Geared Motors Krick Max Gear 540 Type Motor 2.5:1 so I worked out a way to do some more calculations and could be used on any model I think I have been mainly working stuff out for real boats so made an adaption Model boat speed/ pitch/rpm calculations First change all to meters and seconds RPM = RPS Speed MPH to m/s pitch inches or cm or mm to metres V= speed wanted or known RPS P pitch into meter V= P/RPS P = V/RPS RPS = V/P Example tug Prop RPM = 560 P x 2.89” = per rev = 2.89X 60 = 173.4” = 4.38m V = 9.33 /4.38 = 2.13m/s = 7.66kph or 4.76mph Losses approx. 26% would then give 4.76 – 1.23 = 3.53mph The thrust ? Dwlbs Springer tug 1.5kg = 3.31lb So I make it 3.31lb will displace .0015m3 in fresh water or .05297cub ft To move it at 3.576 m/s or 8mph You will need 52.6 N or 11.82lb-force At 1.788m/s or 4 mph You will need 26.3N or 5.9lbs- force This will help https://www.omnicalculator.com/physics/buoyancy#buoyant-force-equation Loss about 5% about 7.6 mph or 3.8mphjust thought it may be interesting to you | |
| Subject: Re: Our Springers | |
| Our Springers | |
