| rudder tiller help | |
blue danube Deck Hand
Posts : 19 Join date : 2015-06-01 Age : 42 Location : gravesend
| Subject: rudder tiller help Tue Aug 18, 2015 7:37 pm | |
| anyone got any advice for a method of connecting a rudder tiller in a small space with little room to swing? | |
| Subject: Re: rudder tiller help Tue Aug 18, 2015 10:38 pm | |
| Some photo's of what you are trying to achieve would be a good idea, so folk can see your predicament | |
| Subject: Re: rudder tiller help Wed Aug 19, 2015 6:33 am | |
| Is this any help? Barrie | |
| Subject: Re: rudder tiller help Wed Aug 19, 2015 11:33 am | |
| I would move the tiller 45 degrees and cut off the top section.
You would then have to rotate the servo or arm to match.
hope this helps
ken | |
| Subject: Re: rudder tiller help Wed Aug 19, 2015 4:31 pm | |
| how do i post images here?
the problem i am having is the rudder post being quite far back towards the stern inner wall and lacking the space the tiller to rotate its a narrow-boat(mobile marines"Margaret") | |
| Subject: Re: rudder tiller help Wed Aug 19, 2015 6:20 pm | |
| If the rudder post is near the stern wall, then you need an asymmetric tiller arm, and possibly fixing the servo along side the rudder post. If necessary you can use a miniature servo - they have plenty of power for a canal boat. Look under Forum Rules - there are two topics on posting photos, one using Photobucket, one using the Forum mechanism. Barrie | |
| Subject: Re: rudder tiller help Thu Aug 20, 2015 4:37 pm | |
| i will get a Photobucket account set up and will get some pics up | |
| Subject: Re: rudder tiller help Thu Aug 20, 2015 9:00 pm | |
| Subject: Re: rudder tiller help Sat Aug 22, 2015 2:33 pm | |
| ok photos! sorted out the rudder swing issue by modding a commercial rudder fitting to a similar appearance to the kit tiller(the cream one which is quite bulky and was in no way going to fit) swapping the larger screw with a grub screw and sanding a little bit off the inner wall,still need some help sorting out servo setup and location,this is only my second boat and is a touch more complex and less roomy than the 1/16 springer
Last edited by blue danube on Sat Aug 22, 2015 2:43 pm; edited 1 time in total | |
| Subject: Re: rudder tiller help Sat Aug 22, 2015 2:41 pm | |
| Subject: Re: rudder tiller help Sat Aug 22, 2015 6:53 pm | |
| Yes - tricky, especially as you probably need a big swing to get any steerage. Have you tried asking Bryan at MMM? He's very helpful and if anyone has built one he will probably know how it was done.
| Subject: Re: rudder tiller help | |
