| Question from newbie to this forum | |
restin Deck Hand
Posts : 4 Join date : 2016-12-14
| Subject: Question from newbie to this forum Mon Dec 19, 2016 4:44 pm | |
| Hi Folk, This is my first post on this Forum and so I say hi to you all. I am currently building a Dumas Trojan F-31 it is 31 inches in length and 12 across the beam. Its quite a light build and the original boat was fast. All my previous builds have been 4 feet plus in length and I know what size motors, props etc for that size boat having had help from other Modelers. What size motors (Twin) would I need for the Trojan? They need to be Brushless and run on 3's Lipo.
Kind Regards and Thanks Glyn | |
restin Deck Hand
| Subject: Re: Question from newbie to this forum Tue Dec 20, 2016 3:41 pm | |
| Subject: Re: Question from newbie to this forum Tue Dec 20, 2016 5:29 pm | |
| Sorry Glyn, but my knowledge of brushless motors is limited. I think that Just Add Water is probably the one who may be able to help you. I have used brushless motors, but only one at a time and then selected by guess work. Barrie | |
restin Deck Hand
| Subject: Re: Question from newbie to this forum Tue Dec 20, 2016 5:43 pm | |
| Thanks for Response troutrunner and barriew | |
| Subject: Re: Question from newbie to this forum Tue Dec 20, 2016 6:37 pm | |
| I see you posted on the Mayhem forum. You should get a response on there - probably many more than one, and all different Barrie | |
| Subject: Re: Question from newbie to this forum Tue Dec 20, 2016 9:11 pm | |
| I'm sure that Dave Milbourn, aka inertia will be able to help, but as the guys say,
you'll probably get a million and one differing answers on mayhem, but wait till Dave has had his say...........the guru on all things electronic.
inertia Midshipman
| Subject: Re: Question from newbie to this forum Wed Dec 21, 2016 12:41 pm | |
| My experience with brushless motors is limited to one size (28mm outrunner) and just two model designs, both around 24" long with single screws. That said, the Dumas boat is quite beamy and should take a couple of these small motors quite easily, running on something like a 30mm 3-blade prop. The motor is a Turnigy 2822/17 1100kv. You'll find them on E-Bay or you can get them from HobbyKing (and good luck with their website!). The 30A Fusion Hawk ESC is very suitable, or the V3 Marine Brushless ESC from Component-Shop. You will, of course, need two speed controllers for twin motors, and I'd advise you to buy the appropriate programming card to make setting up easy. BTW the motors fit straight onto those 400-sized glass-nylon mounts with no modifications required (apart from slightly countersinking the holes in the mount). Good luck! I tried to insert an image but it's not playing ball, so here's a link to a photo of the installation in my 1/16 Huntsman 31 http://www.modelboats.co.uk/albums/member_photo.asp?a=33728&p=638643 I have a half-built Dumas Lord Nelson Victory 'tug' sitting in disgrace in my workshop. It's the worst kit I've ever had - by a large margin - and most of the contents thus far have had to be replaced or bodged. I'm now looking at having to make a superstructure from a very stiff foam plastic material which doesn't look as if it will bend in the way it's intended, so that will probably have to be replaced with either ply or styrene. To think what I could have bought with that £250... DM | |
restin Deck Hand
| Subject: Re: Question from newbie to this forum Wed Dec 21, 2016 3:02 pm | |
| Hi Dave, Thanks for the input, your suggestion on the 2822 turnigy Motor has been echoed by someone else so thanks for your input because you speak from knowledge and have helped me in the past. Thanks to for Prop. size and blade type that info was very important for me. (Good to see you on this Forum) I am not surprised that you had trouble with the Dumas kit as I am on my second Dumas kit and they both left a lot to be desired. They use iffy materials and their Die's must be worn or blunt. Thing is, I love some of their designs. Kind Regards Glyn | |
| Subject: Re: Question from newbie to this forum | |
