| Hull finishing for plank balsa boats (RC) | |
dockbuster Deck Hand
Posts : 2 Join date : 2019-11-17 Location : Cavendish, Vermont
| Subject: Hull finishing for plank balsa boats (RC) Sun Nov 17, 2019 6:51 pm | |
| I just started a Dumas Jolly Jay and are questioning their recommendations for sealing and finishing the balsa plank hull. I'd prefer not to use glass cloth and would like a sandable resin type product that can a receive a quality paint finish. Dumas recommended products seem to be out dated and some are no longer available. I'm looking for current recommendations and their success stories. Many thanks.... | |
| Subject: Re: Hull finishing for plank balsa boats (RC) Sun Nov 17, 2019 7:14 pm | |
| Try aircraft tissue and dope or sanding sealer. You can use resin instead if you wish. Easier to apply than glass cloth.
| Subject: Re: Hull finishing for plank balsa boats (RC) Sun Nov 17, 2019 7:43 pm | |
| - barriew wrote:
- Try aircraft tissue and dope or sanding sealer. You can use resin instead if you wish. Easier to apply than glass cloth.
Barrie much easier, and not half as much mess, especially using in confined spaces. |
inertia Midshipman
| Subject: Re: Hull finishing for plank balsa boats (RC) Thu Nov 28, 2019 5:29 pm | |
| Hope this helps. [You must be registered and logged in to see this link.]However the balsa planking in the only Dumas kit I ever had was so soft that nothing except resin and epoxy would have toughened it enough for even moderate handling. I replaced it all with obechi. DM | |
titanic12 Deck Hand
Posts : 22 Join date : 2019-11-11
| Subject: Hi Mon Dec 09, 2019 4:47 pm | |
| As well as the other solutions, (I have done a lot of tissue/dope with aircraft) I would first give the hull at least one good coat of water proof PVA/aliphatic resin. It should seal and strenthen the balsa. | |
| Subject: Re: Hull finishing for plank balsa boats (RC) Mon Dec 09, 2019 7:03 pm | |
| - titanic12 wrote:
- As well as the other solutions, (I have done a lot of tissue/dope with aircraft) I would first give the hull at least one good coat of water proof PVA/aliphatic resin. It should seal and strenthen the balsa.
all in favour of Aliphatic resin...…….love the stuff, but never thought of watering it down for a sealant...…..I learn something new every day. |
titanic12 Deck Hand
| Subject: Re: Hull finishing for plank balsa boats (RC) Mon Dec 09, 2019 7:57 pm | |
| I actually don't water it down, use it neat. | |
samc Deck Hand
Posts : 4 Join date : 2018-01-23 Age : 78 Location : wilmington NC
| Subject: I have a dumas Chris Craft commander Tue Dec 10, 2019 1:11 am | |
| It has 1/2 strips of balsa for the sides. i wish i had put on thin layers of plywood or something else i have been trying to finish it for a long time. dumas said cover the hull with Bodo 3m stuff for cars. it is a filler. a quart will do a 2-3 boats. then a another thinner filler i still can not get a good finish. spared a filler / primer, to fill in the little hole or lines on the side of the hull. have done this several times also. hard to get all of the imperfections out. very hard. never tried airplane tissue don't know how you would do that the bodo will seal everythng up I have no leaks you have to become a car body expert to get a good finish...i think. how you guys do it i don't know have tried everything i have read and asked questions and i'm still working on the hull. will be looking for your picture of your boat. to see how you made out samc | |
| Subject: Re: Hull finishing for plank balsa boats (RC) Tue Dec 10, 2019 1:27 am | |
| have a good read of our moderator Barrie's builds often in balsa or obeche,,,,,,,,,,a similar soft hard wood...…...and look at his finishing.
some very good tips on his build blogs, that's what we are here for. good luck. |
| Subject: Re: Hull finishing for plank balsa boats (RC) | |
