 Will Everard - Dropkeel
Stewpot
Stewpot
Will Everard - Dropkeel Empty
PostSubject: Will Everard - Dropkeel   Will Everard - Dropkeel EmptySat Jun 13, 2020 7:35 pm
I am building the Will Everard (Billings Boat) How do I attach the Dropkeel to the hull?
The drawing is at best challenging. How does one attach part# 51 to part # F539. It would appear just to slip on then glue. Not very satisfactory.Will Everard - Dropkeel Dropke10
PostSubject: Re: Will Everard - Dropkeel   Will Everard - Dropkeel EmptySat Jun 13, 2020 8:33 pm
What I did was to fix F539 to the inside of the bulwarks pass it through the hole and create a 'hook' on which to hang the paddle. I then glued the paddle to the hull to fix it. I assume you aren't hoping to sail the model. Rolling Eyes
Here it is before F539 was cut and bent.
url=https://servimg.com/view/17072593/1501]Will Everard - Dropkeel Dscn0941[/url]
I'll try to get a better photo tomorrow if it will help, although I'm not sure if it will be clear enough.
Stewpot
Stewpot
PostSubject: Re: Will Everard - Dropkeel   Will Everard - Dropkeel EmptySun Jun 14, 2020 11:37 am
Thank you for your reply and advise. Billing Boats' instructions are at best vague, particularly when one is a beginner. Your help is very much appreciated.
PostSubject: Re: Will Everard - Dropkeel   Will Everard - Dropkeel EmptySun Jun 14, 2020 12:30 pm
Yes - Billings instructions stop just when you need them Shocked Shocked Rolling Eyes There are a couple of build logs for the Will Everard on this Forum under Rag & Stick - they may help you if you need more clarification, but don't hesitate to post if you have more queries.
» Will Everard
» Will Everard
» Will Everard 601
» Will Everard
» Building Will Everard and need help!
