 stirling engine
stirling engine Empty
PostSubject: stirling engine   stirling engine EmptyThu Dec 29, 2011 11:16 pm
make no apologies for this not being a model boat I just thought it might be of interest to some.
Basically this is a Stirling or hot air engine. It works by shunting air from the hot end of the displacer cylinder to the cold end causing the air to contract rapidly pulling the power cyinder inwards turning the crank and flywheel this raises the displacer piston shunting the cold air to the hot end of the cylinder causing it to expand so pushing the power piston out and so on. this example is constructed from an old cola can cardboard a balloon (to act as a diaphram in place of the power cylinder) and some od bits of wire and a foil pie dish
stirling engine Card_s10
The designs and a ready made displacer cylinder I found on ebay for under a tenner and when put together she works well.
Video of her working
PostSubject: Re: stirling engine   stirling engine EmptyFri Dec 30, 2011 8:03 am
Very clever Phil, but it will take a BIg hull to fit it in!! Laughing Laughing
PostSubject: Re: stirling engine   stirling engine EmptyFri Dec 30, 2011 2:33 pm
Thanks Barry it is more a display model to demonstrate a principle. however I have considered making a more compact version to run an alternator to power a small electrtic motor (they don't have a lot of tourque built like this) that could maybe go in a boat time will tell
something like this
The flywheels would have to be aluminium with neodynium magnets in the holes for the alternator, one on each fly wheel shoud produce about 6v with enough amps between them to run a small electric motor fast enough to turn a small (ish) prop
stirling engine
» How about this for an engine............
» 1-2cc vintage engine required
» electric engine set up
» Glass Stephenson's Engine
» HP .61 gold cup engine probs
