| 105 ft Motor Minesweeper 'Mickey Mouse' | |
+3Footski phil winks intrepid75 7 posters |
intrepid75 Master
Posts : 271 Join date : 2011-06-11 Age : 68 Location : Bristol, West country
| Subject: 105 ft Motor Minesweeper 'Mickey Mouse' Mon Feb 25, 2013 8:27 pm | |
| I ordered a few fittings such as deck lockers, anchors, hawse plates and capstans for my Castle Class. They arrived at the weekend so now just waiting for my running gear from George Sitek. But as luck would have it when I ordered them from Sirmar I pondered over a small build to do in between work on the Castle which I figure is going to be a long long job. Always fancied a Motor Minesweeper so took the plunge and ordered a semi kit which arrived with my few fittings for the castle. Having now finished the Caldercraft Puffer at least I cans start on a new build. The semi kit is fine in quality hull has some imperfections that need addressing with a little filler here and there but nothing major and is a nice hull at 29 inches by 5.75 so a nice size. Fittings are good but the resin ones are mostly moulded as groups on a long strip to be fettled and sanded off rather than single individual items. Its missing a funnel as the mould for the funnell has split. As the funnell is a square(ish) box build I am happy to build that myself. The big snag was the plan - I knew when I ordered it from Sirmar that they didnt have an original plan and need to contact the guy who did the original. So at the moment I am without a plan although one is supposed to be on its way from Sirmar in the next few days and I have sourced a back up copy also. However there is plenty to get on with in the meantime and during the week I will make a start with a stand and also making right the few minor flaws in the hull. I have ordered the shaft and motor (385) and the rudder I will have a crack at making myself. A few pics of what comes with the semi kit. Okay the last two arent a MMS but thought I would share a couple of pics of my just finished Puffer. I didnt do a build diary as its been done to death over the years and others are probably better efforts than mine so I dont think a diary will add anything. But didnt turn out bad at all. Waiting for some vinyl name decals to arrive to finish it off. | |
phil winks Master
| Subject: Re: 105 ft Motor Minesweeper 'Mickey Mouse' Mon Feb 25, 2013 9:07 pm | |
| Hi Intrepid as you say that clyde puffer has been done more than once lol but to be fair that looks like a great example !! thanks for sharing it. That mine sweeper hull looks very sleek and slippy and I will be watching this one with interest | |
Footski Master
| Subject: Re: 105 ft Motor Minesweeper 'Mickey Mouse' Tue Feb 26, 2013 7:43 am | |
| I agree with Phil. A lovely job you have done and the puffer is a beautiful little boat. As for the next two builds you have going, not doing a build log is simply not an option..... | |
intrepid75 Master
| Subject: Re: 105 ft Motor Minesweeper 'Mickey Mouse' Tue Feb 26, 2013 8:46 pm | |
| I will be doing a blog on those builds certainly. Been making good some of the hull imperfections this evening on the MMS and will start posting at the weekend. | |
intrepid75 Master
| Subject: Re: 105 ft Motor Minesweeper 'Mickey Mouse' Wed Mar 13, 2013 8:33 pm | |
| Finally got round to making a start on the Motor Minesweeper over the last few days. Unfortunately as the weather has been that cold and damp I couldnt brave myself to start rubbing down the hull and cutting out shaft openings out in the open. Instead I made a start on the superstucture. First job though was to make a rudder. As it doesnt come with running gear I decided to make one as the brass standard ones commercially available will look totally out of place. It also has a skeg which isnt supplied but as luck has it I have a spare skeg from an old Deans build at 1/48th which when I measured it was the exact size but needs some reshaping. Rudder was made by 1mm plastic sheet with brass rod inserted and epoxied into place to ensure it doesnt move at a later stage. | |
intrepid75 Master
| Subject: Re: 105 ft Motor Minesweeper 'Mickey Mouse' Wed Mar 13, 2013 8:40 pm | |
intrepid75 Master
| Subject: Re: 105 ft Motor Minesweeper 'Mickey Mouse' Wed Mar 13, 2013 8:46 pm | |
| Port holes were straightforward using the supplied white metal and they seem to be fairly straight line after my drilling and filling of the openings. AS they are flanged it does help to hide any ovals that I ended up with. Less straighforward was the lower bridge window set. This is a resin fitting but it doesnt come finished. Oh no. You have to drill out and file out the actual openings in the resin!! Was careful in fact very careful as I was conscious the whole thing could snap in the middle but using the dremel and the flat file cautiously it seems to have turned out okay. There is a bit of plastic filler required in the opening I made but I will settle for that. Next job tomorrow is the bridge wing supports and the spay guards at the top of the bridge which I will do over the next coupld of days. Then after any filling and sanding the doors can be fitted. This was the basic drilling out very ragged. However a little more squarer and neater below after some filing effort!! | |
| Subject: Re: 105 ft Motor Minesweeper 'Mickey Mouse' Wed Mar 13, 2013 10:14 pm | |
| That's a good start intrepid. |
intrepid75 Master
| Subject: Re: 105 ft Motor Minesweeper 'Mickey Mouse' Wed Mar 13, 2013 10:43 pm | |
| Thanks Damien. Its a very simple build really as essentially there is little else to build after this superstructure wise. Its just a question of detailing it as from the photos I have found there are a number of variations of the detail of the superstructure - some didnt have the tunnel but others appeared to have open shelter over hangs at the stern, and there are variations of the bridge supports and also in some cases the funnel as a different shape - not tapering upwards at an angle from aft to forward and others without bridge wings. | |
intrepid75 Master
| Subject: Re: 105 ft Motor Minesweeper 'Mickey Mouse' Sat Mar 16, 2013 3:33 pm | |
intrepid75 Master
| Subject: Re: 105 ft Motor Minesweeper 'Mickey Mouse' Sun Mar 31, 2013 7:45 pm | |
intrepid75 Master
| Subject: Re: 105 ft Motor Minesweeper 'Mickey Mouse' Mon Apr 08, 2013 11:54 pm | |
Footski Master
| Subject: Re: 105 ft Motor Minesweeper 'Mickey Mouse' Tue Apr 09, 2013 7:22 am | |
| Coming along very nicely indeed! | |
intrepid75 Master
| Subject: Re: 105 ft Motor Minesweeper 'Mickey Mouse' Wed Apr 10, 2013 10:05 pm | |
| Thanks for the comments. Being perfectly honest as I intend for this build to put in a fair bit of time in the water rather than the occasional sail, I am not dwelling to much on getting the best possible finish I can achieve. All the photos of these little ships show them as real workhorses battered and with much localised changes and their own individual personality. So any flaws in my build, well more than my normal amount of flaws, I am not going to fret over. I think with any imperfections that result from my build it will still look what it is meant to be if that all makes sense! | |
| Subject: Re: 105 ft Motor Minesweeper 'Mickey Mouse' Wed Apr 10, 2013 11:03 pm | |
intrepid75 Master
intrepid75 Master
| Subject: Re: 105 ft Motor Minesweeper 'Mickey Mouse' Mon May 06, 2013 7:06 pm | |
intrepid75 Master
| Subject: Re: 105 ft Motor Minesweeper 'Mickey Mouse' Wed May 08, 2013 7:48 am | |
| Lovely finish to it intrepid.......I like it very much............but the big question is.......when are you going to start that Thornwick bay....she lools a real cracker |
| Subject: Re: 105 ft Motor Minesweeper 'Mickey Mouse' Wed May 08, 2013 8:24 am | |
intrepid75 Master
| Subject: Re: 105 ft Motor Minesweeper 'Mickey Mouse' Wed May 08, 2013 7:18 pm | |
| Already had a start when I got her - rudder was done and shaft fitted and some of the rubbing down done and a battery tray made. Since then I have done a few bits and bobs to the point where I hope to wire up the ESC this weekend and test the internals. I have also started some drilling work on the bridge windows and marked out decks so the build is up and running so to speak. I will put up build pics of her later. | |
intrepid75 Master
jaydee Midshipman
Posts : 52 Join date : 2014-04-19 Age : 77 Location : Mornington, Victoria, Australia
| Subject: Re: 105 ft Motor Minesweeper 'Mickey Mouse' Tue May 06, 2014 12:27 pm | |
| Great build Intrepid I don't know how you handle more than 1 build at a time. In my world there are not enough hours in the day. Keep up the good work. John | |
helensdad Able Seaman
Posts : 40 Join date : 2018-08-22 Age : 69 Location : Wirral
| Subject: Re: 105 ft Motor Minesweeper 'Mickey Mouse' Wed Aug 29, 2018 7:29 pm | |
| Subject: Re: 105 ft Motor Minesweeper 'Mickey Mouse' Thu Aug 30, 2018 12:55 pm | |
| We would in interested to see a build blog of your 3d printed build bud!!!!! _________________ I'm Not Anti-Social, I'm Anti-Stupid.
| Subject: Re: 105 ft Motor Minesweeper 'Mickey Mouse' Thu Aug 30, 2018 3:57 pm | |
| I think I started one yesterday, if not I will do it this evening in the warships section. | |
| Subject: Re: 105 ft Motor Minesweeper 'Mickey Mouse' Thu Aug 30, 2018 6:45 pm | |
| lovely trawler...bags of character......look forward to seeing that build. |
| Subject: Re: 105 ft Motor Minesweeper 'Mickey Mouse' Fri Aug 31, 2018 6:43 am | |
| - helensdad wrote:
- I think I started one yesterday, if not I will do it this evening in the warships section.
You did - on Mayhem!!! Barrie | |
| Subject: Re: 105 ft Motor Minesweeper 'Mickey Mouse' Fri Aug 31, 2018 8:33 am | |
| Oo eck, going daft in my old age! | |
intrepid75 Master
| Subject: Re: 105 ft Motor Minesweeper 'Mickey Mouse' Tue Nov 13, 2018 7:53 am | |
| Nice to see another MMS. Sorry I didn't reply but not been taking any active interest in my modelling lately, well for 3 years !!!! But now heading back into the build fray. Will watch your build with interest. Looks excellent on your thread. | |
| Subject: Re: 105 ft Motor Minesweeper 'Mickey Mouse' | |
