| Jupiter, a Caledonian macBrayne Ferry | |
+13battleshipbuff Tug--Kenny carlmt vnkiwi wbeedie Roadrunner gribeauval Oldsmokey Cody614 davidjt Windy barriew Footski 17 posters |
| Subject: Re: Jupiter, a Caledonian macBrayne Ferry Wed Nov 11, 2015 3:05 am | |
| Subject: Re: Jupiter, a Caledonian macBrayne Ferry Thu Nov 12, 2015 2:09 pm | |
| cheers me dear........... Next thing was to start thinking about sanding and smoothing the hull down ready for painting. I have to paint upto the bulwarks and scuppers before I paint the inside of the bulwarks as the process of masking up to stop overspray of black into the bulwarks would be horrendous and end up painting the nice duck egg blue of the inside with streaks of black. But before I could do the sanding and painting I had to make a "fin" which sits at the bottom of the stem, right in front of the forward Voith Schneider unit.....this I presume was to protect the voith from foreign bodies. This I made from a piece of chunky 3mm brass, which I drilled and pinned with stainless steel rod, and drilled into the grp stem.I also cut a small groove into the stem for the fin to slide into ( to stop twisting and trimmed out with a 2mm chisel. Once this has set hard I will back fill from the inside with some polyester resin to make the whole job sturdy and watertight. Once done I can then sand the hull smooth with wet and dry before painting. I'll be glad when I get my other camera back from the repairers though for some better quality photos, lol |
| Subject: Re: Jupiter, a Caledonian macBrayne Ferry Thu Nov 12, 2015 5:28 pm | |
| It is coming on very nicely one little question, please forgive my ignorance but what is a "forward Voith Schneider unit"..... it reminds me of that saying, "we had one of them but the wheels fell off" LOL please tell Neil. | |
| Subject: Re: Jupiter, a Caledonian macBrayne Ferry Thu Nov 12, 2015 5:51 pm | |
| Hi Paul.......
It is easier to show pictures of Voiths.
They are a propulsion unit made up of vertical blades which operate via changing pitch to the blades, much the same as a helicopter.
This allows the ship to travel in any direction conceivable. The big holes in the bottom of the hull showing in some pictures are the locating holes for two Graupner VSP units that they used to make and will allow the model to go anywhere.
They are usually fitted to "tractor" tugs, allowing them to go sideways diagonally and any which way till they basically vanish up their own trumpets, lol............amazing things which only Graupner would ever consider making and manufacturing for the modelling world, each unit uses two servos and a speed controller running the motor at a maximum 3000 revs.
here's a few shots of real and model ones.
https://www.google.co.uk/search?q=voith+schneider+propulsion+system&biw=1280&bih=642&tbm=isch&tbo=u&source=univ&sa=X&ved=0CDAQsARqFQoTCP3-u_W3i8kCFcnVFAodW-kH4A |
| Subject: Re: Jupiter, a Caledonian macBrayne Ferry Thu Nov 12, 2015 8:41 pm | |
| Ah! I get the gist of it now, thanks for the explanation, interesting idea, did they use these on the actual ferry | |
| Subject: Re: Jupiter, a Caledonian macBrayne Ferry Thu Nov 12, 2015 9:14 pm | |
| Oh yes, Paul.......the Jupiter, Juno, Saturn and ( one other ...forget the name) were the largest of the ships using the Voiths and were fast for their day, built in the 1970's and got the nickname of "streakers".
the larger ships in the Caledonian MacBrayne fleet are these days powered via schottel drives and the latest Loch Seaforth is powered by azipods as used on the larger Ocean Queens and other cruise ships,
But the smaller inter Island ferries are still equipped with Voith Schneiders. |
| Subject: Re: Jupiter, a Caledonian macBrayne Ferry Thu Nov 12, 2015 10:56 pm | |
| Well, don't ya just learn a little more each day just looked at both the others you mentioned never new they existed either, thanks for the info | |
| Subject: Re: Jupiter, a Caledonian macBrayne Ferry Fri Nov 13, 2015 1:22 am | |
| Subject: Re: Jupiter, a Caledonian macBrayne Ferry Fri Nov 13, 2015 10:00 am | |
| no problems Paul.........my daughter, who I am building this for hopes one day to serve with Caledonian MacBrayne........she is at nautical college Fleetwood at the mo studying for her OOW as a cadet officer in the MN and is a geek on Calmac.
At 13 years of age she was steering a ferry across the Clyde on Voith Schneider propulsion......she got the bug then to become an officer.
her favourite ferry is the MV Loch Riddon which she spends time on each summer with the skipper and crew........she loves it and her first job when arriving at Largs each year for our hols is to go aboard the little ferry.
https://en.wikipedia.org/wiki/MV_Loch_Riddon |
| Subject: Re: Jupiter, a Caledonian macBrayne Ferry Fri Nov 13, 2015 11:41 am | |
| I wish her good luck and hope she gets what she wants, a very keen young lady by the picture you paint, it's good to have direction and determination, especially at such a young age. | |
| Subject: Re: Jupiter, a Caledonian macBrayne Ferry Fri Nov 13, 2015 12:07 pm | |
| Subject: Re: Jupiter, a Caledonian macBrayne Ferry Fri Nov 13, 2015 1:02 pm | |
| I see the holes for the propulsion units now looking good | |
| Subject: Re: Jupiter, a Caledonian macBrayne Ferry Fri Nov 13, 2015 2:05 pm | |
| Subject: Re: Jupiter, a Caledonian macBrayne Ferry Fri Nov 13, 2015 2:15 pm | |
| - troutrunner wrote:
- I wish her good luck and hope she gets what she wants, a very keen young lady by the picture you paint, it's good to have direction and determination, especially at such a young age.
I am extremely proud of her, Paul. if only I had had the courage to do what she has chosen to do I wouldn't have been stuck in a dead end teaching job for so many years........but sadly we had tossers of careers advisers when I was a teenager and the biggest tosser put me off joining the merch at the age of 15. |
the goon Deck Hand
Posts : 9 Join date : 2015-10-29 Age : 66 Location : Whittier CA, USA
| Subject: Re: Jupiter, a Caledonian macBrayne Ferry Fri Nov 13, 2015 4:09 pm | |
| Neil, Looks great . Didn't realize how big she was . Keep it coming. Mark | |
| Subject: Re: Jupiter, a Caledonian macBrayne Ferry Fri Nov 13, 2015 7:14 pm | |
| Aye it's a fair size indeed Mark.....plenty of beam so should sail well.
I should have had it ready for this summer passed for my daughter ut due to a few personal problems lost my way a bit.......but back on it again now so should have it ready for the spring time for her. |
| Subject: Re: Jupiter, a Caledonian macBrayne Ferry Sat Nov 14, 2015 6:10 am | |
| Subject: Re: Jupiter, a Caledonian macBrayne Ferry Wed Nov 18, 2015 2:07 pm | |
| Sadly disaster has struck in my workshop over the past few weeks. I have never known storms wind and rain constantly battering us from the north and east for so long and it has finally taken it's toll. a week or so ago I started seeing black marks on the carpet that I have lining my garage to keep the warmth in. On further inspection I realised it was water, but it was only a small area about the size of a dinner plate........however over the past week it became so large that it covered one third of the floor space, and so I had to cut the carpet and underlay to find that the whole floor was absolutely sodden. I hung it over the washing line, but from the early photos it can be seen from the water in the garden that the rain is here to stay and so carpet and underlay will be off to the tip as soon as it dries sufficiently to put in the car........and more rain fell over the last few days and I have found that the silicon seal at the back wall of the 20 year old garage has gone, leaving me with no option but to live and bare it and keep everything off the floor.........luckily nothing was actually damaged, and I did find some items that I haven't used for years and so will put them on ebay or elsewhere for sale. the sad thing is though that at the moment my workshop is in even more of a tip than it usually is as I have things on the workshop tops that would normally be on the floor. |
battleshipbuff Gunner
| Subject: near disaster! Wed Nov 18, 2015 10:36 pm | |
| With the weather we have been having,Im not surprised you have sprung a leak! How many lost chuck keys did you find my friend?? I expect some of them have antique value lol! Hope you soon find out where the leak is,and be able to cure it! Still watching your build with interest,keep up the good work! Mick F | |
| Subject: Re: Jupiter, a Caledonian macBrayne Ferry Thu Nov 19, 2015 7:57 am | |
| - battleshipbuff wrote:
- With the weather we have been having,Im not surprised you have sprung a leak! How many lost chuck keys did you find my friend?? I expect some of them have antique value lol!
Hope you soon find out where the leak is,and be able to cure it! Mick F Not yet matey...........but I did find a pair of nail clippers.................be able to trim me toe nails now, lol.............. on a serious note though, the leak is from the silicon seal that was laid under the prefabicated concrete panels that make up the end wall 21 years ago, and it would mean lifting that whole wall up even if I could get at it, as there is a shed next to the wall.................so I will just have to live with it and mop up after heavy rainfall in future.......c'est la vie. And as I am giving up scratch modelling after the lifeboat hull for Baloo next summer on my retirement I will be taking out much of the bench work and selling off all my tools to buy an MG and a bike for my retirement................so don't see the point. |
| Subject: Re: Jupiter, a Caledonian macBrayne Ferry Thu Nov 19, 2015 8:21 am | |
| My shed had water coming up through the floor when we had heavy rain,up to an inch deep!I went to a good builders merchant,and bought what is called Tanking Cement.This is literally put on with a large brush,quite thickly,first brushing one lengthways,and when dry another vertically.I did my floor and 2 feet up the walls,one of which is a cob wall,and to make sure,finally coated it in bitumen paint.It was fairly easy to do,and it has cured the problem! Are you doing the Clyde for Baloo? He wants to get us all together when his is done | |
| Subject: Re: Jupiter, a Caledonian macBrayne Ferry Sat Nov 21, 2015 11:08 am | |
| cheers for the info Mick............unfortunately there's a shed in the way of the back wall and just don't have any access room at all to paint from the outside, and inside would be same problem because I clad the walls with battens and insulation stuff before adding a false wall of MDF.........so I have no chance of getting to it from either inside or out without either taking a shed apart otr all my back benches and wall/cladding so it will just have to stay as it is until I finally give up modelling and revert back to a garage. No Matey.the lifeboat hull and superstructure is of the Steam Hydraulic lifeboat Queen from 1898..........am going to make just the moulds for the hull and superstructure and a set of mouldings so that I can make a pattern in obeche for the Hydraulic pump and valves to be printed on a 3 d printer and that is that. |
| Subject: Re: Jupiter, a Caledonian macBrayne Ferry Mon Nov 30, 2015 3:12 pm | |
| And it is amazing what little gems are hidden away and forgotten until you have to clear some of the junk away from your workshop.... I had been given a lot of Lego many years ago and some was from old house structures and was in the process of sorting it when I found some latticed shutters from the windows, which will double up as ventilator frames. Saves making them. |
| Subject: where oh! where has it gone?!!! Wed Dec 02, 2015 4:51 pm | |
| Having survived the flood I got down to a little more work today, but at the important point of the exercise, I could only find one bottle of a two part epoxy mix, and so had to resort to plan two and use a two pack I have had for ages.............luckily it still worked as it had been unopened until this afternoon. and the exercise was to fit flanges and cross members to the upper superstructure deck so that it doesn't sag in the middle where the main wheelhouse fits. It has a support of the mid deck cabin aft but one at the fore part, so made two cross members first and epoxy'd them in place and then cut pieces of 8x 6mm ply for the flanges for the combing to hold the removable wheel house in place. these will be set in place with epoxy once the 30minute setting stuff has hardened and cured tonight. |
| Subject: Re: Jupiter, a Caledonian macBrayne Ferry Wed Dec 02, 2015 9:24 pm | |
| Subject: Re: Jupiter, a Caledonian macBrayne Ferry Thu Dec 03, 2015 2:50 pm | |
| Subject: Re: Jupiter, a Caledonian macBrayne Ferry Sun Dec 06, 2015 10:50 pm | |
| Subject: Re: Jupiter, a Caledonian macBrayne Ferry Sun Dec 06, 2015 11:57 pm | |
| Subject: Re: Jupiter, a Caledonian macBrayne Ferry Mon Dec 07, 2015 12:00 am | |
| by the way, the little woman went her own way last year with a piece of paper in her hand after 28 years of marriage, to her new partner.............yippeeee.....
hopefully my date with a beautiful lady will go well tomorrow, ..........I could not be happier, lol |
| Subject: Re: Jupiter, a Caledonian macBrayne Ferry Mon Dec 07, 2015 12:29 am | |
| Subject: Re: Jupiter, a Caledonian macBrayne Ferry Mon Jan 04, 2016 2:27 pm | |
| Subject: Re: Jupiter, a Caledonian macBrayne Ferry Thu Jan 07, 2016 12:18 am | |
| Subject: Re: Jupiter, a Caledonian macBrayne Ferry Thu Jan 07, 2016 7:32 am | |
| Coming along nicely Neil Just done a little homework on this vessel, interesting read on Wikipedia......... Wikipedia Farewell to ferry Jupiter Just thought these might be interesting to other folk. | |
| Subject: Re: Jupiter, a Caledonian macBrayne Ferry Thu Jan 07, 2016 11:37 am | |
| cheers matey.........yes I should have put some links p........they were a fast and very manoeuvrable ship............sailed on them a number of times in happy days..................very good sea ships and god knows why Calmac got rid of them sadly. |
| Subject: Re: Jupiter, a Caledonian macBrayne Ferry Mon Jan 11, 2016 11:35 am | |
| Subject: Re: Jupiter, a Caledonian macBrayne Ferry Sun Jan 17, 2016 9:37 pm | |
| another bit of the build that I have been putting off as it has been by guess work, as there are no visual markings on the plans........and that is, the lane markings for the car deck. However I do have photographs and enough markers on the deck ( i.e. the vehicle restraining brackets dotted all over the deck, which were marked on the plans ) to make the job a little better than guessing. And so, working from these photos and brackets on deck I lined the deck today with car pin striping tape, and once all put on, they actually made sense.........well all except the red lining, which I still haven't made sense of yet.........but given time it might come to me in a brain fart what they are actually for. I also painted all the vehicle brackets too. |
| Subject: Re: Jupiter, a Caledonian macBrayne Ferry Tue Jan 19, 2016 1:10 pm | |
| Subject: Re: Jupiter, a Caledonian macBrayne Ferry Tue Jan 19, 2016 5:49 pm | |
| Subject: Re: Jupiter, a Caledonian macBrayne Ferry Tue Jan 19, 2016 5:57 pm | |
| Certainly beginning to look the part Neil. Could the red lane markings indicate spaces for high vehicles?
| Subject: Re: Jupiter, a Caledonian macBrayne Ferry Tue Jan 19, 2016 6:23 pm | |
| thinking that myself Barrie...........funny that I sailed on this ship as a passenger many times along with her sister ship.............and never noticed the markings at all........half yer life ya wander round wi' yer eyes shut. |
| Subject: Re: Jupiter, a Caledonian macBrayne Ferry Tue Jan 19, 2016 6:39 pm | |
| Subject: Re: Jupiter, a Caledonian macBrayne Ferry Wed Jan 20, 2016 1:57 am | |
| Subject: caledonian ferry Sun Jan 24, 2016 3:10 am | |
| I dont know,I dont look in on this build for a couple of weeks,and what happens? The man starts getting on with it again! Now that IS coming along nicely,congratulations! Its certainly something different for you and for us! Hope Molly is still progressing through college,and will get all the results she needs to follow her chosen career. I will look in on a regular basis now that you have restarted building. PS you mentioned a date??? Come on whats all the news on that then??? Best Wishes my friend err keep it up? Mick F | |
| Subject: Re: Jupiter, a Caledonian macBrayne Ferry Sun Jan 24, 2016 9:11 am | |
| The date.......lol........that fell flatter than one of my pancakes...lol.......will tell about mollie when i get out of bed later but my back n leg are playing up cronic the last couple of days. |
| Subject: Re: Jupiter, a Caledonian macBrayne Ferry Sun Jan 24, 2016 9:19 am | |
| Subject: Re: Jupiter, a Caledonian macBrayne Ferry Tue Jan 26, 2016 6:27 pm | |
| Subject: Re: Jupiter, a Caledonian macBrayne Ferry Tue Jan 26, 2016 6:52 pm | |
| Lot of work there! I notice you have appeared to have made solid funnels? Would have really looked good with a smoke unit and diesel smoke coming out of them? Mick F | |
| Subject: Re: Jupiter, a Caledonian macBrayne Ferry Wed Jan 27, 2016 5:23 pm | |
| don't know what happened there Mick, but I posted a reply to this two days ago from my phone........no matey the funnels are hollow, but I don't go in for working gismos on my models at all.
I once went to inordinate amounts of trouble and work to put lots of lights into a Caldercraft Clyde puffer I built nearly 30 years ago.........and within three weeks of putting it into the drink at Fleetwood salt water lakes all of them HAD FAILED and no longer worked as all the wiring had corroded.................so that was it for me.
I don't decry those that do put lots of working stuff on their boats, and it is great to see, but not for me.............don't think I have ever sailed in the dark anyway, lol |
| Subject: Re: Jupiter, a Caledonian macBrayne Ferry | |
