| Mississippi Paddle Steamer Robt.E.Lee | |
jaydee Midshipman
![Midshipman Midshipman](https://2img.net/i/itest/ranks/default/default4.gif)
![jaydee](https://2img.net/u/1413/25/46/12/avatars/190-37.jpg)
Posts : 52 Join date : 2014-04-19 Age : 76 Location : Mornington, Victoria, Australia
![Mississippi Paddle Steamer Robt.E.Lee Empty](https://2img.net/i/empty.gif) | Subject: Mississippi Paddle Steamer Robt.E.Lee Sat Apr 19, 2014 3:20 am | |
| Hi all. I have been building this boat since November last year and I'm not even half way there yet. With working full time and most Saturdays it doesn't leave much time to do all of the other things that life throws at you, but I hope to retire at Xmas so I will just plug away until then. Well here goes with the boat. I will post some of the photos that I have taken so far along the build but if there is anything you want to see in more detail just ask. The hull is made by milling out 2 solid slabs of Jelutong timber this timber comes from a rubber tree. I am digressing from the plan a little bit on the rudder, my boat will have 2 rudders to make for better stearing I am still working on this area of the hull. I have only got my engine plumbed this week thanks to the boys at Miniture Steam in Montrose. So this is where I am up to so far. Trial assembly of engine into hull. ![Mississippi Paddle Steamer Robt.E.Lee Engine11](https://i.servimg.com/u/f55/18/82/91/12/engine11.jpg) Engine & boiler mounted on machine plate with paddles attached. No plumbing yet. ![Mississippi Paddle Steamer Robt.E.Lee Engine10](https://i.servimg.com/u/f55/18/82/91/12/engine10.jpg) Starting to attach top deck, all held together with dowel pins at the moment. ![Mississippi Paddle Steamer Robt.E.Lee 20140410](https://i.servimg.com/u/f55/18/82/91/12/20140410.jpg) | |
![Go down](https://2img.net/i/empty.gif) | |
![Mississippi Paddle Steamer Robt.E.Lee Empty](https://2img.net/i/empty.gif) | Subject: Re: Mississippi Paddle Steamer Robt.E.Lee Sat Apr 19, 2014 4:50 am | |
jaydee Midshipman
![Mississippi Paddle Steamer Robt.E.Lee Empty](https://2img.net/i/empty.gif) | Subject: Mississippi Paddle Steamer Robt.E.Lee Sat Apr 19, 2014 2:06 pm | |
| Thanks Damien I am going out to see the good folk at Surrey Park Model boat club tomorrow, hopefully the weather holds up. I don't get up that way much but if I do then I will pop in for that cupper for sure. I got the engine plumbed on Thursday but I am not happy with a part of it, they put a rubber hose from the engine to the oiler, I will try and get some copper tube solder on the fitting and bend it to suit and just use a piece of the rubber tube about 30mm long to join it to the tank, it should look a lot better. | |
jaydee Midshipman
![Mississippi Paddle Steamer Robt.E.Lee Empty](https://2img.net/i/empty.gif) | Subject: Mississippi Paddle Steamer Robt.E.Lee Thu May 22, 2014 10:49 am | |
| Hi Guys It's been awhile since I updated this post, so here goes. I have completed the new stern apart from the final filling and shaping installed the rudders and started on the lower decks and also started cutting the planking into the decks and paddle wheel covers, this has been a slow process but it is starting to come together. New stern with 2 rudders ![Mississippi Paddle Steamer Robt.E.Lee Stern_11](https://i.servimg.com/u/f55/18/82/91/12/stern_11.jpg) Start of planking on deck and paddle housing. ![Mississippi Paddle Steamer Robt.E.Lee Planki10](https://i.servimg.com/u/f55/18/82/91/12/planki10.jpg) I have also invested in a new plaything to keep the other couple of minutes a week that I can make free. Not a steam boat but I got it cheap on ebay and it also goes on water. ![Mississippi Paddle Steamer Robt.E.Lee Yacht_10](https://i.servimg.com/u/f55/18/82/91/12/yacht_10.jpg) ![Mississippi Paddle Steamer Robt.E.Lee Yacht310](https://i.servimg.com/u/f55/18/82/91/12/yacht310.jpg) | |
jaydee Midshipman
![Mississippi Paddle Steamer Robt.E.Lee Empty](https://2img.net/i/empty.gif) | Subject: Re: Mississippi Paddle Steamer Robt.E.Lee Sun May 25, 2014 2:03 pm | |
| Here is a video of the first firing of my engine and boiler. I need to change the gearing system as the paddles are going way to fast, I could probably get the boat up on airfoils at the rate they are turning. I originally thought that I would have to change it but I had all of these pulleys in stock so I thought I would have a play with them first. https://youtu.be/-d8sth51cuE | |
![Mississippi Paddle Steamer Robt.E.Lee Empty](https://2img.net/i/empty.gif) | Subject: Re: Mississippi Paddle Steamer Robt.E.Lee Mon May 26, 2014 1:32 am | |
jaydee Midshipman
![Mississippi Paddle Steamer Robt.E.Lee Empty](https://2img.net/i/empty.gif) | Subject: Mississippi Paddle Steamer Robt.E.Lee Tue May 27, 2014 12:00 pm | |
| You could be right Damien. Someone else on another forum suggested a Steam regulator but they seem very hard to find, so I will have to do some more browsing. a Steam regulator would probably be better as then I could keep the gearing I have got and just adjust the steam flow | |
jaydee Midshipman
![Mississippi Paddle Steamer Robt.E.Lee Empty](https://2img.net/i/empty.gif) | Subject: Back on deck again Mon Oct 26, 2015 10:35 am | |
| Hi folks, I am finally back on deck again after a year and a half away. I haven't actually done much on the boat since I have been absent as there was a lot of other things to get through, I have hardly been in the shed apart from getting tools and things out of it. I am retiring in December and a lot of things needed to be done before that came around. So most of these things are done now so I can get back to the boat a bit. I actually started on the Spiral staircase and top cabins today. 1 other development over this past little while is that I have bought a 3D printer for making bits and pieces for the boat 180 Windows of differing designs, doors, stairs handrail and finials ECT. I am not in production at the moment as I am waiting on a part for it, and I am still coming to grips with the software. My thought was to get the items up and running while I am building the boat. ![Mississippi Paddle Steamer Robt.E.Lee Sintro13](https://i.servimg.com/u/f21/18/82/91/12/sintro13.jpg) | |
![Mississippi Paddle Steamer Robt.E.Lee Empty](https://2img.net/i/empty.gif) | Subject: Re: Mississippi Paddle Steamer Robt.E.Lee Tue Oct 27, 2015 6:32 pm | |
| that looks very interesting jaydee. will look forward to seeing it in operation.......couldn't imagine turning all the spindles on a lathe..........what a godsend these printers seem to be............come too late in my modelling life sadly, but it will revolutionise scratch building. neil. |
jaydee Midshipman
![Mississippi Paddle Steamer Robt.E.Lee Empty](https://2img.net/i/empty.gif) | Subject: Mississippi Paddle Steamer Robt.E.Lee Tue Dec 22, 2015 11:30 am | |
| Progress is slow at the moment, I retired last Friday and haven't had a moment in the shed since I last posted. I have had to get some brackets 3d printed for the stop switches on my 3d printer and hope to have it up and running early in the new year. I have made a new machine plate for all the mechanicals out of 1mm aluminium and am in the process of reworking the mount for the paddles along with some work on the wheel houses I have taken some photos but my tablet is locked up in the shed with a flat battery at the moment so it will have to wait until tomorrow night. | |
jaydee Midshipman
![Mississippi Paddle Steamer Robt.E.Lee Empty](https://2img.net/i/empty.gif) | Subject: Mississippi Paddle Steamer Robt.E.Lee Sat Dec 26, 2015 10:23 am | |
| ![cheers](https://2img.net/i/fa/i/smiles/icon_cheers.png) Hooray I was able to get back in my shed today. hope everyone had a great x-mas. mine was fairy quiet but I have some update photos. I have to get myself organized again I find myself chopping and changing to different parts of the boat every time I get into the shed which means I have about 10 parts on the go at any 1 time. at the moment I am a full time nurse to my wife so I only get out there when we have someone else in the house and the time varies. Progress from last previous postsI started assembly of the three life boats as I thought I may be able to do small parts like these in the house. ![Mississippi Paddle Steamer Robt.E.Lee 20150616](https://i.servimg.com/u/f68/18/82/91/12/th/20150616.jpg) ![Mississippi Paddle Steamer Robt.E.Lee 20150618](https://i.servimg.com/u/f68/18/82/91/12/th/20150618.jpg) As I said last time I am redoing the machine tray in aluminium. ![Mississippi Paddle Steamer Robt.E.Lee 20151210](https://i.servimg.com/u/f68/18/82/91/12/th/20151210.jpg) I have also done a little bit more work on the paddle housings. ![Mississippi Paddle Steamer Robt.E.Lee 20151211](https://i.servimg.com/u/f68/18/82/91/12/th/20151211.jpg) ![Mississippi Paddle Steamer Robt.E.Lee 20151212](https://i.servimg.com/u/f68/18/82/91/12/th/20151212.jpg) And a little work on the Feathers for the chimney pots. ![Mississippi Paddle Steamer Robt.E.Lee 20151213](https://i.servimg.com/u/f68/18/82/91/12/th/20151213.jpg) I received the Smoke machine the other day and will try it when I know the correct centres for the chimneys. | |
![Mississippi Paddle Steamer Robt.E.Lee Empty](https://2img.net/i/empty.gif) | Subject: Re: Mississippi Paddle Steamer Robt.E.Lee Sat Dec 26, 2015 11:01 am | |
![Master Master](https://2img.net/i/itest/ranks/default/default6.gif)
![troutrunner](https://2img.net/u/1413/25/46/12/avatars/174-50.jpg)
![Mississippi Paddle Steamer Robt.E.Lee Empty](https://2img.net/i/empty.gif) | Subject: Re: Mississippi Paddle Steamer Robt.E.Lee Sat Dec 26, 2015 5:01 pm | |
| It's nice to see it's coming along with you back on it again. ![2thumbsup](/users/1413/25/46/12/smiles/2302161080.gif) | |
jaydee Midshipman
![Mississippi Paddle Steamer Robt.E.Lee Empty](https://2img.net/i/empty.gif) | Subject: Mississippi Paddle Steamer Robt.E.Lee Tue Jan 05, 2016 12:19 pm | |
![Mississippi Paddle Steamer Robt.E.Lee Empty](https://2img.net/i/empty.gif) | Subject: Re: Mississippi Paddle Steamer Robt.E.Lee Tue Jan 05, 2016 12:50 pm | |
![Mississippi Paddle Steamer Robt.E.Lee Empty](https://2img.net/i/empty.gif) | Subject: Re: Mississippi Paddle Steamer Robt.E.Lee Tue Jan 05, 2016 1:13 pm | |
| Very good ![Mississippi Paddle Steamer Robt.E.Lee Thumbsup](https://2img.net/h/i798.photobucket.com/albums/yy262/rhode-island-red/A%20few%20Smilies/Thumbsup.gif) Interesting view through the window, I spy a truck I think or a camper perhaps, do you live in the woods as it looks like ferns growing out there in front of the window? | |
jaydee Midshipman
![Mississippi Paddle Steamer Robt.E.Lee Empty](https://2img.net/i/empty.gif) | |
![Mississippi Paddle Steamer Robt.E.Lee Empty](https://2img.net/i/empty.gif) | Subject: Re: Mississippi Paddle Steamer Robt.E.Lee Wed Jan 06, 2016 11:16 am | |
| Ah! I see ![2thumbsup](/users/1413/25/46/12/smiles/2302161080.gif) you've made a nice job of the pond, it's nice to see other folks achievements on subjects other than boats, thanks for the explanation. ![Very Happy](https://2img.net/i/fa/i/smiles/icon_biggrin.png) | |
jaydee Midshipman
![Mississippi Paddle Steamer Robt.E.Lee Empty](https://2img.net/i/empty.gif) | Subject: Mississippi Paddle Steamer Robt.E.Lee Fri May 13, 2016 1:06 pm | |
| I will be working on the next deck over the next couple of weeks and leave all of the finishing off, railings stairs ect. until the decks are all finished I have a pretty solid frame work holding all of the cabin parts together. The whole cabin section from the deck to the top deck lifts off in 2 sections.
(Post clean up to remove disfunctioning photo links... Admin.) | |
![Mississippi Paddle Steamer Robt.E.Lee Empty](https://2img.net/i/empty.gif) | Subject: Re: Mississippi Paddle Steamer Robt.E.Lee Sat May 14, 2016 2:15 am | |
![Mississippi Paddle Steamer Robt.E.Lee Empty](https://2img.net/i/empty.gif) | Subject: Re: Mississippi Paddle Steamer Robt.E.Lee Sat May 14, 2016 8:18 am | |
| Very nice work, it's coming along beautifully ![2thumbsup](/users/1413/25/46/12/smiles/2302161080.gif) | |
![Mississippi Paddle Steamer Robt.E.Lee Empty](https://2img.net/i/empty.gif) | Subject: Re: Mississippi Paddle Steamer Robt.E.Lee Sun Aug 21, 2016 2:07 am | |
![Mississippi Paddle Steamer Robt.E.Lee Empty](https://2img.net/i/empty.gif) | Subject: Re: Mississippi Paddle Steamer Robt.E.Lee Sun Aug 21, 2016 7:48 am | |
jaydee Midshipman
![Mississippi Paddle Steamer Robt.E.Lee Empty](https://2img.net/i/empty.gif) | Subject: Mississippi Paddle steamer Robert. E. Lee Sat Mar 24, 2018 3:30 am | |
| Hi Guys It's been a long time from my last post, I see Photobucket has kicked some of my old photos to the wall but I will try to eventually catch up. A lot has happened to me since my last post in August 2016 I had just been diagnosed with Stage 4 Non Hodgkin Lymphoma so was on Chemo for 6 months and during that time I lost My wife of 46 years. I have now had over a year in remission so all is not lost. In the last year I have remarried sold 2 properties and moved to Mornington not much has been done on the boat since my diagnosis but I will eventually bring you up to date. I am still not working on it as it is still in storage I have my permit for my new shed and it should be up within the next month then a few extra weeks to get it lined and finished inside I have all of my tools and machines in storage too so need to get all of that stuff out, It's costing a bloody fortune. Anyhow it's good to be back. | |
jaydee Midshipman
![Mississippi Paddle Steamer Robt.E.Lee Empty](https://2img.net/i/empty.gif) | Subject: Mississippi Paddle steamer Robert. E. Lee Sat Mar 24, 2018 4:26 am | |
![Mississippi Paddle Steamer Robt.E.Lee Empty](https://2img.net/i/empty.gif) | Subject: Re: Mississippi Paddle Steamer Robt.E.Lee Sat Mar 24, 2018 7:11 am | |
| Jaydee in the top right hand corner of each post you have the option to edit or the X means delete.
You can edit each page and delete the now dead photos or delete sections of your posts.
My Josie Olsen thread has had all the dud photobucket picks removed leaving the comments inplace.
Cheers Damien. |
![Forum Overlord Forum Overlord](https://2img.net/i/itest/ranks/default/default6.gif)
![Roadrunner](https://2img.net/u/1413/25/46/12/avatars/1-74.jpg)
Posts : 1714 Join date : 2011-06-10
![Mississippi Paddle Steamer Robt.E.Lee Empty](https://2img.net/i/empty.gif) | Subject: Re: Mississippi Paddle Steamer Robt.E.Lee Sat Mar 24, 2018 7:52 pm | |
| Members don’t have the ability to delete posts off the forum nor go back and edit them after a set period of time ( I’ve done this as some disgruntled members on other forums tend to delete their work due to arguments and such, we don’t have that issue here... )
However I will take the the time to clean up your blog and remove the non functioning photos and condense the txt, feel free to reupload photos. ( if you want txt from your posts just leave me a note and I’ll edit the blog accordingly.
On a side note feel free to use the forums photo host, it’s simple to use ( it also creates you an account to log into externally) there are no limits on photos sizes nor bandwidth usage.
Instructions on its use can be found in the forums help section!
RR _________________ I'm Not Anti-Social, I'm Anti-Stupid.
jaydee Midshipman
![Mississippi Paddle Steamer Robt.E.Lee Empty](https://2img.net/i/empty.gif) | Subject: Mississippi Paddle steamer Robert. E. Lee Mon Mar 26, 2018 9:14 pm | |
| Thanks Roadrunner & Damian, I still have all of the photos on my computer so I will have to see where I am up to on this blog now the duds are removed and just re post them. There are a lot of photos to add to this blog but I can catch up while I am waiting for my shed is made. | |
![Mississippi Paddle Steamer Robt.E.Lee Empty](https://2img.net/i/empty.gif) | Subject: Re: Mississippi Paddle Steamer Robt.E.Lee Mon Mar 26, 2018 11:18 pm | |
| If you don’t have time to upload photos to the forum you can email me the folder and I’ll take the time to upload and post on your behalf no problem.
Just send me a pm and I’ll sort you out from there. _________________ I'm Not Anti-Social, I'm Anti-Stupid.
jaydee Midshipman
![Mississippi Paddle Steamer Robt.E.Lee Empty](https://2img.net/i/empty.gif) | Subject: Mississippi Paddle steamer Robert. E. Lee Tue Mar 27, 2018 2:42 am | |
| Thanks Road Runner. But a lot of things have changed on the boat too since the last post,and there is only 1 post that I have lost the photo on so I will just continue the build with new posts and photos after this post | |
jaydee Midshipman
![Mississippi Paddle Steamer Robt.E.Lee Empty](https://2img.net/i/empty.gif) | Subject: Mississippi Paddle steamer Robert. E. Lee Tue Mar 27, 2018 3:04 am | |
| I Hi Guy's In my last post before the interruptions in my life I had been working on the second deck of the boat, so I will just continue from there. I have completed the spiral staircase and wheel housings, the planking has been done on both decks as can be seen in the next 4 photos ![Mississippi Paddle Steamer Robt.E.Lee 36_spi10](https://i.servimg.com/u/f62/18/82/91/12/36_spi10.jpg) ![Mississippi Paddle Steamer Robt.E.Lee 37_smo10](https://i.servimg.com/u/f62/18/82/91/12/37_smo10.jpg) ![Mississippi Paddle Steamer Robt.E.Lee 38_1st10](https://i.servimg.com/u/f62/18/82/91/12/38_1st10.jpg) ![Mississippi Paddle Steamer Robt.E.Lee 39_pad10](https://i.servimg.com/u/f62/18/82/91/12/39_pad10.jpg) | |
![Mississippi Paddle Steamer Robt.E.Lee Empty](https://2img.net/i/empty.gif) | Subject: Re: Mississippi Paddle Steamer Robt.E.Lee Tue Mar 27, 2018 2:00 pm | |
| Looking Great ![2thumbsup](/users/1413/25/46/12/smiles/2302161080.gif) nice to see you have a cooling fan for heat dissipation, is it an ex-computer fan ? Good to see you're back at it, I look forward to more updates as it moves along ![Thumbup](/users/1413/25/46/12/smiles/263602217.gif) | |
jaydee Midshipman
![Mississippi Paddle Steamer Robt.E.Lee Empty](https://2img.net/i/empty.gif) | Subject: Mississippi Paddle Steamer Robt.E.Lee Tue Mar 27, 2018 11:59 pm | |
| Thanks Road Runner no the fan is on the smoke maker to force the smoke up the tall stacks it works well as seen in previous photos. The next few photos are of the finishing off of the wheel houses. I tried to use cutout lettering on them but was not happy with the result, so now i have made some transfer lettering, not bad for first attempt, I am happy with them now, I have also installed the windows and lights. I find I will have to install the lights as I go on each deck because of the way it is made and lack of access later. There are a lot of changes that I have had to make on this boat as I get further into the build but I will explain them as I get to them. Her are the wheel houses. Wheel houses with cutout letters ![Mississippi Paddle Steamer Robt.E.Lee 50_whe11](https://i.servimg.com/u/f62/18/82/91/12/50_whe11.jpg) Wheel houses with Tranfer letters ![Mississippi Paddle Steamer Robt.E.Lee 52_let10](https://i.servimg.com/u/f62/18/82/91/12/52_let10.jpg) Wheel houses in place over paddle wheels. ![Mississippi Paddle Steamer Robt.E.Lee 55_sid10](https://i.servimg.com/u/f62/18/82/91/12/55_sid10.jpg) | |
jaydee Midshipman
![Mississippi Paddle Steamer Robt.E.Lee Empty](https://2img.net/i/empty.gif) | Subject: Re: Mississippi Paddle Steamer Robt.E.Lee Fri Apr 20, 2018 12:12 pm | |
jaydee Midshipman
![Mississippi Paddle Steamer Robt.E.Lee Empty](https://2img.net/i/empty.gif) | Subject: Re: Mississippi Paddle Steamer Robt.E.Lee Sat Jul 07, 2018 9:45 am | |
| New shed is up and now I am working on the inside lining ![Mississippi Paddle Steamer Robt.E.Lee 20180610](https://i.servimg.com/u/f15/18/82/91/12/20180610.jpg) | |
jaydee Midshipman
![Mississippi Paddle Steamer Robt.E.Lee Empty](https://2img.net/i/empty.gif) | Subject: Mississippi Paddle Steamer Robt.E.Lee Sat Jul 07, 2018 9:49 am | |
| Lining is 16mm MDF to reduce noise plain on the bottom patterned on the top still a couple of ceiling panels to go up yet but I had to stop to seal the floor. ![Mississippi Paddle Steamer Robt.E.Lee Inside10](https://i.servimg.com/u/f15/18/82/91/12/inside10.jpg) | |
![Mississippi Paddle Steamer Robt.E.Lee Empty](https://2img.net/i/empty.gif) | Subject: Re: Mississippi Paddle Steamer Robt.E.Lee Sat Jul 07, 2018 9:52 am | |
| Looks impressive! ![2thumbsup](/users/1413/25/46/12/smiles/2302161080.gif) can’t wait to see the finished shop _________________ I'm Not Anti-Social, I'm Anti-Stupid.
![Mississippi Paddle Steamer Robt.E.Lee Empty](https://2img.net/i/empty.gif) | Subject: Re: Mississippi Paddle Steamer Robt.E.Lee Sat Jul 07, 2018 10:03 am | |
![Mississippi Paddle Steamer Robt.E.Lee Empty](https://2img.net/i/empty.gif) | Subject: Re: Mississippi Paddle Steamer Robt.E.Lee Sun Jul 08, 2018 7:10 am | |
jaydee Midshipman
![Mississippi Paddle Steamer Robt.E.Lee Empty](https://2img.net/i/empty.gif) | Subject: Re: Mississippi Paddle Steamer Robt.E.Lee Mon Jul 09, 2018 5:40 am | |
| Hi troutrunner it took about 1 week to build with no lining it is 6 x 4.5 metres. I bought all of the lining on Ebay cheap used for crating and it has taken me longer to do the lining and painting than it did to build it in the first place 2 coats of prep primer and 2 coats of colour and the floor has had 3 coats of sealer starting to look good, window frames are going to take a bit of time. Power is connected to the home solar system with battery backup so it's cheap to run. Need the heater this weather though. | |
![Mississippi Paddle Steamer Robt.E.Lee Empty](https://2img.net/i/empty.gif) | Subject: Re: Mississippi Paddle Steamer Robt.E.Lee Mon Jul 09, 2018 9:10 pm | |
| Sounds very good ![2thumbsup](/users/1413/25/46/12/smiles/2302161080.gif) | |
jaydee Midshipman
![Mississippi Paddle Steamer Robt.E.Lee Empty](https://2img.net/i/empty.gif) | Subject: Mississippi Paddle Steamer Robt.E.Lee Tue Apr 09, 2019 5:13 am | |
| Hi Guys, Gee, it has been nearly a year since my last post. Time fly’s when you are having fun. The shed is finished and I have retrieved all of my stuff from storage the boat is looking a bit the worst for ware with a lot of dust on it that is hard to get off. I am in a bit of a quandary as to what to do with it. There are a lot of bad memories attached to it as it was built at a very traumatic period in my life and I find it hard even to look at it now. I am thinking of cleaning it off covering it over and put it in the rack until I feel better about it at the moment I have just lost the will to work on it. There were a couple of model shows on around here last month and I was going to try and finish it and put a for sale sign on it. But it didn’t happen so I am stuck with it, as is. The last time I did any work on it, I entered it in the Queenscliffe model show nearly 3 years ago, this is how it looked then. ![Mississippi Paddle Steamer Robt.E.Lee 75%20under%20lights1](https://oi310.photobucket.com/albums/kk405/Jaydee_008/75%20under%20lights1.jpg) [/size] ![Mississippi Paddle Steamer Robt.E.Lee 20160924_112315](https://oi310.photobucket.com/albums/kk405/Jaydee_008/20160924_112315.jpg) [/size] And now ![Mississippi Paddle Steamer Robt.E.Lee Robrt%20E%20Lee1](https://oi310.photobucket.com/albums/kk405/Jaydee_008/Robrt%20E%20Lee1.jpg) ![Mississippi Paddle Steamer Robt.E.Lee Robrt%20E%20Lee2](https://oi310.photobucket.com/albums/kk405/Jaydee_008/Robrt%20E%20Lee2.jpg) That’s how she looks at the moment some parts like the ramps on the front were removed for storage. I would love to hear some of your views on my dilemma | |
jaydee Midshipman
![Mississippi Paddle Steamer Robt.E.Lee Empty](https://2img.net/i/empty.gif) | Subject: Mississippi Paddle Steamer Robt.E.Lee Wed Feb 05, 2020 2:36 am | |
| Hi Guys. I have finally decided to get rid of this boat so it has been sold to a guy in Mt Martha. I do not know if he is interested in continuing with this thread or not, I have showed him this site so he may present it in the future as he gets up to speed with the finish of it. I have now decided to set my shed up with a HO scale train layout instead of boats. Thanks guy's for your interest over the years, I am sorry you didn't get to see the finished boat on the water. | |
![Mississippi Paddle Steamer Robt.E.Lee Empty](https://2img.net/i/empty.gif) | Subject: Re: Mississippi Paddle Steamer Robt.E.Lee Wed Feb 05, 2020 9:07 am | |
| Shame but understandable, I do a few other hobbies too to beat the boredom And repeatability of boat building, one includes 00 gauge railways! Good luck in your future projects and don’t be a stranger!
Admin _________________ I'm Not Anti-Social, I'm Anti-Stupid.
![Mississippi Paddle Steamer Robt.E.Lee Empty](https://2img.net/i/empty.gif) | Subject: Re: Mississippi Paddle Steamer Robt.E.Lee Wed Feb 05, 2020 11:05 pm | |
| I do hope from time to time you post progress of your railways on here under other interests Jaydee……..would love to see them.
neil |
![Mississippi Paddle Steamer Robt.E.Lee Empty](https://2img.net/i/empty.gif) | Subject: Re: Mississippi Paddle Steamer Robt.E.Lee ![Mississippi Paddle Steamer Robt.E.Lee Empty](https://2img.net/i/empty.gif) | |
