 My Eileen
7 posters
Go to page : 1, 2  Next
My Eileen Empty
PostSubject: My Eileen   My Eileen EmptyTue Oct 28, 2014 11:30 pm
I sought of found with this modelling lark that you can run out of things to do, so, the reason I started in the first place was because I had a plan for MFV Eileen, had it for many, many years, started it twice and for reasons unknown didn't get very far. I was advised by others to buy a kit, which would be an easier build, hence the Fast Patrol Launch build.
Here is a quick catch up to where I am now.
I have a Burgess Band Saw and used it to cut out my basic shapes.
My Eileen SAM_0483_zps8500865a
My Eileen SAM_0487_zps17ce7fe6
The keel/centre board and sheer boards are cut out.
My Eileen SAM_0502_zps49cc7129
And cleaned up
My Eileen SAM_1594_zpse7186186
Fitting the stern tube and keel doublers.
My Eileen SAM_1597_zps2bcbb4a6
Trial fit of a few bits.
I just love elastic bands, free from my postman 2thumbsup
My Eileen SAM_1617_zpsc29f5a62
Made a little mistake but I will repair and it won't be seen anyway.
My Eileen SAM_1616_zpsf440169d
My friend made me some profile gauges for the sides on his Ekold shrinker/stretcher.
My Eileen SAM_1611_zpsb945ea44
My Eileen SAM_1610_zps24310407
I must have lost a few photy's somewhere Sad
My Eileen Empty
PostSubject: Re: My Eileen   My Eileen EmptyTue Oct 28, 2014 11:46 pm
This is where I am now, these are partially glued.
My Eileen SAM_1623_zpse4842549
My Eileen SAM_1624_zps1f6422ad
My Eileen SAM_1625_zps54735aaf
My Eileen Empty
PostSubject: Re: My Eileen   My Eileen EmptyWed Oct 29, 2014 8:04 am
Hi all, a little help required, I don't know what motor or servo for the rudder to use, some advice from you knowledgeable folk  for a novice on which type and size and where do others get these bits from please. My Eileen Bow
My Eileen Empty
PostSubject: Re: My Eileen   My Eileen EmptyWed Oct 29, 2014 8:41 am
For a motor I would imagine a 545 would be ideal - it looks as though it will be a substantial model, but you are not looking for great speed. As for a servo, I find the miniature ones have sufficient torque for non-racing models up to 30 or so inches, but a standard servo would do fine. As for supplier, then either Cornwall Model Boats or Component Shop can supply both the above, and are very reliable in my experience.
The International Model Boat Show at Leamington Spa is coming up soon. If you are able to visit that you will find all you need there (and more Shocked )
My Eileen Empty
PostSubject: Re: My Eileen   My Eileen EmptyWed Oct 29, 2014 7:09 pm
What does 545 stand for, probably obvious but not to me the novice.
I'm not sure how I tell a standard from a Miniature servo either
forgive my ignorance, all the bitts for the "Fast Patrol Launch" came with it, so have not many clues
My Eileen Empty
PostSubject: Re: My Eileen   My Eileen EmptyWed Oct 29, 2014 7:17 pm
Paul,
A 545 motor is a 540 series motor with 5 poles. These are more efficient than straight 540s which only have 3 poles. Athough not marked as 545, this is a 5 pole motor http://www.componentshop.co.uk/540-standard-dc-motor.html
This ia a micro servo http://www.componentshop.co.uk/9g-micro-servo-3v-6-0v.html whilst this is a standard one http://www.componentshop.co.uk/25g-standard-servo.html
The difference is the physical size, as well as the power and operating speed.
Hope this clarifies things a bit.
My Eileen Empty
PostSubject: Re: My Eileen   My Eileen EmptyWed Oct 29, 2014 8:13 pm
Thanks Barrie, got that now, next question, what motor Bracket is required Thumbup I'm sure when I get onto boat build 3 I will know a little more, I'm planning that one now,  a "Great Lakes Freighter" Very Happy
My Eileen Empty
PostSubject: Re: My Eileen   My Eileen EmptyWed Oct 29, 2014 8:15 pm
You can get a bracket designed for the motor - check the web site, there is an option to buy the motor with a mount I believe.
My Eileen Empty
PostSubject: Re: My Eileen   My Eileen EmptyWed Oct 29, 2014 10:00 pm
Many thanks Barrie, beginning to get it now 2thumbsup
My Eileen Empty
PostSubject: Re: My Eileen   My Eileen EmptyThu Oct 30, 2014 9:00 am
Ok, assuming I go with this 540 series motor with 5 poles, what battery power do I/can I use ?
And what speed controller would I need ?
My Eileen Empty
PostSubject: Re: My Eileen   My Eileen EmptyThu Oct 30, 2014 11:15 am
Paul,
A 10 or 15 amp ESC would be fine. That is a very low current motor. As for battery, 6 to 12 volts depending on your preference for NiMh or SLA - I wouldn't recommend LiPo for this application.
My Eileen Empty
PostSubject: Re: My Eileen   My Eileen EmptyThu Oct 30, 2014 1:59 pm
I have some batteries for the other project and have posted a question in the electrics section to keep this thread a little cleaner, must go back to work now, I'm late Rolling Eyes as usual...........
My Eileen Empty
PostSubject: Re: My Eileen   My Eileen EmptySun Nov 02, 2014 11:08 am
I had a little problem with the sheer boards, they were a bit kinked or wigglier that I liked, pondered quite hard on this and came up with the idea of putting a piece of hardwood at right angles and to the outside as not to interfere with the access openings I require for electrics etc.
Some photy's, I found a good use for the small cable ties that I have a pile of Very Happy
My Eileen SAM_1630_zpsce3a7aba
My Eileen SAM_1631_zps187efa8a
My Eileen SAM_1632_zpsb98d4dbb
My Eileen Empty
PostSubject: Re: My Eileen   My Eileen EmptySun Nov 02, 2014 12:01 pm
looking good 2thumbsup  are you going to plank on frame it with what material 2thumbsup
My Eileen Empty
PostSubject: Re: My Eileen   My Eileen EmptySun Nov 02, 2014 8:30 pm
Hi David,
    I was given an old wardrobe which was edged with some hardwood, some teak like in colour (thought I would save this for decking) and some lighter coloured stuff, not sure what though. I have already cut the lighter coloured bits into some planks of 2mm thickness but still have more if I need to correct my mistakes.
I have just uploaded some photy's of the planking, will put it in a post in a bit 2thumbsup
My Eileen Empty
PostSubject: Re: My Eileen   My Eileen EmptySun Nov 02, 2014 8:59 pm
Photy's uploaded Thumbup
The first shot shows planks cut on the band saw, if you look at the left you will see a plank I twisted as a test and it seems to be very pliable, so I think good possibilities.
My Eileen SAM_0521_zpsb2702208
My Eileen SAM_0517_zps35dac992
Bits of the old wardrobe which were my source for these planks.
My Eileen SAM_0506_zps69baea04
My Eileen SAM_0505_zps4c0ea8d3
Now I remember, I also cut up the teaky stuff for decking too.
My Eileen SAM_0504_zps1018331e
Oldsmokey
Oldsmokey
My Eileen Empty
PostSubject: Re: My Eileen   My Eileen EmptyTue Nov 04, 2014 11:29 am
Postman, elastic bands! You’re lucky ours must sell his because we never get any left around.
Wardrobe recycling again, I think you do more than you are telling us. lol!
Another nice build, more piccy’s please. 2thumbsup
My Eileen Empty
PostSubject: Re: My Eileen   My Eileen EmptyTue Nov 04, 2014 12:20 pm
I asked the relief postlady for a few as they would be handy and they just kept coming, now I have a carrier bag full, I had to ask them to stop leaving then as I think I must have as many as the Post Office do. My Eileen Rollonfloorlaughing
My Eileen Empty
PostSubject: Re: My Eileen   My Eileen EmptyTue Nov 04, 2014 1:53 pm
I found I had a little discrepancy in the deck level, about an eighth of an inch from one side to the other which I thought a little to much. So I made a board up for the planking job which has pulled it back within limits, not sure how others build boats like Eileen, I must admit I am making all this up as I go along, please comment if you use a different method.
Angle irons screwed to the bottom of a piece of ply.
My Eileen SAM_1638_zpsdb5757d5
chocked under and clamped on top.
My Eileen SAM_1637_zps65523e69
My Eileen SAM_1636_zps712c6967
My Eileen Empty
PostSubject: Re: My Eileen   My Eileen EmptyMon Nov 10, 2014 7:51 pm
A little more done here, I have put in the motor mounting shelf, U?J on the prop in reediness.
 My Eileen SAM_1644_zpseb97a112
Also the start of the battery shelf.
My Eileen SAM_1643_zps59f1f174
Not a great deal I can do now until I see an engineering pal of mine who is going to make up a two part rudder assembly for me. The rudder shaft is to have a slot machined to take the rudder and will be secured with a couple of grub screws, much like a throttle assembly of a carburettor.
My Eileen Empty
PostSubject: Re: My Eileen   My Eileen EmptyTue Nov 11, 2014 10:16 pm
A little more done, trial fit of the motor and fitting sides to the battery tray/shelf 2thumbsup
My Eileen SAM_1645_zpsbff888fc
My Eileen SAM_1648_zps0205670a
My Eileen SAM_1646_zps323417dd
My Eileen SAM_1647_zpsc2ed9f88
My Eileen SAM_1650_zps80bd1988
My Eileen Empty
PostSubject: Re: My Eileen   My Eileen EmptyWed Nov 12, 2014 3:32 pm
looking good 2thumbsup 2thumbsup 2thumbsup 2thumbsup 2thumbsup
Oldsmokey
Oldsmokey
My Eileen Empty
PostSubject: Re: My Eileen   My Eileen EmptyWed Nov 12, 2014 4:23 pm
Coming along very nicely indeed Paul.
My wife flower gave me a present yesterday just to cheer me up.
A large bag of elastic bands.
My Son came round just to take the lift! with a load of cable ties.
All different colours.
Suppose it makes a change from grapes.
My Eileen Empty
PostSubject: Re: My Eileen   My Eileen EmptyWed Nov 12, 2014 6:44 pm
Thanks chaps, it's nice to get a bit of encouragement My Eileen Wave
My Eileen Empty
PostSubject: Re: My Eileen   My Eileen EmptyThu Nov 13, 2014 7:48 pm
A little more progress today, fitted the last and smallest bulk head but not glued yet as I need to cut holes in both the centre board and the this bulk head for the rudder post and it's control connections to the servo.
My Eileen SAM_1653_zpsfbcfd3d8
Also I was to strengthen the Skeg I believe it's called, the sticky out bit for the lower end of the rudder post, but have decided to cut away the wooden Skeg and use two brass plates (first photy is them rough cut) and solder a solid piece of bar between them, this will make things easier especially fitting the rudder itself.
My Eileen SAM_1658_zps74b9e50a
My Eileen SAM_1652_zpsa801795d
Still needs shaping.
My Eileen SAM_1651_zpsf1b0e0e8
Also started making holders for the receiver and the ESC.
My Eileen SAM_1656_zpsbe31ce13
My Eileen Empty
PostSubject: Re: My Eileen   My Eileen EmptyFri Nov 14, 2014 8:03 pm
Finished and fitted the little pockets for the receiver and ESC.
My Eileen SAM_1660_zpsa878d635
My Eileen SAM_1661_zps83848168
My Eileen SAM_1672_zpsbc8b8644
My Eileen SAM_1673_zps68e103f4
My Eileen SAM_1671_zps52a9fa5a
My Eileen SAM_1668_zpsba3cfd48
My Eileen Empty
PostSubject: Re: My Eileen   My Eileen EmptyTue Nov 18, 2014 6:49 pm
Getting the rudder position sorted now, I'll see my friend tomorrow who is to slot the brass rod for me.
I have cut removed half the slot for the tube, then placed a bit of ply for strengthening over it, when it's set I will do the other side.
My Eileen SAM_1694_zps2c4c90cd
Also roughed out holes for the rudder control rod.
My Eileen SAM_1695_zps17e093ae
My Eileen Empty
PostSubject: Re: My Eileen   My Eileen EmptyThu Nov 20, 2014 5:49 pm
Cut the slot for the rudder tube and plated it over with another piece of ply, I have left the brass tube out until I get the rudder and brass skeg made up so as to make sure they are fitted together and in a true line.
My Eileen SAM_1702_zps3abd7ebb
My Eileen SAM_1703_zps7c5b1588
My Eileen SAM_1704_zps7f048485
I ran out of clamps so had to be inventive Very Happy
My Eileen SAM_1705_zps3e40ab94
My Eileen Empty
PostSubject: Re: My Eileen   My Eileen EmptyWed Nov 26, 2014 5:28 pm
I'm now getting prepared to fit the rudder which I can pick up Friday afternoon 2thumbsup
I am replacing the skeg with a brass bar with brass plates soldered to it, made this today and cleaned it up ready.
The reason for this move was that I caught the skeg and almost snapped it off, you can see the repair in the first photy.
My Eileen SAM_1749_zps1bea058a
My efforts in brass and soldering.
My Eileen SAM_1750_zpsed948f01
Lining it up ready for surgery.
My Eileen SAM_1752_zps0b627e91
I had to bite the bullet and cut it off.
My Eileen SAM_1753_zps2a9535de
Then rough out where it was to fit.
My Eileen SAM_1754_zps499ef319
One of the many trial fits.
My Eileen SAM_1755_zpsafc64912
Nice and snug fit. Thumbup
My Eileen SAM_1756_zpsf7e59370
Now to clear up the mess. Rolling Eyes
My Eileen SAM_1758_zps84e4b0f7
I will drill and screw in place once the rudder is fitted and probably glue or use epoxy resin stuff, not sure quite yet.
My Eileen Empty
PostSubject: Re: My Eileen   My Eileen EmptyThu Nov 27, 2014 3:00 pm
I would use resin and then screw in, stops any water that might find its way into gaps making a good seal.
My Eileen Empty
PostSubject: Re: My Eileen   My Eileen EmptyThu Nov 27, 2014 5:36 pm
I always try to leave it so that I can remove the rudder if necessary. Sometimes that's the only way to remove the propshaft.
barrie
My Eileen Empty
PostSubject: Re: My Eileen   My Eileen EmptyThu Nov 27, 2014 6:48 pm
Thanks for your thoughts chaps, Epoxy Resin was my choice but as Barrie says I may need at some point to service the rudder or prop. so I will have to think a bit harder or I might cause a problem.
This is the good thing about putting a build blog up, it throws up other folks thoughts and ideas for all to read too  Thumbup
My Eileen Empty
PostSubject: Re: My Eileen   My Eileen EmptySat Nov 29, 2014 6:19 pm
I picked up my rudder shaft from my friend Barry yesterday, excellent job he has done, bought a little gas welding kit off of him too, with a small jet it will be ideal for soldering 2thumbsup
My Eileen SAM_1769_zps99f457dd
My Eileen SAM_1768_zpsb1a01d8f
Just have to solder them together then the fit can begin. Barry did both ends of the rod for me, I now have a spare Thumbup
My Eileen Empty
PostSubject: Re: My Eileen   My Eileen EmptySat Nov 29, 2014 8:16 pm
That's an interesting way of making a rudder. I usually just solder the blade to the shaft with soft solder. Shocked  I haven't had one come adrift yet. I have tried silver solder but my torch isn't strong enough for something as big as a rudder.
My Eileen Empty
PostSubject: Re: My Eileen   My Eileen EmptySat Nov 29, 2014 11:32 pm
I had lots of thoughts on this Barrie and this was the decision, a flat surface gives an easier place to solder it, soft solder is what I will use but probably will go silver solder in the future. The little welding set will make it easy for silver soldering and the advantage is that there are several solders with different melting points which I will be using in my copper art projects.
I'm not sure how much it would affect the steer of a boat by putting the rudder on one side of the shaft. Ideally the prop needs to be central to the propeller and I would imagine the longer the boat the more its effect would have, my next one is going to be 54inches long so I think I want to avoid any chance of problems. Perhaps I am being over the top in this, it's just the way I see it.
My Eileen Empty
PostSubject: Re: My Eileen   My Eileen EmptySun Dec 07, 2014 8:06 pm
Been doing a bit on the rudder etc. today and made some progress.
First I made the shaft fit and the upper guide tube.
My Eileen SAM_1778_zps6fd4a039
Soldered the two bits of the rudder together.
My Eileen SAM_1781_zps0cfbbab1
My Eileen SAM_1782_zpsdc0ba1ac
Then set the tube in epoxy resin.
My Eileen SAM_1783_zps887fe95b
When it had hardened a little I removed the shaft and put some more epoxy resin around the tube just to make sure, then cleaned some off before it set fully to make things easier.
My Eileen SAM_1785_zps2894ff4f
With the rudder in the loose skeg I thought it a bit low and might bind.
My Eileen SAM_1786_zps4f643c3a
I needed a spacer and couldn't find a suitable non ferrous washer, so I made one from a tube nut (gas pipe fitting).
My Eileen SAM_1787_zps85abea5e
Newly made washer/spacer in place.
My Eileen SAM_1788_zps50ee19a3
My Eileen SAM_1789_zpsbc57f824
Soon be ready to have a go at the planking Thumbup never tackled this job before, so I'll take it slowly and see how it goes. Any tips anyone has would be useful. Very Happy
My Eileen Empty
PostSubject: Re: My Eileen   My Eileen EmptyMon Dec 08, 2014 5:43 pm
A little more progress today, I made a lever arm for the rudder. I was going to use a wheel collet but decided against it, when I drilled it out to the size required I didn't think enough thread was left for the grub screw to make proper purchase on the shaft, I had a feeling that the thread might strip.
I drilled two opposing holes in the end of the bit of brass left over from the skeg, 3/8square I think, and cut a small suitably sized strip of 2.5mm brass from a sheet I have and soldered them together. Then cleaned it up and cut a slit with a hacksaw through to the second hole turning it into a clamp.
 My Eileen SAM_1797_zps036c6038
Drilled a few holes.
My Eileen SAM_1798_zpse508d6f3
Here it is with 4mm nut and bolt along with rudder, skeg and all.
My Eileen SAM_1801_zpsc4282f0a
My Eileen Empty
PostSubject: Re: My Eileen   My Eileen EmptyMon Dec 08, 2014 10:03 pm
2thumbsup 2thumbsup 2thumbsup 2thumbsup 2thumbsup 2thumbsup
My Eileen Empty
PostSubject: Re: My Eileen   My Eileen EmptySat Dec 13, 2014 11:03 am
Did a little more yesterday, I needed to get the rudder and servo link sorted so had to make a mount for the servo. I like these to be adjustable as it makes life easier when making the rod, as long as the rod is somewhere near the length I can then move the servo till it's spot on and central, saves removing that little screw that holds the servo arm for realignment.
My Eileen SAM_1802_zps4493bb85
My Eileen SAM_1803_zpsd52171a8
Glued and clamped
My Eileen SAM_1804_zps5fc845ec
Servo in place, it can slide in and out to get the correct position.
My Eileen SAM_1805_zpse31d86bb
My Eileen Empty
PostSubject: Re: My Eileen   My Eileen EmptySat Dec 13, 2014 11:37 am
2thumbsup 2thumbsup 2thumbsup 2thumbsup 2thumbsup 2thumbsup well thought out.
My Eileen Empty
PostSubject: Re: My Eileen   My Eileen EmptySat Dec 13, 2014 12:10 pm
It just makes things easier Damien, might give others a bit of help too. I get lots of tips on stuff by reading other folks threads, it's a way of giving back. Thumbup
My Eileen Empty
PostSubject: Re: My Eileen   My Eileen EmptySat Dec 13, 2014 12:34 pm
That's why we're all here to learn and share this is what makes a successful forum Paul some I don't visit anymore belittle other members that makes for an unfriendly forum this one will never be allowed to go that way.
I learned from your trick of a sliding servo adjustment   Thumbup Thumbup  great Idea I've been modelling for 50yrs and never thought of that,
if I can learn something new each day I'm a happy fella. 2thumbsup 2thumbsup
My Eileen Empty
PostSubject: Re: My Eileen   My Eileen EmptySat Dec 13, 2014 2:05 pm
I'm pleased if I can help in any small way, it makes the world feel good to be appreciated, thank you  2thumbsup
My Eileen Empty
PostSubject: Re: My Eileen   My Eileen EmptySun Dec 14, 2014 1:43 am
Smile Smile Smile Smile
coastie23
My Eileen Empty
PostSubject: My Eileen   My Eileen EmptyWed Dec 12, 2018 7:47 pm
Did you finish your model if so can we have a update please
My Eileen Empty
PostSubject: Re: My Eileen   My Eileen EmptyWed Dec 12, 2018 9:36 pm
Hi coastie23,
I do intend to get back to my models at some point but I am afraid life is in the way at present.
I have had to move my work space to another location for the models and just had no time to sort it properly.
I also have other projects I am doing, mainly classic cars and at present I am putting a 1937 Ford Model "Y" back on the road and hope to have it mobile in the spring, I have 90% of the parts I require, just need to keep fitting them.
My Eileen SAM_2856_zpstpnlundz
My Eileen Empty
PostSubject: Re: My Eileen   My Eileen EmptyWed Dec 12, 2018 11:21 pm
2thumbsup 2thumbsup 2thumbsup 2thumbsup 2thumbsup 2thumbsup 2thumbsup 2thumbsup 2thumbsup 2thumbsup 2thumbsup 2thumbsup 2thumbsup 2thumbsup 2thumbsup
coastie23
My Eileen Empty
PostSubject: Re: My Eileen   My Eileen EmptyThu Dec 13, 2018 8:10 am
Morning  mate quick question if I may don`t know if you will remember. When you cut out the bulkheads did you have to trims the tops down I`ve traced mine off the plan bulk no1 is 10mm higher than the slope coming off the bow. I noticed yours is flush with the top which is making live difficult to fit the sheer boards broken two (balsa).What thickness ply did you use for the keel and bulk heads at the moment I`m using some spare balsa and to me its going to be very flimsy.
Regards
Coastie
ps nice car.
My Eileen Empty
PostSubject: Re: My Eileen   My Eileen EmptyThu Dec 13, 2018 10:21 pm
I can't quite remember but it was traced off of the plan as you did. does it look to be in correct alignment with the keel for the planks to fit to ?
1/4inch ply I think, it's all made from scrap wood I had laying around, I love recycling stuff.
This car is one of 10 or so that I have, I think I have more projects than time left to live but hey ho I like to keep busy Laughing
Have you thought of making a build log (photo log) for others to see, it helps us all as we all do thing a little different and this to me is especially helpful in the my learning curve.
coastie23
My Eileen Empty
PostSubject: Re: My Eileen   My Eileen EmptyFri Dec 14, 2018 8:57 am
Hi Just trying to work it out at the moment using scrap balsa. now cut 10mm off the top of bulk head 1 so it fits like yours. all bulk heads sit on the plank line just notice I cocked up lol couldnt understand why some of the bulkheads were higher so cut slots in them to get the sheer line to like right (I blame the pills) had bulk head 2 in postion no4 and 3 in 2 4 in 3 will now have to fill in the slots and try again will take a picture and upload it later when i figure how to load pictures. just order 9mm ply for keep and 6 mm for bulk heads marine ply.
Regards
Coastie
My Eileen Empty
My Eileen
