| My Eileen | |
+3davidjt barriew troutrunner 7 posters |
coastie23 Able Seaman
Posts : 38 Join date : 2018-12-12 Location : Whitby Yorks
| Subject: Re: My Eileen Fri Dec 14, 2018 11:17 am | |
| Photo 1 straight off the plan bulkhead 1 10mm higher the the sloop from the bow Photo 2 10mm cut from top of bulkhead 1 flat piece of balsa laid on top to see if deck line looks ok photo 3 card sheerline temporarily in place need trimming to fit without breaking
https://servimg.com/view/20008812/4
https://servimg.com/view/20008812/5
https://servimg.com/view/20008812/6
Last edited by coastie23 on Fri Dec 14, 2018 11:29 am; edited 1 time in total (Reason for editing : p) | |
| Subject: Re: My Eileen Fri Dec 14, 2018 10:07 pm | |
| Good luck Coastie I look forward to seeing your build thread to see how you tackle Eileen, we all have a slightly different take on the same theme. | |
| Subject: Re: My Eileen Sat Dec 15, 2018 7:03 am | |
| - coastie23 wrote:
- Photo 1 straight off the plan bulkhead 1 10mm higher the the sloop from the bow
https://servimg.com/view/20008812/6 Coastie If you select the middle line - starting URL - the photos will appear in your post not just the link. Barrie | |
| Subject: Re: My Eileen Sat Dec 15, 2018 6:14 pm | |
canabus Deck Hand
Posts : 8 Join date : 2016-07-25
| Subject: Re: My Eileen Fri Dec 21, 2018 11:39 am | |
| Hi I have two of the later ones, the Hellen. Also building the French version Julieth 4 which is the same length , but more beam. Larger hatch and a raised section forward of the wheelhouse. All running 540 rock crawler motors on 2S Lipo batteries. Canabus | |
canabus Deck Hand
| Subject: Re: My Eileen Fri Dec 21, 2018 11:41 am | |
| Hi Adding pics of the Julieth 4. Canabus | |
AlanP Master
| Subject: Re: My Eileen Thu Dec 05, 2019 1:59 pm | |
| Has anyone else had a go at this boat, I have just found the drawings in my files and fancied having a go at it. It seems a funny way of building a plank on frame model, they are usually built upside down.
Alan | |
| Subject: Re: My Eileen Thu Dec 05, 2019 7:07 pm | |
| Took a while didnt use balsa as he suggested ply for bulk heads and keel 6mm x 3mm obechi for hull. | |
AlanP Master
| Subject: Re: My Eileen Thu Dec 05, 2019 8:30 pm | |
| Thanks for the photo coastie, That is a very very nice model and you should be proud of it. I like the colours you have chosen and the nice sheen you have on the deck planking. What did you use to seal the deck planking?. I have used sanding sealer in the past but it has crazed after a few years so I am looking for something else for this model.
Thanks again, may be asking for more photo's well into next year.
Regards Alan | |
canabus Deck Hand
| Subject: Re: My Eileen Fri Dec 06, 2019 5:44 am | |
| HI All
A month ago I pickup an original Eileen kit with plans.
The hull was basically done with only six more planks to add.
I added a new 4mm prop drive line with a 60mm brass 3 blade prop. The rudder was missing, so I made a new one, but follow the curve of the hull at the top. Motor a rock crawler 540 80 Turn brush with a 60 Amp ESC on a 2S 6000mah Lipo battery.
The stern bulwarks were missing, so I made new ones and the top railing is missing.
The hatch and wheelhouse are basically together.
Fibreglass the inside with 2 ounce matting and double resin coated the outside.
The plywood deck and bulwarks are installed.
I have cutout the deck between the hatch and wheelhouse to made this a removal section which gives me better access to the inside.
Still a lot more work to go !!!
Canabus | |
| Subject: Re: My Eileen Fri Dec 06, 2019 8:16 am | |
| Hi Alanp deck got two thin coats of sanding sealer then i rubbed it down with oooo wire wool next came 4 coats of matt varnish (not the water based crap) inbetween rubbed down with 400 grit sandpaper i got off fleabay same for wood on hull. the wood was stained with colron wood dye english light oak again not the water based rubbish (getting hard to find is the orginal stain all i can get here is the water based. green is humbrol found a no 2 size tin in shed from 20yrs ago and its still better than tin i bought for it its watery. red is rattle can. | |
AlanP Master
| Subject: Re: My Eileen Fri Dec 06, 2019 10:09 am | |
| Thanks for the replies, they are very helpful. Full of enthusiasm now and will be making a start today.
Thanks to all
Alan | |
| Subject: Re: My Eileen | |
| My Eileen | |
