Hello my friends, I have a Bancroft armidale and need to get more deflection in my rudders. I can’t get to the Rudder control because of it being a ready to run Boat, but I can’t get to the servo. I see these at the last outer hole of the servo arm on both sides of servo. Should I get a larger servo arm so I have one or two connecting holes, further from the servo and get a larger deflection of the Rudder ?the Rudder has two Rudders And two props with one servo with two connecting rods one on each side of the servo. It just doesn’t have enough sharper return than I really want. Thank you and thank you to everybody. That has helped me with my charging systems. Stay safe.
