| Josie Olsen | |
+3barriew troutrunner Roadrunner 7 posters |
| Subject: Re: Josie Olsen Sun Jan 24, 2016 9:52 am | |
| I've never heard of them either. |
| Subject: Re: Josie Olsen Sun Jan 24, 2016 11:49 am | |
| OK - maybe not the correct name Amati Plank Benders is the correct name. In my view an overpriced tool - but so are all Amati's other tools. Barrie | |
| Subject: Re: Josie Olsen Sun Jan 24, 2016 5:09 pm | |
| Thanks Barrie, I will take a look on the net and check them out | |
| Subject: Re: Josie Olsen Sat Jan 30, 2016 10:08 am | |
| Four planks each side glued on Clamps in progress to hold hull inverted for the rest of the planks the hard work begins with tighter compound curves. I've only glued myself to the hull 3 times so far lol And the poly pipe for soaking the planks 40mm id Damien. |
| Subject: Re: Josie Olsen Mon Feb 01, 2016 9:57 am | |
| Thanks Paul. Today, 3 planks each side reduced from 8.5mm to 5mm x 3mm so much easier to work with. And there was no flex in the keel at all. The clamps were made with 50mm angle brackets that were epoxied to 12mmx30mm Poplar and were attached with bolts through the base board so that when planking is finished the hull and clamps lift off together and allow access to the clamp bolts to release them. |
| Subject: Re: Josie Olsen Tue Feb 02, 2016 6:46 am | |
| Its coming along nicely Damien Now planking wasn't so bad was it Barrie | |
| Subject: Re: Josie Olsen Tue Feb 02, 2016 7:15 am | |
| Thanks chaps far better than I expected the only trouble I've had was it was really warm today and the white glue was drying before I got to the end of the planks. |
| Subject: Re: Josie Olsen Thu Feb 04, 2016 9:16 am | |
| Only a little planking to do tomorrow and then the sanding starts. |
| Subject: Re: Josie Olsen Thu Feb 04, 2016 2:01 pm | |
| Looking good Damien | |
| Subject: Re: Josie Olsen Thu Feb 04, 2016 2:08 pm | |
| Damien,
Before I start sanding the outside of my planked hulls I resin the insides - either just resin, or resin and glass fibre tissue or model aircraft tissue. It makes the hull more rigid to help with sanding.
| Subject: Re: Josie Olsen Fri Feb 05, 2016 12:30 am | |
| I'll use filler on any gaps before the resin or it'll be a disaster sanding. |
| Subject: Re: Josie Olsen Sat Feb 06, 2016 10:25 am | |
| 5/2/16 Planking finished, filler to all the gaps and polyester resin to the inside to stiffen it up prior to sanding the resin cured quickly on top of shed in full sun 27c heat. 6/2/16 Sanded easily a few bits of filler still needed a calliper was used to ensure equal outer width of each bulkhead from keel at deck level. Pic's later off to add filler it will dry quickly 27c outside heading for 31c. Inside with polyester resin coat. Second lot of filler sanded coming together nicely . The bow blocks glued in place. |
| Subject: Re: Josie Olsen Sat Feb 06, 2016 1:03 pm | |
| Looking good Damien. Barrie | |
| Subject: Re: Josie Olsen Sat Feb 06, 2016 2:02 pm | |
| And all the worrying before, it all looks fine it'll be me that's troubled about doing Eileen next I'm not looking forward to that but you and Barrie have both given me more confidence | |
| Subject: Re: Josie Olsen Tue Feb 09, 2016 5:00 am | |
| Subject: Re: Josie Olsen Tue Feb 09, 2016 7:49 am | |
| I'll have a go as soon as I have finished lining out the new bit off shed and built the new bench | |
| Subject: Re: Josie Olsen Wed Feb 10, 2016 10:20 am | |
| Bow and stern nicely to correct shape. Keel and bulkheads removed as shown on the plan. and the deck cut from 2.5mm ply. Had a productive day. |
| Subject: Re: Josie Olsen Thu Feb 11, 2016 2:37 am | |
| Thanks Paul.
While sanding the bow blocks I was regretting gluing the the stem piece on first with super glue however a whoops happened with it caught under the bench and it broke sanding proceeded smoothly and a new stem was added to finish her off I intended to glass tissue & resin her today but I cant be bothered so will sit and watch Babylon5 episodes. |
| Subject: Re: Josie Olsen Thu Feb 11, 2016 8:13 am | |
| I love it lol recently finished all of DS9 and 3 epi's of Eureka left to watch. |
| Subject: Re: Josie Olsen Thu Feb 11, 2016 1:45 pm | |
| I have watched quite a few of Eureka, have you watched any Stargate, my favourite is Stargate Atlantis.
If you like strange Sci-Fy try Fringe, some of it is almost believable that it could be real in the near future, Continuum is another worth a watch if you like time travel.............. | |
| Subject: Re: Josie Olsen Fri Feb 12, 2016 2:35 am | |
| Yep all 4 Stargate movies entire SG1 & all SG Alantis. I have Fringe & Continuum but haven't watched them Yet
A Scifi movie I really liked was Cowboys and aliens set in USA wild west.
I have every book EE Doc Smith ever wrote and a few written in his name that were finished after his death. |
| Subject: Re: Josie Olsen Fri Feb 12, 2016 7:42 am | |
| I like most science fiction stuff as long as it is well done. I watched Stargate Universe but was disappointed as it only ran for 2 seasons, but still worth a watch | |
| Subject: Re: Josie Olsen Fri Feb 12, 2016 8:58 am | |
| 2 layers of glass cloth went on easily ( See the post in Tricks ant tips) no dramas 5% thinner added to the polyester resin. The stem and end of keel were all I that wouldn't behave so will need to do separately. Nice and smooth. She'll be ready to trim tomorrow. |
| Subject: Re: Josie Olsen Sat Feb 13, 2016 5:21 am | |
| Subject: Re: Josie Olsen Sat Feb 13, 2016 7:57 am | |
| Hi Damien, is it general practice to either cover with fibre glass tissue inside or out, I understand why you are doing it but I am curious to know.......... On another note, she is coming along quite nicely | |
| Subject: Re: Josie Olsen Sat Feb 13, 2016 10:38 am | |
| Thanks Paul.
Applying resin to the inside firms up the balsa so it doesn't warp whilst sanding, I apply resin/glass tissue to the outside to accident proof the hull against other models and rocks around the launch sites. |
| Subject: Re: Josie Olsen Sat Feb 13, 2016 12:32 pm | |
| That makes sense, something I will have to think about | |
| Subject: Re: Josie Olsen Sat Feb 13, 2016 12:49 pm | |
| Subject: Re: Josie Olsen Sat Feb 13, 2016 2:13 pm | |
| - Damien wrote:
- Thanks Paul.
Applying resin to the inside firms up the balsa so it doesn't warp whilst sanding, I apply resin/glass tissue to the outside to accident proof the hull against other models and rocks around the launch sites. Hi Paul I do the same as Damien, except that I sometimes use model aircraft tissue instead of glass tissue. I also use either glass or paper tissue inside sometimes if my planking isn't very good instead of just resin. I also prefer to use a water based resin if possible - it has less odour and is easier to clean up. If using it inside I always use some form of tissue. Barrie | |
| Subject: Re: Josie Olsen Thu Feb 18, 2016 11:43 am | |
| After removing the obvious faults in the GRP surface I sprayed the hull with high build primer after it dried I wet sanded with 120 git wet & dry paper unfortunately it was not as smooth as I thought. A drama proceeded as I found my spot filler had thickened since last use approx 12yrs since last used on my Hillclimb car, I thinned it with GP thinners and proceeded to apply to hull but being 29c day it dried as i applied it the hull ended up looking like a mountain rage of hills cliffs and chasms 2 to 3mm thick left it 3 days to fully dry. Finally started wet sanding with 120 grit without much success for 2 hrs so switch to 80grit for another hour also without much success this putty had set like concrete. I attacked it today with my sander with 90mm triangle 80 grit pads which cut the worst of it and with the paper in my hand not to bad as pics show. Tip If stop putty gets thick and lumpy chuck it out. |
| Subject: Re: Josie Olsen Mon Feb 22, 2016 5:16 am | |
| Hull finished ready for final u/coat. Rudder from 1.5mm aluminium sheet & some 2.9mm stainless steel rod. The blade material was bent at 90deg's in a vice and hand bent the rest of the way finished of with a hammer. The rudder shaft was notched diagonally in six places and was epoxied into place. The joint of the 2 sides was super glued and when dried body filled was packed into the top & bottom. The brass plate pivot for rudder bottom pin although not on plan was 3mm tube hammered flat was added as the pivot tube is only around 15mm long . |
| Subject: Re: Josie Olsen Wed Feb 24, 2016 10:31 am | |
| With the hull ready for the deck I thought of getting a profile for a stand and thought of plaster bandage to get the profile after seeing the price on ebay I cut a hand towel into strips and soaked then in plaster wrapped the hull in cling wrap and placed 4 strips fore and aft, The string was needed to hold the strips to the contour of the hull. |
| Subject: Re: Josie Olsen Sat Mar 12, 2016 10:04 am | |
| While not able to process photo's at present building progresses I found the beam pivot bearing shaft some what off centre I removed the pivot tube to rectify I placed axle rod in drill press with the tube centre over said axle it was place within the beam and held at 90 deg by the drill press locked in place while the glue dried.
Funnel made and cylinder and valve assembly well under way couldn't get 3/16"channel cheaply so with Dremel and 12mm sander tube I spent an hour turning it into channel (Anyone want a heap of brass powder lol) Brass scroll work for the top of the assembly is next.
When I get my computer fixed I'll add all the pictures I've taken of the progress. |
| Subject: Re: Josie Olsen Tue Mar 15, 2016 12:02 pm | |
| Finally have my computer fixed and able to process photos. The stand completed. Funnel and cylinder/valve block done. Piston slide gantry under construction. 3/16 square brass tube turned into channel with 1/2" dia 80 grit sanding drum in the Dremel. Gantry assembly. The deck installed with rubber bands and 10mm dowel used to force it to conform to the hull curvature while glue dried. Engine bay cut out. My deck didn't quite match the the bow as this pic shows the filler required to make the deck conform to shape. |
| Subject: Re: Josie Olsen Wed Mar 16, 2016 12:52 am | |
| No $20 for s/h power supply & $10 labour. We have a computer shop near by that caters for the poor, unemployed and disabled if needed they will supply a S/h machine for $100 I donate our old computers when my son updates ours. Yes moved along instead of sitting around most of the day had much more time whilst sharing my wife's computer even got the shed totally cleaned Didn't stay that way long though |
| Subject: Re: Josie Olsen Wed Mar 16, 2016 7:34 am | |
| Looking good Damien wish I could get back to my boats, the shed seems to taking forever your progress is encouraging me though | |
| Subject: Re: Josie Olsen Wed Mar 16, 2016 7:47 am | |
| Subject: Re: Josie Olsen Sun Mar 27, 2016 6:41 am | |
| 3 of the 4 engine/valve rods made some finishing still needed. The plan called for laminating 3mm ply but I had 3 failures as glue let go while shaping so cut new ones from 9mm poplar. 3 of the bow planks glued in place pic's when closer to finished planking. |
| Subject: Re: Josie Olsen Sun Mar 27, 2016 12:50 pm | |
| been a while since I looked at this Damien..........how well it has come on.........superb.
I like the idea for the profile for the stand.
| Subject: Re: Josie Olsen Sun Mar 27, 2016 1:15 pm | |
| Thanks mate. |
| Subject: Re: Josie Olsen | |
| Josie Olsen | |
