I put the digital tachometer on it with 12v supply from my power supply built at Tech school way back in the seventies it gave 57.75 rpm at these rev's the beam was rather slow although it runs very smoothly.
My camera takes stills & video but I can't workout the video part
Subject: Re: Josie Olsen Fri Mar 23, 2018 12:41 am
If you have a smart phone with the YouTube app installed making videos is a lot easier. Just simply log into your YouTube account/google account and you’ll see a video button ( looks like a camera) you can push that and it will take the feed from your smart phone and just record. Once done just finish off and follow the instructions. You can then use the share links for your video once it uploads to the forum either using the forums YouTube link ( creates a video in the blog) or just upload a direct link to YouTube...
I hope that makes sense if you get stuck message me.
I should note that YouTube can also take video from your laptops camera too ( same process as your smart phone would use)you’ll just have to use the edit tool to remove yourself from the frames etc...
Subject: Re: Josie Olsen Fri Mar 23, 2018 1:40 am
No mobile or laptop Aron. 90% of tech savvy was destroyed by radiation to the brain recently told by specialist Doc the double vision when I turn my head to the right is also a by product of radiation at least I'm still alive.
Subject: Re: Josie Olsen Sat Mar 24, 2018 7:25 am
New pulley turned a little under double the diameter of the original, still have to drill & tap for the grub screw the pic also shows the spring I'll somehow attach to apply light pressure the drive belt.
Subject: Re: Josie Olsen Sat Mar 24, 2018 8:13 pm
Ill point to any kid over 8 to help you at this point for video, I could write a long set of instructions but have no idea if your able to follow them for video.
Honestly it’s not much dissimilar to uploading photos however you would need to upload to video host such as YouTube and just post the link on the forum...
I wouldnt worry to much tho bud photos do the job nicely.
Subject: Re: Josie Olsen Sat Mar 24, 2018 11:24 pm
Thanks mate.
Subject: Re: Josie Olsen Sun Mar 25, 2018 8:03 am
Aron. I found the video on off by accident now to workout the youtube upload.
The new pulley increased the wheel revs to 79 rpm so I removed the main pulley chucked it in lathe and reduced the diameter by about 5mm then cut the new pulley groove put it back together and the batteries ion the tacho were flat, tomorrow's another day.
That will be spent vacuuming the dust from machining the body filler main pulley it's everywhere. If it's to fast there's room to make the new pinion smaller in diameter.
Subject: Re: Josie Olsen Sun Mar 25, 2018 1:11 pm
Good job bud, it’s always those pesky rpms on paddlers that drive me batty, and have always led to me trying to remember you need low rpm and high torque rather than the high rpms in used to dealing with.
One day I’ll get around to finishing my paddle boat design plans ( honestly they are further along than last posted) I just need some time to prototype and also need Sit down and do some real math on rpm and gear ratios.
Subject: Re: Josie Olsen Sun Mar 25, 2018 1:18 pm
I think 120 to 150rpm should do it
Subject: Re: Josie Olsen Thu Mar 29, 2018 9:09 am
A piece of scrap 8mm plywood solved the belt tension hassle.
The pulley mod's produced 123 rpm
Motor & beam in action.
https://youtu.be/Jhp-iL65hL0
Subject: Re: Josie Olsen Thu Mar 29, 2018 2:40 pm
brilliant video Damien , nice to see you finally got it working and filmed it, you must be over the moon with it I would be well done .
Subject: Re: Josie Olsen Thu Mar 29, 2018 5:13 pm
Top job...
I edited your link, vid now plays direct in the blog.
Subject: Re: Josie Olsen Fri Mar 30, 2018 2:49 am
Thanks Aron & David with all the hassles I've had with this model it rewarding to see it coming together.
Subject: Re: Josie Olsen Fri Mar 30, 2018 7:49 am
Nuts fitted my guess of keel to motor clearance was a close call if the belt stretches even a little the motor tray will hit the keel.
with top 2 decks in place she looks good.
A few more picks.
Subject: Re: Josie Olsen Fri Mar 30, 2018 8:01 am
There's not much room inside for the radio and batteries I've ordered 10 x 6ooo mAH sub C batteries on ebay I'll build 2 packs of 5 cells and velcro them to hull walls then worry about the Rx & Rx battery then think on the speed controller placement.
Subject: Re: Josie Olsen Fri Mar 30, 2018 6:05 pm
Hi Damien
Lots of progress while I've been away.
The beam looks very good in operation.
Subject: Re: Josie Olsen Sat Mar 31, 2018 12:39 am
Thanks Barrie
Subject: Re: Josie Olsen Sat Mar 31, 2018 10:57 am
Finished Josie's body art, she's looking good.
Oooops that's a fib I still have her name to do.
Subject: Re: Josie Olsen Sat Mar 31, 2018 11:07 am
Very smart Damien. I hope you do manage to get her on the water at least once.
If you are looking for a new ESC try one of these https://www.banggood.com/20A-Double-Sides-Brush-ESC-For-RC-CarBoat-p-926460.html?rmmds=search&cur_warehouse=CN - they are very good, also have a BEC which wil save you a battery
I have been using 10 amp similar versions for some time now, not that I would expect them to last very long if you did ask it to carry 10 amps, but for 1 - 2 amps they are great.
Subject: Re: Josie Olsen Sat Mar 31, 2018 1:19 pm
Thanks Barrie I have a few Esc's on hand. I do plan to start sailing again it just struck me a few days ago besides the weeds I'm worried about falling in the during launch and retrieve process I can't even pic up the dogs waste without leaning against something.
I bought one of these trolleys on ebay and will modify it lo launch models.
Subject: Re: Josie Olsen Sat Mar 31, 2018 1:23 pm
Looking awesome!
Now this time no knocking it off the bench and to the floor i still have nightmsres on your last one that hit the deck!
Subject: Re: Josie Olsen Sat Mar 31, 2018 11:39 pm
I bought one of those trolleys for my boats as well............haven't used it yet..........your boat looks fantastic.......beautiful, matey.
Subject: Re: Josie Olsen Sun Apr 01, 2018 1:08 am
Thanks Neil I also bought some aluminium angle 25mm x 12mm x 3mm I'll attach to the bottom tray will then put nylon webbing between the upright arms and the angle for the models to rest upon, Picks when it's done.
Subject: Re: Josie Olsen Mon Apr 02, 2018 8:19 am
Got a video of the piston slide in action.
https://youtu.be/n0nfTjZX2k0
and the drive end.
https://www.youtube.com/watch?v=YPDewqEdZoo
Took a dremel with a 50mm saw blade followed by 10mm sanding wheel and removed excess deck and bulkhead material inside work area to make room for R/c gear and batteries.
Subject: Re: Josie Olsen Mon Apr 02, 2018 8:47 am
hi Damien, looks great in the boat. the second video has not come through at my end, has any one else got same problem.
Subject: Re: Josie Olsen Mon Apr 02, 2018 9:18 am
Damien - I agree with David - no second video. I think you have missed part of the link.
Subject: Re: Josie Olsen Mon Apr 02, 2018 9:25 am
Ditto the above, yes I agree she's looking great
Subject: Re: Josie Olsen Mon Apr 02, 2018 9:29 am
Try it again please guys I'd forgotten to publish it ooop's
Subject: Re: Josie Olsen Mon Apr 02, 2018 9:31 am
got it Damien well done
Subject: Re: Josie Olsen Mon Apr 02, 2018 9:45 am
Subject: Re: Josie Olsen Mon Apr 02, 2018 9:54 am
Oldsmokey Gunner
Posts : 120 Join date : 2014-10-10 Age : 86 Location : Bournemouth, Dorset. UK.
Subject: Re: Josie Olsen Wed Apr 04, 2018 5:21 pm
Excellent Damien I always like movement. Josie Olsen with the paddles turning and the engine running, it will look very impressive both on the water or a show table.
Subject: Re: Josie Olsen Wed Apr 04, 2018 7:56 pm
amazing mate..........can't wait to see her on the water.........it really is a stunning model.........and so quirky.
Subject: Re: Josie Olsen Sat Apr 07, 2018 7:42 am
I got the test tank out and found it hadn't weathered the extremes of weather well and the fibreglass had delaminated all around the top edges, I finished repairs the" I thought " filled it with water and it still leaks like a sieve where I added extra width for paddle boxes more work needed, however I got 4 pics of Josie, with the motor mounted port side of centre she leans considerably to port as the pics show. This will be addressed by battery, Rx & speed controller placement.
Subject: Re: Josie Olsen Sat Apr 07, 2018 12:55 pm
hi, Damien
looks ok, well done
Imcc Gunner
Subject: Re: Josie Olsen Sat Apr 07, 2018 1:15 pm
Amazing work
Subject: Re: Josie Olsen Sat Apr 07, 2018 1:57 pm
Thanks guys.
Subject: Re: Josie Olsen Fri Apr 13, 2018 8:20 am
Started on the rudder fittings 4 - 6mm dia pulleys and the tiller arm. The shape of the stern cabin limits choices for activating the tiller at present the servo horn and tiller arm will be aligned with the the bow, I'll dig out a Tx, Rx and battery To determine if the servo horn needs to be reversed for correct Tx stick to rudder movement so I can select placement for the pulleys an their small towers.
Subject: Re: Josie Olsen Tue Apr 17, 2018 9:30 am
Cleaned and vacuumed the shed yesterday when finished the shed gremlins had made off with the tiller arm the four pulleys were still there though. Made another arm today after searching thru the vac bag and the rubbish bin without finding the missing arm.
Subject: Re: Josie Olsen Tue Apr 17, 2018 6:08 pm
Its always a mistake to be too clean and tidy Damien
Subject: Re: Josie Olsen Wed Apr 18, 2018 1:55 am
It's probably under one of the drawer units if I get down on my knees to look I'll never get up again.
Subject: Re: Josie Olsen Wed Apr 18, 2018 2:41 am
Subject: Re: Josie Olsen Wed Apr 18, 2018 7:46 pm
a magnificent model Damien.................and a beautiful ship too.
Subject: Re: Josie Olsen Thu Apr 19, 2018 1:03 am
Thanks mate.
Subject: Re: Josie Olsen Thu Apr 19, 2018 7:46 am
Drilled and tapped the tiller arm 3mm for the grub screw, started cutting scrap 10mm x 7mm pine for the pulley mounts and forgot how big my butt is and knocked the motor beam assembly to the concrete floor smashing the motor mount pivot assembly hinge points.
Subject: Re: Josie Olsen Sat Apr 21, 2018 8:57 am
Repairs went well.
Servo to tiller pulleys and cord added and mounted a quick test showed it works well. With a small spring on either side of the fitting on the servo arm maintaining tension on the braided cord the same cord used on funnel and mast stays.
Subject: Re: Josie Olsen Sat Apr 21, 2018 9:32 am
Couldn't get anymore done as we had a major catastrophe one ear on Jo's computer headphones died been expecting it as mine died a fortnight ago not a bad run from Sennheiser headphones salvaged 35 years ago from the waste bin at 3ccc then a local community radio where I was a technician and rewired not surprised really the stereo cord I rewired with was rather brittle after after so long. I had an emergency run to Kmart
Subject: Re: Josie Olsen Sat Apr 21, 2018 11:07 am
I really like your take on the rudder pulley assembly! It’s almoat a shame to hide it!
Subject: Re: Josie Olsen Sat Apr 21, 2018 11:49 am
Thanks Aron couldn't think of any other way with such restricted space.
Subject: Re: Josie Olsen Sat Apr 21, 2018 1:46 pm
At first look I figured a simple connecting rod to the tiller would have worked but it clicked your space was limited on ability to turn using that method without fouling the hull, basically you build a quadrent assembly and your method is somthing I’ve yet to see in a model!
Still being schooled by the old boys!
Aron
