| like a kid in a sweet shop | |
+8alw zetec Thornej raaartygunner Specialbuilder davidjt gribeauval Roadrunner 12 posters |
| Subject: Re: like a kid in a sweet shop Sat Mar 30, 2019 6:12 am | |
| Subject: Re: like a kid in a sweet shop Sun Mar 31, 2019 12:23 am | |
| Subject: MYSTERY OF PARTS....NOW SOLVED Mon Apr 01, 2019 2:55 pm | |
| It never ceases to amaze me how two boats that come from the same company can be different in the smallest but strangest of ways. and this is no different with the Shannon class lifeboats built in house at RNLI Headquarters, Poole. let me show what I mean. the following two photos are of a specific area of both the St Ives and the Lytham St Annes boats. one could be forgiven for saying that they are both the same, but one small fitting is different, and this would of course be picked out by rivet counters, and those picky enough to say "you've got it wrong mister"...…...not that it would bother me...….. try to spot the small but significant difference. One of the parts in the Speedline fittings set has had me befuddled for months...….even put pictures on to the forums, and sent to Adrian Gosling without reply. As a last resort I even took the parts to both Fleetwood and St Annes lifeboat stations, and the mechanic at the latter, and coxs'n at the former could not recognise the parts as part of 13-14 or 13 -24, because on those two boats, they don't exist, nor do they on 13-21 the training Shannon...……...but they do on the St Ives boat. It's no wonder that modelling modern lifeboats is a nightmare and subject to all sorts of geeks coming out of the woodwork at you telling you that you've go it wrong......I despair at times, as it wasn't like when I built steam trawlers, tugs and classic lifeboats! so have you got it yet..…..have another look at the middle of the life rings......there is an object in the centre......the EPIRB [emergency position-indicating radio beacon] and bracket...….both different fittings...….one allows the indicator to float vertically, the other floats out horizontally...….its no wonder that the guys on the local boars didn't recognise the former, because our local boats use the latter systems...….. so! knockers rivet counters and general know all geeks...…...there's always an answer t the difference. and here are the two in 1;12 model form...…..with the two from Speedline being reserved for micks, MBD Shannon. |
| Subject: Re: like a kid in a sweet shop Wed Apr 03, 2019 9:21 pm | |
| Just waiting for some 5mm black vinyl lettering from Leeds model shop, and I can finish the life rings, before adding the "rope" safety lines. the SOLAS regulation reflective tape has been added to the rings...…..found this reflective tape in a ships chandlers and cut some 4mm strips to wind round the rings. also through the post today came the 6mm yellow and red lining tape to add to the hulls once I have retrieved them from Dave in wales. in the meantime I shall continue to paint the fittings...…...the small ones that are remaining are the last to be painted. |
| Subject: Re: like a kid in a sweet shop Wed Apr 03, 2019 11:00 pm | |
| Just a piece of useless info the silver tape was originally developed as Battlefeild repair tape for Aircraft and is also used extensivly by engineers installing ducting in shops etc Dave |
| Subject: Re: like a kid in a sweet shop Thu Apr 04, 2019 12:45 am | |
| - stavros wrote:
- Just a piece of useless info the silver tape was originally developed as Battlefeild repair tape for Aircraft and is also used extensivly by engineers installing ducting in shops etc
Dave nope, I like that sort of information mate...…interesting stuff that makes us all wiser...…...well tghose that want to learn, that is. ...just like what WD40 was invented for...…….if only the scientists knew that their wonderful stuff now helps lowly me to lubricate a lazy electric window in my Nissan note...……..what would they think, lol. |
| Subject: Re: like a kid in a sweet shop Fri Apr 05, 2019 11:03 pm | |
| just had it pointed out to me by andy via mick French on a private message that I had got the H frame at the rear of the mast upside down...……. I would have looked a right prat had I fitted this all together permanently, and not been able to fit the back rest...…….an open thanks to you andy for putting me right. the frame below is upside down...….. both now been corrected. |
| Subject: Re: like a kid in a sweet shop Mon Apr 08, 2019 1:11 am | |
| Subject: Re: like a kid in a sweet shop Mon Apr 08, 2019 3:55 pm | |
| Subject: Re: like a kid in a sweet shop Tue Apr 09, 2019 3:12 am | |
| Subject: Re: like a kid in a sweet shop Thu Apr 11, 2019 10:01 pm | |
| stainless steel cleats have now been added to the raised bases ready to go on to the MBD boat...…..think there are a couple spare there…..just in case I dropped one or two onto the floor of my pristinely tidy workshop, lol. each and every little part now ready just means I don't have to fabricate them once the boat comes back from the artiste that's painting them for me, Stavros. |
| Subject: Re: like a kid in a sweet shop Sun Apr 14, 2019 7:44 pm | |
| my next job, and one which I have not been longing to is to put in all the 12v LED's...……….i'm not an electrician nor an electronics wizard...…. and I think this is going to be a loonnnngggggjob………..but has to be done before any other building work can take place at all. so will now wait for the boats to come back from being painted in the next few weeks...……….in the meantime I will wire up the lights for the mast and spot/search lights in the meantime...…...give me something to do, as almost all painting and assembly of fittings has been done. …….but gawd, theres a lot of lights and more on order through my friend mick French. |
| Subject: Re: like a kid in a sweet shop Sun Apr 14, 2019 10:05 pm | |
| would I be right in thinking that with a row of 12v rated led's each fitted with its own resistor each LED could be spliced into the next one in front of it until all are linked to the main 12v battery just with one wire each for each terminal, without loosing any brightness in the bulb at the end of the link. thank you. |
| Subject: Re: like a kid in a sweet shop Mon Apr 15, 2019 2:21 am | |
battleshipbuff Gunner
| Subject: Re: like a kid in a sweet shop Tue Apr 16, 2019 1:58 am | |
| Subject: Re: like a kid in a sweet shop Tue Apr 16, 2019 2:28 am | |
| Subject: Re: like a kid in a sweet shop Tue Apr 16, 2019 9:13 am | |
| LEDs typically require 3.2 volts the resistors are to drop the voltage and regulate current my memory couldn't find the formula so I looked it up. Here ya go mate. The string you've drawn is correct, this link gives the formula for correct resistor versus current & voltage of supply http://www.ohmslawcalculator.com/led-resistor-calculator |
| Subject: Re: like a kid in a sweet shop Thu Apr 18, 2019 12:49 am | |
| dave made great progress today and sprayed the orange onto both superstructures of the two Shannon lifeboats...….what a fantastic job. see here for close up photos. https://www.thercmodelboatforum.com/t1862-a-pair-of-shannons#17818 |
| Subject: Re: like a kid in a sweet shop Thu Apr 18, 2019 1:27 am | |
| Subject: Re: like a kid in a sweet shop Thu Apr 18, 2019 5:07 pm | |
| Subject: Re: like a kid in a sweet shop Fri Apr 19, 2019 7:25 am | |
| Subject: Re: like a kid in a sweet shop Mon Apr 22, 2019 11:29 pm | |
| Subject: Re: like a kid in a sweet shop Mon Apr 22, 2019 11:47 pm | |
| Clever thinking Batman! I like that idea, using the caps that is, not you galloping off to the loo Nah don't want to think of that at all:lol!: Mick F | |
| Subject: Re: like a kid in a sweet shop Tue Apr 23, 2019 12:27 am | |
| feed them to the dog, she'll eat anything, and she's a bit constipated, lol……………… NO FOLKS I DIDN'T MEAN IT...…………..shes far too precious to us...…… |
| Subject: Re: like a kid in a sweet shop Tue Apr 23, 2019 3:21 am | |
| Subject: Re: like a kid in a sweet shop Tue Apr 23, 2019 10:14 am | |
| Subject: Re: like a kid in a sweet shop Tue Apr 23, 2019 11:37 am | |
| Subject: Re: like a kid in a sweet shop Wed Apr 24, 2019 1:10 am | |
| Subject: Re: like a kid in a sweet shop Wed Apr 24, 2019 12:22 pm | |
| Subject: Re: like a kid in a sweet shop Wed Apr 24, 2019 12:35 pm | |
| Subject: Re: like a kid in a sweet shop Thu Apr 25, 2019 2:21 pm | |
| - barriew wrote:
- I hope you've got all these parts safely stored so you know you can find them again Neil. Knowing your workshop I can see a disaster looming
Amazing attention to detail.
Barrie cheers barry, I just hope its worth all the blood sweat and plenty of tears building them. to be honest I find it easier building something from total scratch, than building a semi kit with crap plans and virtually no instructions.....and then find you have to build and generate small parts that you have to finish the model off with some form of reality...……. ...…….. the fittings supplied in the semi-kit are superb...……..but when you then have to make other parts not supplied...……..it defeats the object of producing beautiful parts in the kit...I might not be a good painter, and thus have handed them to Stavros, but I have a decent eye for smaller detail...…….sadly not of the same quality as the 3D printed stuff, and it takes the shine off the "kit" but they have to be made. that is why I like to scratch build...……….because your level of build is the same quality, you know what parts you need to make, cross them off the plan and list of "to do's" and know where every part goes, and you recognise every part of your model and in what order to put it on without needing a "parts list" and names to build one.had it not been a wonderful and precious gift and present from mick in Canada, it would have been an insult to him not to have finished it...……..I would however, had I bought it myself, taken a loss and sold it on...……..but I have got to the stage now of knowing that the worst is over, and once I have got the models back from Dave, it will be an easy job to finish the model with all the pre-made and painted parts...……...and then I'll enjoy sailing it. and joy of joys, I heard from mick in Canada two nights ago after nearly two months silence...............….I had EVEN EMAILED CALGARY POLICE DEPARTMENT,about going to see if he was ok, the local hospital and looked through the obituaries in the Calgary papers, as I was beginning to fear the worse, as the last time we spoke on the phone, he was unwell with a bad virus. however,as I said mick phoned me two nights ago...……..he had had a recurrence of the virus, and had been in hospital for some weeks, but was now in good recovery..…..so great news for those who have the privilege of knowing him...…...a lovely guy and a hoot to talk to. HOPE YOU FEEL MUCH BETTER VERY SOON MATEY.Best wishes, neil |
| Subject: Re: like a kid in a sweet shop Thu Apr 25, 2019 7:25 pm | |
| Subject: Re: like a kid in a sweet shop Thu Apr 25, 2019 8:12 pm | |
| Subject: Re: like a kid in a sweet shop Thu Apr 25, 2019 8:55 pm | |
| Oh Man up and put it in a pot of Cellulose thinners...YUP it will HURT like hell and YES we WILL all LAUGH,but it will cure it
Stav |
| Subject: Re: like a kid in a sweet shop Fri Apr 26, 2019 12:51 am | |
| Subject: Re: like a kid in a sweet shop Fri Apr 26, 2019 9:26 am | |
| Subject: Re: like a kid in a sweet shop Fri Apr 26, 2019 10:31 am | |
| just rereading your post barry about all the parts...……….I haven't a clue as to where half the parts are that I have either painted from supplied OR made...….……..am going to have a shock when I get the boats back and start fitting the parts to it...………...they'll be there somewhere...…..but where...…...god only knows lol. |
| Subject: Re: like a kid in a sweet shop Fri Apr 26, 2019 11:42 am | |
| Subject: Re: like a kid in a sweet shop Fri Apr 26, 2019 1:07 pm | |
| Subject: Re: like a kid in a sweet shop Fri Apr 26, 2019 1:28 pm | |
| Subject: Re: like a kid in a sweet shop Fri Apr 26, 2019 10:31 pm | |
| Subject: Re: like a kid in a sweet shop Sat Apr 27, 2019 12:16 am | |
| Subject: Re: like a kid in a sweet shop Sat Apr 27, 2019 4:07 pm | |
| sorry mick...………….forgot about yours, so had to make another this afrenoon………...oooopsss |
| Subject: Re: like a kid in a sweet shop | |
