| MY NEW PROJECT...or two. | |
+6davidjt barriew Tug--Kenny TonyW phil winks Footski 10 posters |
| Subject: Re: MY NEW PROJECT...or two. Sun Dec 16, 2012 10:24 pm | |
| Subject: Re: MY NEW PROJECT...or two. Mon Dec 17, 2012 2:17 am | |
| Subject: Re: MY NEW PROJECT...or two. Mon Dec 17, 2012 9:30 am | |
| Looking like a lot of milliput will be needed, lol |
| Subject: Re: MY NEW PROJECT...or two. Mon Dec 17, 2012 12:43 pm | |
Footski Master
| Subject: Re: MY NEW PROJECT...or two. Mon Dec 17, 2012 3:48 pm | |
| It's the joys of seeing something take shape out of mess, lol |
| Subject: Re: MY NEW PROJECT...or two. Mon Dec 17, 2012 10:05 pm | |
| But before I get down to the messy job of sanding that pile down I decided to cut and trim the front top box of the saling boat. Unfortunately as I don't have plans for this boat, I had to revert to using the small plans in my book Let Not the Deep for measurements. Both plans in the book ( which I showed early in the build log) show the sailor and the motor sailor at exactly the same size, and so by scaling the box on the motorsailor from the small plans, and the measurements I have from the 1:12 scale plans, I was able with dividers able to take measurements quite accurately from the sailor, and able to cutthe fore end box top to the right size. the last picture shows the difference in the shape of the motor sailer and the sailor bow end box tops |
| Subject: Re: MY NEW PROJECT...or two. Mon Dec 17, 2012 10:06 pm | |
| Finally today, I marked the line for the main decks in both boats which runs parallel to the bulwark tops on the boats. To mark these parallel, I cut a piece of timber ( part of an old venetian blind) at the correct depth, allowing for the thickness of the ply deck above the wooden stringers, and by placing it with one edge on the top of the bulwark, I marked the underside at the bottom of the spacer, and next is fitting the deck supports. |
| Subject: Re: MY NEW PROJECT...or two. Wed Dec 19, 2012 1:32 pm | |
| Subject: Re: MY NEW PROJECT...or two. Fri Dec 21, 2012 7:06 pm | |
| Subject: Re: MY NEW PROJECT...or two. Sat Dec 22, 2012 2:58 pm | |
| Subject: Re: MY NEW PROJECT...or two. Sun Dec 23, 2012 7:23 pm | |
| Subject: Re: MY NEW PROJECT...or two. Fri Dec 28, 2012 2:23 pm | |
| Subject: Re: MY NEW PROJECT...or two. Fri Dec 28, 2012 7:30 pm | |
| Subject: Re: MY NEW PROJECT...or two. Sat Dec 29, 2012 9:54 pm | |
Footski Master
| Subject: Re: MY NEW PROJECT...or two. Sun Dec 30, 2012 8:10 am | |
| Subject: Re: MY NEW PROJECT...or two. Sun Dec 30, 2012 2:40 pm | |
| Don't kmow about good, barrie....it's bl***y complicated getting everything aligned up and glued in the correct sequence, lol |
| Subject: Re: MY NEW PROJECT...or two. Mon Dec 31, 2012 6:30 pm | |
phil winks Master
| Subject: Re: MY NEW PROJECT...or two. Mon Dec 31, 2012 7:13 pm | |
| Subject: Re: MY NEW PROJECT...or two. Mon Dec 31, 2012 9:29 pm | |
phil winks Master
| Subject: Re: MY NEW PROJECT...or two. Mon Dec 31, 2012 10:07 pm | |
| half drunk already Neil | |
Footski Master
| Subject: Re: MY NEW PROJECT...or two. Tue Jan 01, 2013 8:52 am | |
| New Year is no excuse to stop working! Hope yu all had a great time? | |
| Subject: Re: MY NEW PROJECT...or two. Tue Jan 01, 2013 9:27 pm | |
Footski Master
| Subject: Re: MY NEW PROJECT...or two. Wed Jan 02, 2013 8:00 am | |
| Dedication....If I had tried going in the work shop on New Years day, I reckon the dinner would have gone in the cat!!! | |
| Subject: Re: MY NEW PROJECT...or two. Wed Jan 02, 2013 10:09 am | |
Footski Master
| Subject: Re: MY NEW PROJECT...or two. Wed Jan 02, 2013 10:45 am | |
| Oh dear......erm any chance of using a very short rod and a smaller motor? If not, drill a hole through the keel section,whatever that is called, lining it up with the shaft and fit the rod in that way. | |
| Subject: Re: MY NEW PROJECT...or two. Wed Jan 02, 2013 10:50 am | |
| Ummm flex shaft with the motor mounted beside the Boxing???????????????? D, |
| Subject: Re: MY NEW PROJECT...or two. Wed Jan 02, 2013 12:29 pm | |
| Well..........luckily, guys..............................
and it is pure luck, had the box been any further back I wouldn't have done........the prop shaft flexes just enough, and being stainless steel it doesn't bend........just flexes.......it goes in with a push........I am so lucky or else I'd have had to think of something else for the box..................but it means that for the first time in my building life I'm going to have to put a grease/oil tube on the prop tube...............off round to Rods in a minute or two to see what he has in the way of grease nipples and how to fix 'em in. |
| Subject: Re: MY NEW PROJECT...or two. Wed Jan 02, 2013 12:38 pm | |
| Subject: Re: MY NEW PROJECT...or two. Wed Jan 02, 2013 6:36 pm | |
| The Problem has been rectified, and all thanks and ideas go to my mate Rod (trawlerman) as to how to do the job, 'cos I was floundering. Take one block of nylon that my friend Andy (tatooed) from RCMB gave me some time ago, and drill it for the prop shaft to pass through and a piece of tubing at right angles. shape the nylon block to fit onto the prop tube and up tp the hull. Take one grease nipple supplied by Rod, and thread it onto a piece of Alluminium tube. Put some filler on the bottom of the block and some 2 part epoxy onto the prop tube and place the nylon block onto the shaft to glue and set in place. Drill a hole into the prop tube by drilling centrally down the hole in the nylon block. Glue the alli tube containing the grease nipple into the hole....voila' Grease the tube with my old mix of graphite powder and vaseline and insert the prop shaft, placeing a nut at each end once in situ ready for the propellor and motor. Thank goodness for good friends................but I won't publish the reply that Rod gave me as a solution before he gave me the grease nipple. neil. |
Footski Master
| Subject: Re: MY NEW PROJECT...or two. Wed Jan 02, 2013 7:59 pm | |
| Subject: Re: MY NEW PROJECT...or two. Wed Jan 02, 2013 8:29 pm | |
| cheers Barrie............but it was all trawlerman's idea.
| Subject: Re: MY NEW PROJECT...or two. Fri Jan 04, 2013 10:10 pm | |
Footski Master
| Subject: Re: MY NEW PROJECT...or two. Sat Jan 05, 2013 8:25 am | |
| Blimey Neil, I live a very quiet,boring kind of life out here in the sun......nothing exciting happens here.....mind you, not much modelling gets done either! | |
| Subject: Re: MY NEW PROJECT...or two. Sat Jan 05, 2013 6:43 pm | |
| Barrie, my wife describes me as a disater already happened......don't know what she means really............... Well , no one can accuse me of not building a boat to last, and take knocks. There's nothing worse than picking a boat up that feels flimsy and falls apart on you for lack of a "bit" of strengthening. Both boats have now had all their beams put in to take the decks....the only process to do now is to put a fillet of polyester filler into the boat between the hull and the bottom edge of the beams around the bulwark, and pour polyester resin and lead shot into the keel groove to set in place the keel boxes and the ballast.........that will be done tomorrow and sand the beams level to take the decks. these boats won't fall apart in a hurry. neil |
| Subject: Re: MY NEW PROJECT...or two. Sun Jan 06, 2013 1:35 pm | |
| applied the filler to the underside of the beams this morning..........messy and not pretty.....at the ends where I couldn't get underneath to apply the filler i put it in from the top.......... the boat will now be waterproof, at least from the top and deck, once the deck has gone on..............it's also incredibly strong and rigid now. the tops of the beams will be sanded down to remove excess and messy filler before the deck is placed onto the boat and glued sometime this week. |
| Subject: Re: MY NEW PROJECT...or two. Sun Jan 06, 2013 10:45 pm | |
| Oooooh I wish I could still work as fast as you Neil. Looking Goooood. Damien. |
| Subject: Re: MY NEW PROJECT...or two. Mon Jan 07, 2013 7:45 am | |
| Subject: Re: MY NEW PROJECT...or two. Mon Jan 07, 2013 8:37 am | |
Footski Master
| Subject: Re: MY NEW PROJECT...or two. Mon Jan 07, 2013 11:09 am | |
| Subject: Re: MY NEW PROJECT...or two. Mon Jan 07, 2013 4:41 pm | |
Footski Master
| Subject: Re: MY NEW PROJECT...or two. Mon Jan 07, 2013 6:10 pm | |
| Now this should be interesting. Rather you than me Neil... | |
| Subject: Re: MY NEW PROJECT...or two. Tue Jan 08, 2013 8:41 am | |
| I could think of other words, barrie, other than interesting, lol.......not really printable though, lol As the old proverb says.......necessity is the mother of invention....and yesterday I was filling in the upper pieces of the forward keel box to make it totally watertight. it needed some little blocks inserting at front and back and some side pieces....the blocks were clamped easily with small spring clamps.....but the sides were more diificult as there was only a 4mm gap to get into..........so I made some wooden wedges and drove them in with a small pin hammer to hold tight.........it worked..........the simplest of ideas are sometimes the best. |
| Subject: Re: MY NEW PROJECT...or two. Wed Jan 09, 2013 9:41 pm | |
Footski Master
| Subject: Re: MY NEW PROJECT...or two. Thu Jan 10, 2013 7:49 am | |
| Great work. I always mount my motors in resin and then use rubber bands to hold it in place. Never had any trouble with them either.... | |
| Subject: Re: MY NEW PROJECT...or two. Thu Jan 10, 2013 11:31 am | |
| people laugh at me Barrie, but I always secure my motors in with blutack..the hotter the motor gets the better stickiness the blutack gives, lol. Tank testing and ballasting took place this morning of the sailing lifeboat. She has been in the "test tank" aka the bath tub for 3 hours now to test (at full ballasted weight of 6.5 kilos) to weedle out any leaks in the hull around the keel boxes and I am happy to say that she is still bone dry. The large battery on top of the boat is the correct ballast weight needed to bring the sailor down to waterline. this poses a slight problem in weight distribution as the whole of the deck on this boat will be sealed and totally wathertight and so the ballast will have to go in in the next day or so before the deck is glued down permenantly........this will make manhanling it somewhat painfull at times, but as there will be no room or access to put it in at a later date as a permenant fixture it is the lesser of many evils. the motor sailor will be easier as there will be access into the hull for motor and such, and therefore can be made removeable in certain areas to make lighter to handle. |
| Subject: Re: MY NEW PROJECT...or two. Fri Jan 11, 2013 1:12 pm | |
| Subject: Re: MY NEW PROJECT...or two. Fri Jan 11, 2013 3:22 pm | |
| Neil,
Where do you get your lead shot? My previous supplier (leadshotballast.co.uk) has stopped selling shot and only sells sheet lead. I've found some dive shops selling it but its quite expensive that way.
| Subject: Re: MY NEW PROJECT...or two. Fri Jan 11, 2013 7:05 pm | |
| I think you'll find it expensive anywhere you go now Barrie.......this stuff I bought about 15 years ago and it's the last of a batch..........but the cheepest I found when looking the other day was here..... http://www.ebay.co.uk/itm/320825068603?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649 |
| Subject: Re: MY NEW PROJECT...or two. Fri Jan 11, 2013 7:08 pm | |
| I ballasted the motor sailor this afternoon, but before I could do that I had to make a "dam" around the motor so that once I poured in the resin to set the lead sheet in place, it wouldn't flow into the well that I had made for the motor to set into. Now both have had lead added I can give them both a bath, and add or take out any that is not needed before adding the resin. I have also taken into account the weight of the batteries, motor sevos and estimated weight of any materials for the rest of the build. Here's the second boat, the motor sailor. |
| Subject: Re: MY NEW PROJECT...or two. | |
