| Josie Olsen | |
+3barriew troutrunner Roadrunner 7 posters |
| Subject: Re: Josie Olsen Wed Nov 23, 2016 8:17 am | |
| It appears for about an hour a few times a day, I have to see my Doc next week I'm hoping it's wax build up on ear drum and a flush out will fix it I've never experienced it before.
| Subject: Re: Josie Olsen Thu Nov 24, 2016 5:54 pm | |
| Subject: Re: Josie Olsen Thu Nov 24, 2016 6:43 pm | |
| the more noisy the world and your surroundings get, the more people will suffer from it. |
| Subject: Re: Josie Olsen Fri Nov 25, 2016 2:05 am | |
| Such a relief when it goes away. |
| Subject: Re: Josie Olsen Fri Nov 25, 2016 5:10 pm | |
| You are lucky Damien, if it does for you.
I am plagued with it 24/7/365 ............just a constant ringing in my ears.......especially at night when all is quiet.
I suppose you grow to ignore it most of the time.
Jim. |
| Subject: Re: Josie Olsen Fri Nov 25, 2016 9:54 pm | |
| Some times just like pressure in the ear others it's so loud it drowns out my hearing aids, tv & workshop tools. See the Doc tuesday for blood test results so I'll tell her whats going on. |
| Subject: Re: Josie Olsen Sat Nov 26, 2016 12:07 am | |
| I finished the stern planking yesterday I'll get a pic later today as I try to work out I stuffed up and have one plank more on starboard side oh well to late now. |
| Subject: Re: Josie Olsen Tue Nov 29, 2016 4:40 am | |
| Trimmed to shape, got a little heavy handed sanding them and managed to delaminate the top layer of the port side 1.5mm ply deck. To stiffen it up I rough cut some 1.5mm ply scrap and glued it to the underside of the planks a little over size as seen in first pic. The gap filled with light weight filler ooop's looking at next pic shows a glaring fault in starboard hull shape at deck level more filler needed. |
| Subject: Re: Josie Olsen Mon Dec 05, 2016 6:10 am | |
| Outside hull had final coat of primer and upon checking the plan my forward deck planking goes 30mm too far astern a bit of cutting tomorrow, also the stand I made her will need significant lowering of the side retainers as they will currently interfere with the hull to underside of deck braces. On the up side I've marked where the braces need to be will mark the waterline tomorrow with a liuttle help from my missus. |
| Subject: Re: Josie Olsen Mon Dec 05, 2016 9:57 am | |
| Looking good and smooth Damien. Barrie | |
| Subject: Re: Josie Olsen Mon Dec 05, 2016 10:11 am | |
| Thanks Barrie. |
| Subject: Re: Josie Olsen Sat Dec 17, 2016 6:59 am | |
| Decided to get a start on the wheels only to discover the 24 wheel blades and the wheel inner discs have disappeared started cutting new ones from 2mm polystyrene only to discover the plastic handle on my guillotine flexes and cuts out of square the square & the base also flexes so mounting on 12mm MDF coming up Hmm perhaps it's more for balsa. Machined 4 new 60mm inner discs on the lathe. Just awaiting arrival of 10mm dia brass from Hong Kong to turn the wheel centres. |
| Subject: Re: Josie Olsen Sun Dec 18, 2016 9:47 am | |
| More progress Damien Keep up the good work Shame you lost and have to remake those parts, have a last look to see if you can find them, you know what will happen, you'll make new ones then find the originals....................... | |
| Subject: Re: Josie Olsen Sun Dec 18, 2016 10:11 am | |
| No I recently had a clean up and threw out a lot of old vitamin and pill bottles they were in on of them the wheel rims and spokes were store separately it not good getting older |
| Subject: Re: Josie Olsen Tue Dec 20, 2016 5:00 am | |
| GRRRRRRRRR grumble, a polite way of saying what i called myself after finding my carefully laid out deck support braces on port side were 6mm further forward than starboard side. |
| Subject: Re: Josie Olsen Thu Dec 22, 2016 10:28 am | |
| All good removed them and made new supports and got the the rudder servo fitted in place. |
| Subject: Re: Josie Olsen Thu Jan 05, 2017 7:59 am | |
| First wheel centre machined just needs to be drilled and tapped the second is part machined it got too warm in the shed 33c outside today. |
| Subject: Re: Josie Olsen Thu Jan 05, 2017 10:33 am | |
| Roll on summer, plenty of frost around here at the moment Sounds like you could do with air conditioning Damien | |
| Subject: Re: Josie Olsen Thu Jan 05, 2017 10:44 am | |
| Aircon in a zincalume shed under the carport we don't have aircon in the house & Gov't not likely to put it in. And temp's forecast for next 6 days 33, 34, 31,27, 32, 19c still 2 months of summer |
| Subject: Re: Josie Olsen Fri Jan 06, 2017 4:33 am | |
| Second centre turned no need for pic it's identical to first. That's it until possibly this evening as it's 38deg C in the shed. |
| Subject: Re: Josie Olsen Tue Jan 10, 2017 4:10 am | |
| Decided today was start the wheels day whilst searching for the pre cut spokes I pulled the brown paper from this pill bottle. And what did I find? The lost wheel centres and floats. Subsequently found the spokes and built one rim. |
| Subject: Re: Josie Olsen Tue Jan 10, 2017 8:46 am | |
| Good news then | |
| Subject: Re: Josie Olsen Tue Jan 10, 2017 10:09 am | |
| I thought so Paul I went out before dinner and turned it upside down to build the other thought I'd done well until after dinner I went out to assemble the 2nd wheel to discover I'd put the centre disk in place but had forgotten the 2 rings and glued the together 40 minutes later I had salvaged the original half had to cut another centre disc. The original half with the remains of the 2nd centre. The new centre and 12 new spokes. |
| Subject: Re: Josie Olsen Tue Jan 10, 2017 10:42 pm | |
| putting those wheels together, matey.........you have the patience of a saint............looking good, and that hull is superb. |
| Subject: Re: Josie Olsen Tue Jan 10, 2017 11:46 pm | |
| Subject: Re: Josie Olsen Wed Jan 11, 2017 5:36 am | |
| First wheel ready for assembly. First half of second wheel done the arrow on hub is a key for later assembly it will be turned spokes down and the other half is built on top when assembling the arrows assure perfect alignment of the paddles. All four rims complete. |
| Subject: Re: Josie Olsen Wed Jan 11, 2017 9:58 am | |
| Coming on nicely now Damien , I'm looking forward to seeing the completed paddle wheels | |
| Subject: Re: Josie Olsen Wed Jan 11, 2017 10:09 am | |
| Not long now Paul, Wheel centres drilled and tapped 3mm. |
| Subject: Re: Josie Olsen Wed Jan 11, 2017 6:25 pm | |
| You're becoming the paddle wheel expert Damien. How many set is this you've made? Looking good.
| Subject: Re: Josie Olsen Wed Jan 11, 2017 10:39 pm | |
| 3 sets Barrie.
I had intended using a burr in my Dremel to put grooves in the mating surfaces prior to epoxying now thinking I'll drill 1.5mm and use stainless pins. |
| Subject: Re: Josie Olsen Mon Jan 16, 2017 3:43 am | |
| The drilling was unsuccessful as it was impossible to a centre punch close enough for drilling the pin holes, so cut slots and silver soldered the cross pins in place. |
| Subject: Re: Josie Olsen Mon Jan 16, 2017 11:43 pm | |
| I am mesmerised by this build. |
| Subject: Re: Josie Olsen Tue Jan 17, 2017 12:49 am | |
| And i'm stressed buy it lol
Went out to see how the first half wheel to centre gluing went, not good if it wasn't a fire ban day I'd put my propane torch to the whole shebang some how even with the wheel weighted to stop warping when I spun in lathe to check it and it has a 4mm wobble. 36c in shed to hot to bother with it today tomorrow is to be 24c perhaps look to see if I can drill the centre from the wheel and try again. |
| Subject: Re: Josie Olsen Tue Jan 17, 2017 9:18 am | |
| Feeling calmer I thought about it and tomorrow I'll chuck the brass centre in the lathe and then grind a parting tool point of 1mm and 6mm cut depth to separate it from the wheel with minimum polystyrene loss. And have another go at the bludger. |
| Subject: Re: Josie Olsen Sat Jan 21, 2017 4:49 am | |
| Both wheels assembled several of the floats are not quite 90 deg to the rims some how a couple of spokes must have moved whilst drying. |
| Subject: Re: Josie Olsen Sat Jan 21, 2017 8:17 am | |
| A complicated job there Damien, they look ok to me, it will still look ok if a couple of bits align wrong. In reality I bet there was a margin of error or a in any case they would have had repairs done over the years just to get her moving again. | |
| Subject: Re: Josie Olsen Sat Jan 21, 2017 9:05 am | |
| Subject: Re: Josie Olsen Sat Jan 21, 2017 3:40 pm | |
| superb but one hell of a job.........you have the patience of a saint. |
| Subject: Re: Josie Olsen Sat Jan 21, 2017 9:56 pm | |
| As my mother was want to say (YOU DIDN'T HEAR THE WORDS HE WAS YELLING) |
| Subject: Re: Josie Olsen Sun Jan 22, 2017 2:49 am | |
| Wheels temporarily in place, a few changes to the wheel area as with wheels hard against the hull the the wheels are still proud of the deck cabin lines. As seen in this pic. Rudder servo installed, as there is no room for a tiller arm I make a small brass pulley and use cord from both sides of the servo arms the other thought is a short piece of bowden cable. |
| Subject: Re: Josie Olsen Sun Jan 22, 2017 10:04 am | |
| Finding the control tube inner & outer binding when bent to shape I needed to change to cord control I re-positioned the Rudder servo to the centre line and turned 2 x 9mm dia pulleys that will sit either side of the tiller arm. I use the brass section of an electrical terminal block and some brass sheet for the tiller arm. This pic shows the pulleys and tiller parts. |
Oldsmokey Gunner
Posts : 120 Join date : 2014-10-10 Age : 86 Location : Bournemouth, Dorset. UK.
| Subject: Re: Josie Olsen Sun Jan 22, 2017 10:19 am | |
| Subject: Re: Josie Olsen Sun Jan 22, 2017 10:23 am | |
Oldsmokey Gunner
| Subject: Re: Josie Olsen Sun Jan 22, 2017 10:38 am | |
| I can see that reading through your build log, but you are up for it and overcoming all the problems, health, extreme weather, materials not co-operating as we would like. Thought, you're are not expecting a plague of Locusts or Termites about now? It always gives me a lift to see your work and how you did it your way. | |
| Subject: Re: Josie Olsen Sun Jan 22, 2017 11:03 am | |
| Subject: Re: Josie Olsen Mon Jan 23, 2017 11:02 am | |
| Subject: Re: Josie Olsen | |
| Josie Olsen | |
