 Josie Olsen
7 posters
Go to page : Previous  1, 2, 3 ... 7, 8, 9, 10, 11  Next
Josie Olsen - Page 8 Empty
PostSubject: Re: Josie Olsen   Josie Olsen - Page 8 EmptyFri Feb 09, 2018 10:07 am
Finished the narrower doors this morning and applied a coat of dope to seal the grain left it several hours and applied a coat of satin clear this is the result.
Josie Olsen - Page 8 Img_0810
Embarassed Embarassed Embarassed Embarassed  The clear didn't like the dope obviously by the cloudiness.
Another lesson learned as air in shed turned rainbow colours into the bin they went.
Start again tomorrow using 5mm x 3mm planks used on bow & stern decks.
PostSubject: Re: Josie Olsen   Josie Olsen - Page 8 EmptyFri Feb 09, 2018 9:22 pm
nil illigitimous carburundum,  2thumbsup 2thumbsup 2thumbsup
PostSubject: Re: Josie Olsen   Josie Olsen - Page 8 EmptyFri Feb 09, 2018 11:40 pm
2thumbsup 2thumbsup
PostSubject: Re: Josie Olsen   Josie Olsen - Page 8 EmptySat Feb 10, 2018 9:39 am
The timber is actually 4.1mm x 2.2mm brown and white 5.26mm x 2.2mm
Josie Olsen - Page 8 Img_0811
For the narrower door the white rails are edge on leaving considerable sanding to do.
PostSubject: Re: Josie Olsen   Josie Olsen - Page 8 EmptySun Feb 11, 2018 7:42 am
Trimmed and sanded smooth not an easy task pushing 2mm wood back & forth on 280 grit sand paper nails on 3 fingers are rather strangely manicured lol, rails for sliding cargo doors fitted not final sanded yet.
Josie Olsen - Page 8 Img_0813
PostSubject: Re: Josie Olsen   Josie Olsen - Page 8 EmptySat Feb 24, 2018 10:36 am
The sliding doors morphed into hinged doors as they were to high. opp's
The cut and polish sort of worked it can stay as it is now.
I've hidden the worst of the primer bleed through with some woven 3mm dia cord liberally coated with dope and hung to dry with a weight on the end and left overnight to dry.
Next day a bead of balsa glue put around lower deck-cabin join.
Josie Olsen - Page 8 Img_0820
Josie Olsen - Page 8 Img_0819
Started on windows for the want of correct word the top the rear of the upper deck roof using 2 7mm strip of mirror tile and 3mm brown pinstripe tape, the lined strip of paper at the top of the pic had the correct spacing for the frame uprights i used it to mark the spacing on the wood for the position of the frame uprights.
Josie Olsen - Page 8 Img_0818
Josie Olsen - Page 8 Img_0821
Had to call it quits too dangerous to work with double vision it comes And goes a side effect of radiation treatment to the head.
PostSubject: Re: Josie Olsen   Josie Olsen - Page 8 EmptySun Feb 25, 2018 7:40 am
Trimmed and pleased it fitted perfectly.
Josie Olsen - Page 8 Img_0822
Started fitting the pre-made windows.
Josie Olsen - Page 8 Img_0823
Josie Olsen - Page 8 Img_0825
The six doors with mirror tile windows and door handles cut from 50mm pins with double sided tape fitted to back.
Josie Olsen - Page 8 Img_0824
The larger Cargo and passenger doors fitted to forward wall.
Josie Olsen - Page 8 Img_0826
PostSubject: Re: Josie Olsen   Josie Olsen - Page 8 EmptySun Feb 25, 2018 7:51 am
Coming to life now Damien. 2thumbsup 2thumbsup
PostSubject: Re: Josie Olsen   Josie Olsen - Page 8 EmptySun Feb 25, 2018 8:01 am
Yes Barrie.
Finally any paint imperfections will now be weather/battle scars lol!
PostSubject: Re: Josie Olsen   Josie Olsen - Page 8 EmptySun Feb 25, 2018 8:55 am
hi Damien
really looking good now you have fixed windows 2thumbsup 2thumbsup there light is at the end of the tunnel now. have they cleaned up your lake yet as you said it was over grown some time ago.
PostSubject: Re: Josie Olsen   Josie Olsen - Page 8 EmptySun Feb 25, 2018 9:47 am
Thanks David, no the weed islands in the middle of the lake have grown by several acres at a guess and around 2.5 to 3 ft of weed on the downwind side they've been regularly mowing the rowing course obviously missing lots of weed in the catcher.
With such a large lake I've no option but the down wind side if anything untoward happens to a model.
PostSubject: Re: Josie Olsen   Josie Olsen - Page 8 EmptySun Feb 25, 2018 8:13 pm
it looks absolutely beautiful, especially classic in those colours and hues.......really is going to be a beautiful boat.
PostSubject: Re: Josie Olsen   Josie Olsen - Page 8 EmptySun Feb 25, 2018 11:31 pm
Thumbup Thumbup Thumbup
PostSubject: Re: Josie Olsen   Josie Olsen - Page 8 EmptyMon Feb 26, 2018 5:30 am
Mid deck forward windows fitted. (note to self do all these fiddly bits before fitting the railings)
Josie Olsen - Page 8 Img_0827
Got 3/4 of the mid deck rear done and what I thought was aligned well wasn't by a long shot more fun (not) removing the duds held not only with double sided tape but also super glue where they were on curves the mirror tile plastic was less inclined to bend and overcame the sticky backing. Equally hard to get things aligned well with double vision & with one eye shut. Gave up for the day.
PostSubject: Re: Josie Olsen   Josie Olsen - Page 8 EmptyTue Feb 27, 2018 7:58 am
All windows fitted some slightly crooked but the best my eyes and shaky hand can do.
Josie Olsen - Page 8 Img_0829
Josie Olsen - Page 8 Img_0828
Interesting tricks of light that makes Ivory yellow look pink.
Found I was still 2 doors short they're ready to install thursday as tomorrow we're off to the big smoke for 3 specialist appt's that'll take most of the day
First time in 24yrs they're all on same day.
PostSubject: Re: Josie Olsen   Josie Olsen - Page 8 EmptySat Mar 03, 2018 1:44 am
Fitted the stanchions for the lower deck railings .9mm holes, .9mm brass rod and super glue also fitted final two doors yesterday.
Josie Olsen - Page 8 Img_0830
Josie Olsen - Page 8 Img_0831
also  prepared the railings using some low voltage cable approx 600mm long, I stripped off the outer coating formed a loop at one end, bent a hook on a piece of bike spoke and fitted it to drill which Jo operated at slowest speed whilst I applied finger pressure as it turned to produce a quality cable in next pic.
Josie Olsen - Page 8 Img_0832
Todays effort trim stanchions and start soldering the railings.
PostSubject: Re: Josie Olsen   Josie Olsen - Page 8 EmptySat Mar 03, 2018 4:27 am
Railings added yet to trim the solder.
Josie Olsen - Page 8 Img_0834
Josie Olsen - Page 8 Img_0833
PostSubject: Re: Josie Olsen   Josie Olsen - Page 8 EmptySun Mar 04, 2018 9:30 am
Masking needed prior to painting stanchions and rails thought of masking with a hole to fit around the stanchion diameter then slit so it'd slide in place paper tape was too flimsy so i retrieved the blue plastic tape from bin.
Josie Olsen - Page 8 Img_0835
The blue in place over the stanchion bases bready for the paper mask tape to fill the gaps & cover the deck.
Josie Olsen - Page 8 Img_0836
Gaps filled.
Josie Olsen - Page 8 Img_0837
Josie Olsen - Page 8 Img_0838
The brushable yellow proved to be too yellow after a few days drying I'll use some white spray enamel to lighten it.
Josie Olsen - Page 8 Img_0839
Meanwhile I'll do some more on the upper superstructure.
PostSubject: Re: Josie Olsen   Josie Olsen - Page 8 EmptyTue Mar 06, 2018 3:58 am
Yesterday, It turned out I had some of the ivory yellow left so sprayed some into a small can and waited half an hour for some thinners to evaporate and brushed it over the darker yellow left it an hour and brushed a second coat looks good left it another hour and removed the masking bent the rails a bit removing the tape with tweezers they'll straighten up OK though.
Josie Olsen - Page 8 Img_0841
Josie Olsen - Page 8 Img_0842
Today, I drew up some forward deck gates as pic shows only got half of one gate internals cut when double vision put paid to safe shed time for today.
Looking good so far.
Josie Olsen - Page 8 Img_0843
PostSubject: Re: Josie Olsen   Josie Olsen - Page 8 EmptyWed Mar 07, 2018 10:27 pm
2thumbsup 2thumbsup 2thumbsup 2thumbsup 2thumbsup 2thumbsup
PostSubject: Re: Josie Olsen   Josie Olsen - Page 8 EmptyThu Mar 08, 2018 1:23 am
Thumbup Thumbup
PostSubject: Re: Josie Olsen   Josie Olsen - Page 8 EmptyFri Mar 09, 2018 7:20 am
Got some more done on the paddle boxes from 5mm balsa cut 4 half circles for inside the box walls they'll give extra glue surface to glue the top to out side was easy after rough cutting I used the disc sander on the outer edge scratched my head on best way to do the inside then remembered the Dremel & router bits Damien Jr had given me which I'd previously made a mounting fixture that's held in a workmate foldable bench/vice.
I fitted a 10mm / 3/8th sanding drum which made short work of the inner curve.
Josie Olsen - Page 8 Img_0845
Once glue is dry I'll carve/sand the inside edge to 45deg.
I started to mount the front & rear walls then it hit me I hadn't yet finished the fronts so mounted a 3mm router bit in the dremel.
 Josie Olsen - Page 8 Img_0844
and easily routed to the lines.
 Josie Olsen - Page 8 Img_0846
PostSubject: Re: Josie Olsen   Josie Olsen - Page 8 EmptySat Mar 10, 2018 4:38 am
The gates have their last coat of paint,
Josie Olsen - Page 8 Img_0847
Balsa 1/2 circles sanded to 45deg after glue dried.
Josie Olsen - Page 8 Img_0849
Josie Olsen - Page 8 Img_0848
Josie Olsen - Page 8 Img_0850
you just have to laugh at yourself sometimes while putting fittings together to finish the upper superstructure spent 90 mins searching for A funnel fitting 20mm x 20mm x 3mm 90 deg bend eventually found it already attached to the funnel.
I'll glue the backs on monday too hot since 1-30 pm today and guests for lunch tomorrow.
PostSubject: Re: Josie Olsen   Josie Olsen - Page 8 EmptySun Mar 11, 2018 1:18 am
Got the backs on after dinner last night and the curved outer curved skins on this morning after everything was set up for the guests.
Tried to pin them in place without success so went with rubber bands never ending supply from postal deliveries.
Josie Olsen - Page 8 Img_0853
Josie Olsen - Page 8 Img_0852
One pair of gates in place ready for a slight lift once epoxy is applied.
Josie Olsen - Page 8 Img_0851
PostSubject: Re: Josie Olsen   Josie Olsen - Page 8 EmptySun Mar 11, 2018 10:23 am
Guests a nephew & his new bride arrived at 3-30pm for lunch and left around 5-30, I skipped the evening meal, helped Jo clean up the dishes and escaped to the shed to trim the wheel boxes only to discover super glue doesn't bond balsa to marine ply very well after scraping it off I reglued it with 5 min epoxy.
Josie Olsen - Page 8 Img_0854
Josie Olsen - Page 8 Img_0855
Josie Olsen - Page 8 Img_0856
Some filler in the pinholes tomorrow then a coat of polyester resin to the insides of the boxes.
PostSubject: Re: Josie Olsen   Josie Olsen - Page 8 EmptyMon Mar 12, 2018 8:31 am
Paddle boxes look great sitting in place on superstructure, although not quite in their correct positions.
Josie Olsen - Page 8 Img_0857
Josie Olsen - Page 8 Img_0858
The polyester resin applied to the insides cured and a coat of dope was applied to the outsides had dinner and went out and sanded it ready for primer tomorrow with a top of 20c or 68f it'll be ideal.
PostSubject: Re: Josie Olsen   Josie Olsen - Page 8 EmptyMon Mar 12, 2018 9:19 am
PostSubject: Re: Josie Olsen   Josie Olsen - Page 8 EmptyMon Mar 12, 2018 9:36 am
Thanks mate.
PostSubject: Re: Josie Olsen   Josie Olsen - Page 8 EmptyMon Mar 12, 2018 1:57 pm
hi damien,
you are coming on in leaps and bounds now, I really like the windows very realistic keep up the good work  2thumbsup 2thumbsup 2thumbsup .
PostSubject: Re: Josie Olsen   Josie Olsen - Page 8 EmptyMon Mar 12, 2018 11:44 pm
Thanks David, I'd like to say I'm glad the hassles are over but I won't as It might mozzzz me  lol! lol! lol! lol! lol!
PostSubject: Re: Josie Olsen   Josie Olsen - Page 8 EmptyWed Mar 14, 2018 7:00 am
All was going well until I sprayed the olive enamel over the grey primer filler on the paddle boxes it obviously reacts with enamel but is OK with acrylic paint I left them to dry and installed the rigging lines on the mast on top of the aft top deck fitting.
 Josie Olsen - Page 8 Img_0910
Then installed the Funnel.
Josie Olsen - Page 8 Img_0911
PostSubject: Re: Josie Olsen   Josie Olsen - Page 8 EmptyWed Mar 14, 2018 7:09 am
You don't have much luck with paint do you Damien lol!
PostSubject: Re: Josie Olsen   Josie Olsen - Page 8 EmptyWed Mar 14, 2018 7:26 am
Looks like I'll getaway with the paint on the boxes a light coat seems to have coverd ok.
PostSubject: Re: Josie Olsen   Josie Olsen - Page 8 EmptyThu Mar 15, 2018 4:02 am
Wrong again the corners of the curves still showed grey primer after 2 coats hopefully the third will cover it.
That's it for spray cans back to Airbrush where you control the paint to thinner consistency and the pressure of the airbrush.
 Josie Olsen - Page 8 Img_0913
The Funnel stays anchored.
Josie Olsen - Page 8 Img_0912
Bow mast and Anchor davit?
Josie Olsen - Page 8 Img_0914
Interesting omission on this plan/model although there's stairs and door into the wheel house there's no stairs or ladders to get up there.
PostSubject: Re: Josie Olsen   Josie Olsen - Page 8 EmptyThu Mar 15, 2018 11:51 pm
its looking amazing Damien......a truly stunning model.
PostSubject: Re: Josie Olsen   Josie Olsen - Page 8 EmptyFri Mar 16, 2018 11:40 pm
In the past I've always used automotive acrylic paint with great success and had it on hand from Hillclimb car days, trying to save paying taxi fares to buy good paint ride my scooter to Supercheap auto store and bought budget brand spray cans normally $5 a can on special sometimes   $3-50 on special. They also have acrylic spray cans at $16 to $20 a can depending on colour.
The closest Hardware or specialist paint store is a $20 round trip taxi fare making paint expensive.
The only acrylic I still have is metallic red and green left over from the Renault hillclimb car build how do you think they'll go on HMS Volcano ???????  lol! lol!
PostSubject: Re: Josie Olsen   Josie Olsen - Page 8 EmptySat Mar 17, 2018 8:40 am
Not a lot I can do on the superstructure until the paint hardens on the wheel boxes.
Back to the engine with the 1.6mm pin for the piston to rocker arm loose in the slides there was a tendency to bind so instead of the 4mm square brass tube I'd originally prepared some time ago, and lack of 4mm square solid brass I cut a strip from some 2mm x 90mm Sq plate 4.15mm wide cut to 20mm lengths tinned with solder then joined joined to 2- 4mm x 4mm x 20mm pieces drilled 1.6mm hole counter sunk on back of one and soldered the pin to it then filed them to fit the channel.
Josie Olsen - Page 8 Img_0916
A plastic washer to each side will stop the drift on right hand side.
Josie Olsen - Page 8 Img_0915
PostSubject: Re: Josie Olsen   Josie Olsen - Page 8 EmptySun Mar 18, 2018 8:37 am
Paddle boxes epoxied in  in place.
Josie Olsen - Page 8 Img_0920
Josie Olsen - Page 8 Img_0917
A little bit of filler where they connect to the deck I'll spray some ivory paint into a small plastic tub and add some plaster as the filler hopefully after sanding it'll only need one coat to finish them off.
Did some more on the piston slides 5 x 2mm washers hold it nicely and without oil it travels up and down very smoothly the pivot joints held with 2mm threaded rod with a nyloc nut on each end.
Josie Olsen - Page 8 Img_0918
Josie Olsen - Page 8 Img_0919
PostSubject: Re: Josie Olsen   Josie Olsen - Page 8 EmptyMon Mar 19, 2018 11:40 am
I had made locking discs for the wheel drive to output shafts but after searching for an hour so I butchered another motor to shaft coupler to make another pair of lock rings as shown in the pic.
Josie Olsen - Page 8 Img_0921
Both wheel box to deck joint gaps filler with Pollyfiller powder mixed in ivory paint, tomorrow I'll decant some more of the Ivory spray paint to an airbrush bottle and touch up the sanding marks and the few bits of paint removed when I took the small piece of trim tape off each side prior to installing the boxes.
Josie Olsen - Page 8 Img_0922
Josie Olsen - Page 8 Img_0923
Something else that's gone missing are the 2 drive axles as I was ready for this next pic.
Josie Olsen - Page 8 Img_0924
Any ideas on what colour the wheel should be please?
PostSubject: Re: Josie Olsen   Josie Olsen - Page 8 EmptyMon Mar 19, 2018 12:35 pm
Coming along really nice now Damien. Haven’t replied much just been busy but have been watching.
2thumbsup
PostSubject: Re: Josie Olsen   Josie Olsen - Page 8 EmptyMon Mar 19, 2018 9:52 pm
Coming along real nice Damien 2thumbsup
PostSubject: Re: Josie Olsen   Josie Olsen - Page 8 EmptyTue Mar 20, 2018 12:03 am
Thanks guys.
I can now at least envision the light at end of the tunnel  lol! lol! lol! lol! lol!
PostSubject: Re: Josie Olsen   Josie Olsen - Page 8 EmptyTue Mar 20, 2018 12:19 am
an amazing build Damien..................I'm just waiting to see this beam working on the model as she sails.
in my junior school days we were each given a project essay to do over the Christmas holidays...........I was 10 yr old, and my topic was James Watt and his famous invention...........WTF was james watt...........and what did he invent.........hated libraries as they were too stuffy and quiet..........but that is where I learned about his beam engine and pumping system for mines................never forgot it, and earned myself a gold star for my project..............so I am totally inspired by your beautiful model..........and can't wait to see it in action.
PostSubject: Re: Josie Olsen   Josie Olsen - Page 8 EmptyTue Mar 20, 2018 1:20 am
Thanks mate.
I suspect the closest to water she'll ever see is the test tank apart from the week covered lake I can no longer bend over without holding on to something I can use to push myself upright again, I'm thinking a golf bag 2 wheeled thingy cart might be an idea.
PostSubject: Re: Josie Olsen   Josie Olsen - Page 8 EmptyTue Mar 20, 2018 7:38 am
The engine and beam works beautifully nice and smooth, had to make minor change to the motor mounting plate with a bit of lock I'll get a video of it working tomorrow.
Josie Olsen - Page 8 Img_0925
PostSubject: Re: Josie Olsen   Josie Olsen - Page 8 EmptyTue Mar 20, 2018 5:28 pm
hi Damien,
the golf trolley sounds good to me,  I was thinking of the same thing for my boats as I am getting that way, I cant get up affraid . it  will roll down the edge of our lake and launch then the same retrieving it. we have had some launch made at the club but it looks to much trouble getting it out to me.
the beam looks great, hope you can find away of putting it on the lake you deserve to after all that work. is your other half queen  able to help you 2thumbsup 2thumbsup 2thumbsup .
PostSubject: Re: Josie Olsen   Josie Olsen - Page 8 EmptyWed Mar 21, 2018 3:15 am
lol! lol! lol! lol! lol! I'm not paying $600 for a golf trolley
I bought one of these,
https://www.ebay.com.au/itm/Portable-Folding-Luggage-Cart-Hand-Trolley-Wheel-Truck-Heavy-Duty-NOT-MAGNA-CART/251443516608?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649
I asked seller prior to purchase if the bottom plate locked in the open position and got a yes reply so I can put webbing from the base outer edge to the upright handle tubes to support the models.
PostSubject: Re: Josie Olsen   Josie Olsen - Page 8 EmptyWed Mar 21, 2018 6:44 am
hi Damien,
I would  not pay that for one Mad .I see them on car boots for £5.00 our so I keep looking then leave them, don't you have car boots down there Laughing . maybe this year I will get one Thumbup . that one looks good you have shown us should be just the job 2thumbsup .
PostSubject: Re: Josie Olsen   Josie Olsen - Page 8 EmptyWed Mar 21, 2018 7:31 am
Once a year we do have a buy swap & sell on facebook locally but have never seen them on there either the fold up will hang on the back of mobility scooter seat our city has a population of just over 100,000 the yearly buy, swap & sell is on is 300 acres lots of treasures mostly vintage cars and modified car stuff though.
PostSubject: Re: Josie Olsen   Josie Olsen - Page 8 EmptyWed Mar 21, 2018 8:29 am
The motor pulley needs a large size increase I hooked it up to 7.2v nicad pack and count the paddles as they passed a market point I imagine it would slow further if it was in water.
It's a 12v 2000 rpm geared motor I'll play with sizes until it's right.
Something I learned though is the weight of the motor is not enough to maintain good belt to pulley tension a light hand contact on the wheel caused the motor pulley to climb the belt  I'll have to add a spring either tension or compression which ever is easiest to fit unseen.
Josie Olsen
Page 8 of 11Go to page : Previous  1, 2, 3 ... 7, 8, 9, 10, 11  Next
TheRcModelBoatForum.com :: Modelling Categories & Archived Build Logs :: Paddle Boats-
