| Josie Olsen | |
+3barriew troutrunner Roadrunner 7 posters |
| Subject: Re: Josie Olsen Sun Nov 12, 2017 11:58 pm | |
| it must be global then Damien...............it rained here in the village where I live, EVERY SINGLE DAY at some point during the day/night since July 1st to the present moment............been an absolutely awful summer..........and sickness bugs because of the warm wet conditions are rife. |
| Subject: Re: Josie Olsen Mon Nov 13, 2017 6:50 am | |
| Today's 29c was 29.7c at 4pm 5:49 and no update yet. Got the masking done used the blue tape for the first time had it for quite some time & never remembered it was in the drawer lol Outstanding for curves wish I'd used it when I bought it. |
| Subject: Re: Josie Olsen Mon Nov 13, 2017 10:48 am | |
| Subject: Re: Josie Olsen Tue Nov 14, 2017 5:35 am | |
| Another coat of primer on the hull, and the manufacture of a waterline marking tool one carpenters pencil sacrificed and some scrap balsa. |
| Subject: Re: Josie Olsen Wed Nov 15, 2017 8:33 am | |
| Subject: Re: Josie Olsen Sat Nov 18, 2017 4:28 am | |
| Darn bother drat it's annoying the faults that show up whilst dry rubbing with 600 wet & dry paper lots more filling needed talc added to grey primer will alleviate spraying primer again.
No pic's when i took pic's they showed more faults than I'd noticed.
Gave up for today feeling off my other half is just over a few off days looks like she passed it to me. |
| Subject: Re: Josie Olsen Sat Nov 18, 2017 9:48 pm | |
| don't be despondent mate............the more you fill the less there is to fill next layer..............i'm the king of filler, don't you know.........use so much I've shares in isopon, lol |
| Subject: Re: Josie Olsen Sat Nov 18, 2017 10:36 pm | |
| Subject: Re: Josie Olsen Wed Nov 22, 2017 12:58 am | |
| Painting on hold for a few days temps for next few days with 29c today and medical stuff thursday 30c and friday 28c, saturday's a free day 25c then 22c for sunday. |
| Subject: Re: Josie Olsen Sat Nov 25, 2017 3:05 am | |
| Saturday had lunch 17.9 degrees ready to paint and a thunder storm rolls in and dumps a big load of water no paint today. |
| Subject: Re: Josie Olsen Sun Nov 26, 2017 5:00 am | |
| Subject: Re: Josie Olsen Mon Nov 27, 2017 6:21 am | |
| Grrrrrrrr 24 hours after airbrushing the superstructure is dry but the hull bottom is still really tacky, whilst spraying it it seemed a tad thick I assume it went on thicker than the ivory superstructure both colours were new tins of enamel. |
| Subject: Re: Josie Olsen Tue Nov 28, 2017 5:03 am | |
| 48hrs and still as tacky as yesterday I removed all the masking, out with the thinners and rags and took it back to primer left it an hour and took to it with 400 W&D paper dry when done a tack rag removed the dust and re primed her.
32c tomorrow I'll mix another batch of paint a lot thinner this time and see what happens. |
| Subject: Re: Josie Olsen Wed Nov 29, 2017 3:55 am | |
| 19hrs and the red is tacky and the brown is almost dry just slightly tacky you'd think 32c temp would help it dry. Ooops found this crack where the upper cabin has separated from the deck this will be tricky getting filler into it I just knew they'd be needed when I bought the long cotton buds. |
| Subject: Re: Josie Olsen Wed Nov 29, 2017 9:33 am | |
| It seems not Barrie.
I did a test piece with the original mix of red-dark brown they were new tins bought for the job I also did one with A dark buckboard brown of a different brand if that dries quickly I'll just use it instead and throw away the dud tins.
| Subject: Re: Josie Olsen Thu Nov 30, 2017 4:36 am | |
| Another day goes by the red/black test piece is still very tacky where as the brown is dry a trip to garbage land fill for the 2 dud tins. Nothing else happening here 32c feels like 39c in the little tin shed back inside. Weather mob predicts a week of low 20c's with up to 300mm of rain will be stuck inside if we don't float away. |
| Subject: Re: Josie Olsen Wed Dec 06, 2017 11:15 pm | |
| Most of the rain avoided us as did the heat just enough rain for high humidity, so set to work changing the shed around so I can fit Volcanos hull on the bench.
No pic's at pres it's a pig stye.
The red/black paint mix is still tacky. |
| Subject: Re: Josie Olsen Tue Dec 12, 2017 8:24 am | |
| Sprayed the mission brown on hull bottom very warm day not long until sun reaches model head inside for dinner afterwards discover wind had sprung up and deposited rubbish from neighbours trees all over it Grrrrrrrrrrrrrrrrrrrr Have sanded it with 1200 wet & dry and started masking it again. The talc in the ivory paint worked well as a filler then found a problem reaching the filler to sand it smooth coffee stirrers some PVA glue and some 120 grit powder did the job. |
| Subject: Re: Josie Olsen Wed Dec 20, 2017 5:04 am | |
| Resanded the bottom with 2000 wet & dry wet resprayed when dry I'm happy with it now left it a few days and masked the bottom ready for above waterline paint. The pop stick sanders were a flop wouldn't fit between the hand railings so shaved down some 1/4sq and put the grit on it next day it worked well. also fitted a dowel pin in the base of the funnel and marked and drilled it's position on the roof along with the other fittings shown on plan. Today I started cutting out the wheel covers. Also finished sanding the upper superstructure ready for paint tomorrow as it'll be a nice warm day. |
| Subject: Re: Josie Olsen Sat Dec 23, 2017 5:39 am | |
| The ivory paint went on ok until I was almost ready to turn her over to spray the lower deck cabin wall then CRAAAAACK and a piece of said wall fell on floor. Really regretting using balsa for this and of course holding weight of hull in one hand at the stern Grrrrrr should have learned when it happened spraying the primer. Lovely frame of mind it's left me in for the festive season. |
| Subject: Re: Josie Olsen Sat Dec 23, 2017 7:22 am | |
| Bad lick Damien - this build seems to have attracted all the Gremlins out there. Shut it in the shed and forget it over the holiday.
Happy Christmas to you!
| Subject: Re: Josie Olsen Sat Dec 23, 2017 11:00 am | |
| Well went out after dinner and patched her up. Super glued the piece in place some filler tomorrow. The inside will get some polyester resin and some 25mm glass tape as a precaution against further oooop's I rather like the ivory colour. |
| Subject: Re: Josie Olsen Sun Dec 24, 2017 3:36 am | |
| Polyfiller mixed with a little ivory paint (tried to buy more at local supercheap auto store as I only have 1 airbrush bottle full left, but they no longer sell the smaller tins and no way I'm buying any more of the bigger tins that don't dry) 1" or 25mm glass fibre tape laid inside with polyester resin. |
| Subject: Re: Josie Olsen Mon Dec 25, 2017 11:49 am | |
| After a big lunch sitting at pooter trying hard to stay awake I decided to head for the w/shop Sanded and remasked |
| Subject: Re: Josie Olsen Wed Dec 27, 2017 7:59 am | |
| Not a happy chappy Set Josie up ready for final olive spraying last time I filled the airbrush bottle I obviously hadn't put the lid on properly when I vigorously shook it to mix ready said lid flew off & my black T Shirt and shorts my arms , legs and chest through said T shirt & singlet. T shirt, singlet and shorts went straight in the workshop rubbish bin. Said bottle ended up upright unter bench with 5ml of paint left nowhere near enough to finish the job.
The clean up of me the bench and storage containers under the bench used 200Ml of thinners and a draw full of rags and lots of colourful language I'll just blame it on the HOT weather. |
| Subject: Re: Josie Olsen Wed Dec 27, 2017 9:43 am | |
| Damien Perhaps you should just abandon this one - Its obviously jinxed On the other hand you could shift some of your hot weather over here - we've got snow again I don't think I'll be in the workshop today. Barrie | |
| Subject: Re: Josie Olsen Wed Dec 27, 2017 9:53 am | |
| Don't think I haven't thought of it Barrie we had a 90deg F today and expecting 86F tomorrow along with thunderstorms I'll gladly send them your way if I could lol. |
| Subject: Re: Josie Olsen Wed Dec 27, 2017 5:27 pm | |
| I thought only I was as clumsy and jinxed as you seem to have been on this build.............but the model looks fabulous persevere matey......all these bad bits will fade to insignificance once you are sailing it on the water.............it is really a beautiful model. |
| Subject: Re: Josie Olsen Thu Dec 28, 2017 12:20 am | |
| Bought 2 spray cans of ivory on ebay cheaper than a small tin plus taxi to hardware store coming from Sydney should have them monday or tuesday. depending on how close they are in colour to that already sprayed may have to respray all the ivory a few days will tell. |
| Subject: Re: Josie Olsen Thu Dec 28, 2017 12:25 am | |
| or Wednesday, unless you get post on new years day n day after.........we don#t around here, lol. |
| Subject: Re: Josie Olsen Thu Dec 28, 2017 6:04 am | |
| The price of hard learned lessons T-shirt. Shorts. And all that's left of a once full bottle. The only way forward is to laugh at ones mistakes and move on. |
| Subject: Re: Josie Olsen Thu Jan 04, 2018 4:24 am | |
| The base discs for the lower deck handrail stanchions will now be made on the lathe from 6mm/1/4" pre drilled 1mm then turned to 4mm dia then cut to 3mm thickness with a razor saw whilst still spinning leaving a little to be cut by hand so they don't disappear into the shavings dust. |
| Subject: Re: Josie Olsen Thu Jan 11, 2018 3:29 am | |
| Can't win finally received the ivory spray paint a test shows a darker yellow than the previous ivory I airbrushed so I'll have to spray it all again not today currently 29.6c with a 20km wind across where I usually spray.
The 6mm dowel was put in chuck of lathe and using an extra long 1mm drill drilled the stanchion hole 50mm deep then turned it to 4 and a bit mm emery board took it to 4mm then moved it further out of the chuck to allow hand clearance from the chuck for the last bit, then with razor saw in right hand and left hand steadying the dowell & ready to catch the parted itsy bitsy bit of dowell I proceeded to cut the 15 req'd. |
| Subject: Re: Josie Olsen Thu Jan 11, 2018 11:16 pm | |
| you've had a struggle with this one mate..................but it'll be a triumph in the end and be a beautiful model. |
| Subject: Re: Josie Olsen Thu Jan 11, 2018 11:55 pm | |
| Subject: Re: Josie Olsen Fri Jan 12, 2018 3:46 am | |
| No paint today hot weathers gone away and rain has come our way forecast said 28c currently 20.7c with 94% humidity. |
| Subject: Re: Josie Olsen Tue Jan 16, 2018 6:20 am | |
| Got the paint on yesterday the spray can Ivory is considerably more yellow than previous Ivory I airbrushed, checked on it today whilst surface dry it needs a few days to a week to harden. On checking the rear deck level cabin walls I found some wrigley grey lines I've no idea why the grey primer rejects top coat paint in little lines. Sprayed some ivory into a plastic cup and added talc to it and filled the imperfections. I'm pleased with the upper decks paint. as pic' shows I'm thinking on the wheel boxes build next. |
| Subject: Re: Josie Olsen Tue Jan 16, 2018 7:42 am | |
| Looking good now Damien. Barrie | |
| Subject: Re: Josie Olsen Tue Jan 16, 2018 8:19 am | |
| Thanks Barrie, The funnel and associated fittings are ready to install, the bow, stern mast ect, are done and treated with brass blackening and look good.
The windows all 50 of them are ready to install my wife gave me a craft punch 10mm sq I used to cut window panes from 150mm self adhesive mirror tiles, then cut them from black card and trimmed to the outer shape of the window frames pics tomorrow. |
| Subject: Re: Josie Olsen Wed Jan 17, 2018 8:16 am | |
| The bow & stern masts the curved one is close to bow mast no idea what it's for though. The stanchion bases although using a 1mm centre drill as pic shows it still drifted off centre not doing more though. Still some cleaning up to do. I also sanded and sprayed the stern cabin wall and the grey crack lines appeared again lost for a cause as they were't showing prior to spraying perhaps I'll put life buoys over them. |
| Subject: Re: Josie Olsen Thu Jan 18, 2018 3:38 am | |
| Yesterdays paint ran slightly on port side where I was over enthusiastic trying to cover the primer breakthrough. yesterdays coat almost covered the grey breakthrough, so far todays seems to have covered it I hope so I'm already worried the upper decks won't fit. |
| Subject: Re: Josie Olsen Thu Jan 18, 2018 3:27 pm | |
| just catching up Damien.............that ivory colour, or as we poms used to call it on our MG cars, Old English White, looks absolutely beautiful..........so classy a colour, really sets the boat off well........love it. |
| Subject: Re: Josie Olsen Thu Jan 18, 2018 11:51 pm | |
| Still have primer breakthrough along the bottom of port side fed up painting I'll put some 3mm brown pinstripe tape around the whole rear cabin area to cover it 10.48am already 32.3c or 90.14f no shed today. |
| Subject: Re: Josie Olsen Mon Jan 22, 2018 8:25 am | |
| Finally took a pic of the windows awaiting installation. |
| Subject: Re: Josie Olsen Wed Jan 24, 2018 7:35 am | |
| I'm so over this model but it won't beat me, I removed the standard masking paper from the bottom of hull and all was good when I removed the blue polypropylene tape it left a flat finish and removed several match head sized pieces of the brown paint. I'm hoping cutting compound will restore the gloss finish. |
| Subject: Re: Josie Olsen Wed Jan 24, 2018 11:53 am | |
| After seeing the price of cutting gel decided it's not worth trying I'll just mask and spray again. Thought I may have some left from my Hillclimb car build though was mistaken. |
| Subject: Re: Josie Olsen Fri Feb 02, 2018 6:02 am | |
| The Cargo/equipment doors, the back is 1/16" or 1,5mm door frames from 2mm x 3mm balsa, cut strips for the cabin door fronts from .3mm x 4mm veneer. This pic shows the the build sequence. Glued some 6mm x 10mm balsa temporarily on the door backs to allow finger grips for sanding the door frames flat to veneer. The pic also shows 3 of the cabin door back ready for the frame pieces one still needed. |
| Subject: Re: Josie Olsen Sat Feb 03, 2018 7:46 am | |
| Started on the passenger doors had to dump 2 as the frame rails were held to tight and the rails ended up slanted inwards. The 1.5mm brass rod will become door handles. |
| Subject: Re: Josie Olsen | |
| Josie Olsen | |
